Author Topic: Caps  (Read 1966 times)
Offline Signature
  • master of puppers
  • * Moderator
  • snoozing
« Last Edit: Sun, 22 June 2014, 06:33:22 by Signature »
Offline epzy
  • HHKB Fiend
  • ded
Re: Caps
« Reply #1 on: Sun, 22 June 2014, 06:31:55 »
You can lock it yourself. The lock topic button is next to 'Quick Reply' down to the left. :)
Offline Signature
  • master of puppers
  • * Moderator
  • snoozing
Re: Caps
« Reply #2 on: Sun, 22 June 2014, 06:34:31 »
Ty I'm pretty retarded... MY switches has the same stem as MX right?
Offline iAmAhab
  • Established member
Re: Caps
« Reply #3 on: Sun, 22 June 2014, 08:04:36 »
Yes, but 1.25 mods have off center stems, so beware.
Offline Prelim
Re: Caps
« Reply #4 on: Thu, 10 July 2014, 16:56:55 »
aren't those laser printed?
2x GH60 revC - lubed Linjärs 65g / lubed H1s 65g with SPRIT 5mm acrylic plate | Dolch PAC - Cherry housing / Gateron sliders 65g and QMK clips | Raptor K1 G80-1890 stock
Floating on Cherry/GMK caps
