Author Topic: The Robot-65 (aka: Elf Board): Wood + Alu + Steel custom  (Read 39021 times)
Offline KHAANNN
Re: The Robot-65 (aka: Elf Board): Wood + Alu + Steel custom
« Reply #50 on: Thu, 04 June 2015, 03:13:21 »
Damn, I want one, it's too beautiful :)
Also thanks for the inspiration, I don't know whether I'm going to use it, but it inspired me to try different materials for a keyboard case, lego being the leading one of them
I was looking for a keyboard to go with your True Retro set, it seems this keyboard / layout would be an awesome choice
Offline neverused
« Reply #51 on: Sun, 12 July 2015, 03:02:18 »
it is going to be available soon!
I hope you mean the files, and not the massdrop group buy. I sense more wallet hackery in progress if you make it too easy for geeks to get hold of your wooden casing...
everything will be released (PCB, 3d files, etc...)
the keyboard (in plastic, not wood) will be released soon.
Hi Matt3o,
Is there any chance these files will be released soon?
Offline yehoshuaf
« Reply #52 on: Sun, 12 July 2015, 09:55:35 »
Very nice. I'm curious about how the teensy fit in the plate.
Offline Matt3o
  • -[起財-
  • ** Robot Emeritus
« Reply #53 on: Sun, 12 July 2015, 13:39:38 »
a very similar keyboard will be soon available in a DIY kit.
This is just an early prototype
PCB will be white :)
Offline KHAANNN
« Reply #54 on: Sun, 12 July 2015, 13:42:22 »
so foxy
can't wait
Offline neverused
« Reply #55 on: Sun, 12 July 2015, 14:24:05 »
Will the original files be made available as you had mentioned before?
Offline Matt3o
  • -[起財-
  • ** Robot Emeritus
« Reply #56 on: Sun, 12 July 2015, 16:33:21 »
yes. it's an open source project.
Offline neverused
« Reply #57 on: Sun, 12 July 2015, 16:39:37 »
Awesome! Looking forward to it... Will those be available soon?
Thank you so much for all you do for this community!
Offline Matt3o
  • -[起財-
  • ** Robot Emeritus
« Reply #58 on: Mon, 13 July 2015, 00:57:13 »
Yes, I should have everything ready in a couple of weeks. We are still tweaking the case.
Offline whmeltonjr
« Reply #59 on: Sat, 29 August 2015, 01:36:21 »
Is this still a thing? Looking for a 65% keyboard and like the looks of this one quite a bit.
Offline Matt3o
  • -[起財-
  • ** Robot Emeritus
« Reply #60 on: Sat, 29 August 2015, 03:26:47 »
yes it's still a thing. I'm waiting for the case pre-production sample any day now.
Offline vivalarevoluci鏮
« Reply #61 on: Sat, 29 August 2015, 07:45:20 »
Lol.  This will be a decently big thing.  The world needs more 65%.
Offline neverused
« Reply #62 on: Sat, 29 August 2015, 14:26:31 »
Still waiting on the open source files, can't wait!
Offline jd29
« Reply #63 on: Sat, 29 August 2015, 15:38:03 »
Those aluminum "custom Koreans" got nothing on this. It really makes me question if Cherry profile was the right choice for my board.
10/10, awesome board, especially in granite.
Offline whmeltonjr
« Reply #64 on: Sat, 29 August 2015, 22:02:17 »
Any chance you have a ballpark price on it?
Offline Matt3o
  • -[起財-
  • ** Robot Emeritus
« Reply #65 on: Sun, 30 August 2015, 08:30:43 »
not yet, but it should cost less than you'd expect :)
Offline Frigid
« Reply #66 on: Sun, 30 August 2015, 14:09:01 »
Can you link me to where you learned about that pcb making process? Or just a quick crash course so I can learn on my own?
Offline Eszett
« Reply #67 on: Sun, 30 August 2015, 14:50:19 »
Hm, how did you made the screws sink in the steel plate that far to be flush with the top surface?
Offline neverused
« Reply #68 on: Sun, 30 August 2015, 14:53:02 »
Use a countersink bit.
Offline Eszett
« Reply #69 on: Sun, 30 August 2015, 14:58:04 »
But a countersink screw won't sink in steel that far without any further preparation. I'd like to know: which preparation?
« Last Edit: Sun, 30 August 2015, 15:01:43 by Eszett »
Offline neverused
« Reply #70 on: Sun, 30 August 2015, 15:00:18 »
That is the preparation. You use a countersink bit to create the countersink for the screw.
Offline Eszett
« Reply #71 on: Sun, 30 August 2015, 15:02:34 »
But there is no thread left when you use an countersink bit to widen the hole of a 1.5mm (!) steel plate. There will be just a huge hole.
Offline neverused
« Reply #72 on: Sun, 30 August 2015, 15:07:10 »
Screw into the spacer below
 See the photo from the OP:
Offline Eszett
« Reply #73 on: Sun, 30 August 2015, 15:09:27 »
So there is no thread left in the steel plate?
« Last Edit: Sun, 30 August 2015, 15:40:36 by Eszett »
« Reply #74 on: Sun, 30 August 2015, 15:43:31 »
That sounds enticing.
Offline Matt3o
  • -[起財-
  • ** Robot Emeritus
« Reply #75 on: Sun, 30 August 2015, 17:06:53 »
the top plate has no threading. no need to.
Offline Eszett
« Reply #76 on: Sun, 30 August 2015, 18:01:50 »
Matt3o, alright, and did you use a countersink bit of 90� or 120�?
Offline neverused
« Reply #77 on: Sun, 30 August 2015, 18:04:16 »
My guess is 120 since 90 might be too aggressive of an angle for that thin of a plate.
Offline Eszett
« Reply #78 on: Sun, 30 August 2015, 18:13:38 »
Maybe, neverused. But I'm in doubt, whether a 90� M3 flat head screw sink that deep in a hole made with a 120� countersink.
« Last Edit: Sun, 30 August 2015, 19:41:37 by Eszett »
Offline i3oilermaker
  • techkeys.us
    • TechKeys
« Reply #79 on: Sun, 30 August 2015, 23:13:53 »
My dream board is this plus a tenkey tacked on the end
Love the concept - count me in.
Offline whmeltonjr
« Reply #80 on: Wed, 23 September 2015, 08:22:49 »
I noticed on Deskthority this is ready to go. Will the group buy be run through there only?
Offline neverused
« Reply #81 on: Wed, 23 September 2015, 08:56:16 »
Still hoping to see the files made available as open source
Offline Matt3o
  • -[起財-
  • ** Robot Emeritus
« Reply #82 on: Wed, 23 September 2015, 10:21:19 »
Not finished yet but...
Offline neverused
« Reply #83 on: Wed, 23 September 2015, 10:23:13 »
Oh that's nice
Offline azhdar
  • Praise the AZERTY god
« Reply #84 on: Wed, 23 September 2015, 10:24:53 »
That is nice mr Matt3o.
Azerty Propagandiste
Offline neverused
« Reply #85 on: Wed, 23 September 2015, 10:51:37 »
Just noticed that this is usb micro. Finally someone is doing it right and not using that God awful mini usb.
Offline whmeltonjr
« Reply #86 on: Wed, 23 September 2015, 11:13:15 »
I'm sold. Have a price yet?
Offline mashby
  • What Up Shoney? (ツ)_/�
    • Mashby
« Reply #87 on: Fri, 25 September 2015, 16:37:12 »
Wow, that is c l e a n !
Offline Norman_the_Owl
« Reply #88 on: Fri, 25 September 2015, 18:31:41 »
This might be a bit off topic, but..
How did you make that original PCB?
Is that just the toner onto copper board method? If not, is there a guide you followed (or made, knowing you) to whatever you did?
Offline ccc24
  • HHKB , Ergodox
« Reply #89 on: Sat, 17 October 2015, 20:08:40 »
Any quotes on pricing yet? I plan on buying some PCB receptacles for hot swappable..you think this could be feasible with your PCB? Something like these https://www.digikey.com/product-detail/en/0305-2-15-15-47-27-10-0/ED90333-ND/1801940
« Last Edit: Sat, 17 October 2015, 20:12:27 by ccc24 »
Offline zlittell
    • My Projects
« Reply #90 on: Sun, 18 October 2015, 13:18:48 »
Can you link where you purchased those 2mm inserts.  Thats exactly what I am looking for and had to figure out a different way of doing things because I couldn't source them.
Offline ccc24
  • HHKB , Ergodox
« Reply #91 on: Sun, 18 October 2015, 13:52:20 »
Oh sorry I meant Matt3o's 2mm inserts for attaching the PCB.
ahh ok lol
« Last Edit: Sun, 18 October 2015, 16:02:07 by ccc24 »
Offline zlittell
    • My Projects
« Reply #92 on: Sun, 18 October 2015, 15:17:38 »
Offline blueangel2323
« Reply #93 on: Mon, 19 October 2015, 00:15:25 »
Amazing work! How did you do the green treatment on a DIY PCB?
Offline b4d_tR1p
« Reply #94 on: Thu, 22 October 2015, 09:10:37 »
Oh that's nice
very nice mate, I want one too  :D!
-----BEGIN GEEK CODE BLOCK-----
Version: 3.1
GCS/CC d-(--)>---x s:-(--)>--- a C++++(++++)>++ UBLC++++(+++)$>++ P++ L+++++(+++++)>+++++ E---(---)>--- W+++(+++)>+++ N+++ o++ K-- w O M++ !V- PS+++(+++)>+++ PE+++(+++)>+++ Y+++(+++)>+++ PGP++ t+ 5 X+ R tv- b++ DI++++ D+++ G++++ e+++ h- r++ y+++
------END GEEK CODE BLOCK------
« Reply #95 on: Thu, 22 October 2015, 20:43:15 »
Solder mask, a bunch of diy tutorials on YouTube. Relatively simple, depending on how you do it
Offline trenzafeeds
  • **** off
« Reply #96 on: Fri, 23 October 2015, 06:24:58 »
I would love to see the full CAD files, this is a really cool project. Reminds me of a KMAC Mini without the FN row.
demik will never leave.
Unless he gets banned.
Offline ccc24
  • HHKB , Ergodox
« Reply #97 on: Sun, 08 November 2015, 17:51:46 »
any updates on a GB yet?
Offline whmeltonjr
« Reply #98 on: Sun, 08 November 2015, 17:54:18 »
On deskthority he said he was still waiting on some stuff to get fixed to his liking. Christmas time was the last given timeframe.
Offline neverused
« Reply #99 on: Sun, 08 November 2015, 17:54:25 »
Emphasis on ish
