Author Topic: Comfort Keyboard - Ergonomic Keyboard  (Read 15479 times)
Offline iggysaps
« on: Thu, 14 May 2009, 23:56:00 »
One of the hardest things to find is an ergonomic/mechanical switch keyboard.    I have been looking all over and the only ones that I know of are the ones that kinesis makes which has brown cherry switches, the cherry ergoplus which can no longer be bought brand new, and the northgate omnikey.
I was wondering about what key switches this  Comport Keyboard uses...it's description is: Key Switches: Conductive elastomer rubber designed for 60 million cycles
I tried researching conductive elastomer rubber switches but couldn't find much info on it.
Anybody ever try this keyboard or know about that particular switch?  It's specs/description can be found here http://www.comfortkeyboard.com/keyboards_comfort.html
Cherry G84-4100 cherry ML switches
Cherry G80-3000 blue cherries
Dell AT101W (2)
Solidtek ASK-6600
Unicomp Spacesaver buckling spring
Key tronic designer P2
Offline kyamei
« Reply #1 on: Fri, 15 May 2009, 00:28:11 »
Sounds like a fancy way of saying rubber dome to me.  I do remember seeing rubber domes being called "conductive rubber" before.
Topre:  Realforce 101, Realforce 87U, HHKB Pro 2
Cherry Brown:  Compaq MX11800
Cherry Blue:  Filco FKBN87MC/EB
Cherry Black:  K-202 numerical keypad
Alps Black:  AT101W, ABS M1
Alps White:  Focus FK-2001
Buckling Springs:  Model M 1391401, Lexmark Model M 82G2383, Model M2
Buckling Sleeves:  Unicomp Model M4
Futaba:  Sejin EAT-1010
Offline MsKeyboard
switch info
« Reply #2 on: Fri, 15 May 2009, 11:24:20 »
The comfort uses a membrane switch that also incorporates a mechanical setup affixed to the bottom of the key, giving it a "clicky" feel. Specs for comfort boards here
http://www.fentek-ind.com/Comfort-keyboard.htm
Hope that Helps
Ms Keyboard
Offline lowpoly
« Reply #3 on: Fri, 15 May 2009, 11:32:35 »
Conductive rubber usually is like the chiclet key switch. The rubber dome contains a small piece of conductive rubber that is pressed on a pcb instead of a membrane and connects the circuit paths there.
Offline naveed
« Reply #4 on: Thu, 18 June 2009, 11:36:05 »
I used to have one of these and it has a horribly mushy feel.
Offline IBI
« Reply #5 on: Thu, 18 June 2009, 15:17:31 »
Quote from: iggysaps;90986
Plus the IBM M15, Marquadt mini ergo, Apple Adjustable Keyboard and Maltron's range.
Owned: Raptor-Gaming K1 (linear MX)(Broken), IBM Model M UK, Dell AT102W, Left-handed keyboard with Type 1 Simplified Alps.
Offline wheel83
« Reply #6 on: Thu, 18 June 2009, 18:05:13 »
I owned a northgate omnikey and I still own a PC Innovation KB7000 or something.  both white alps, but i didnt like the backspace/enter layout.
I <3 BS
