Author Topic: DUCK's Inventory of Korean Custom Keyboard Sets FOR SALE [ CLOSED ]  (Read 71706 times)
Offline StylinGreymon
  • Keyboard Hipstar
Re: DUCK's Inventory of Korean Custom Keyboard Sets FOR SALE
« Reply #150 on: Fri, 29 August 2014, 16:06:09 »
So I got my Light Pad a few days ago (sent it to tjcaustin for assembly), and it looks great, but I am having a devil of a time trying to program it  :confused:
I don't run Windows at all, which means I have to try all sorts of workarounds, none of which are working!
Looks like I'll have to borrow a friend's machine.
It's a sad state of affairs, I know, but you definitely should seek out a Windows box.  It makes everything so much easier.
Or find an old copy of windows and install it in a VM. That's what I'm planning on doing.
I can't get flip to do its thing in a VM.
I'm not sure if it's because of a driver issue.
Whenever I press the flip key, and plug the key pad in in order to flash it, nothing happens, and the key pad is unresponsive until I unplug it.
If today had been a hippo, then you'd really have to worry about tomorrow.
Offline Crabby_b
« Reply #151 on: Sat, 30 August 2014, 12:10:51 »
Are you using virtualbox? If so you will need to create a usb filter for it so that the proper driver can be installed. Otherwise it will just use the generic usb keyboard driver and you won''t be able to program it.
  • Keyboard Hipstar
« Reply #152 on: Sat, 30 August 2014, 13:24:45 »
Alright, do I need to install the driver manually?
The guide I have doesn't specify, but after creating the filter, no new drivers have been automatically installed.
EDIT: Got it up and running!
Thanks, Crabby!
« Last Edit: Sat, 30 August 2014, 14:27:36 by StylinGreymon »
  • Keyboard Hipstar
« Reply #153 on: Mon, 01 September 2014, 02:19:38 »
Can't get arrow keys or macros running, no matter what software version I'm using.
Doesn't seem like anyone else can, either :/
Offline ComradeSniper
  • HHKB Pro
« Reply #154 on: Wed, 03 September 2014, 22:36:03 »
I couldn't resist, put in an order for a lightpad.
Offline exitfire401
  • The Force is Re/\l
« Reply #155 on: Fri, 05 September 2014, 09:34:05 »
Finally ordered! So excited!
Offline elton5354
« Reply #156 on: Fri, 05 September 2014, 09:41:39 »
I haven't really checked this in a while. I'll invoice those still interested.
These will be shipped together with Duck Viper Eagle group buy though, so probably around mid to end of September.
  • HHKB Pro
« Reply #157 on: Fri, 05 September 2014, 13:14:02 »
Does that mean I could combine shipping with my viper order?
Offline elton5354
« Reply #158 on: Fri, 05 September 2014, 15:20:50 »
I think there's 3 sets that's shipping to Hoff's address in the same box.  I think it can fit a Light Pad as well..
Offline exitfire401
« Reply #159 on: Fri, 05 September 2014, 18:14:06 »
When should i expect the email with further instructions? Not trying to be pushy, just want to get my payment done and out of the way.
  • HHKB Pro
« Reply #160 on: Fri, 05 September 2014, 21:05:29 »
Sweet!
« Reply #161 on: Fri, 05 September 2014, 21:06:45 »
Man I wish I could buy just a pcb and plate... :*( Anyone want a Duck mini Case if I get it?
Offline xandr
« Reply #162 on: Sun, 07 September 2014, 03:58:46 »
I'm a bit short on cash at the moment, but I'd be very much interested in another DuckMini v2 case without the pcb and plate.
Sprit 60% w/MX Clear in DuckMini V2 case | Matias Quiet Pro (office)
Offline echo0
« Reply #163 on: Sun, 07 September 2014, 12:12:45 »
Put in an order.
« Reply #164 on: Sun, 07 September 2014, 12:35:26 »
Cool Ill think about it but I also am short on cash right now. Hence why Im looking for just a PCB for cheap. Thank You,
Offline echo0
« Reply #165 on: Sun, 07 September 2014, 21:55:16 »
Invoice received and paid.  Thanks...   :thumb:
  • HHKB Pro
« Reply #166 on: Sun, 07 September 2014, 23:00:30 »
Paid here also.
Offline elton5354
Re: DUCK's Inventory of Korean Custom Keyboard Sets FOR SALE [ CLOSED ]
« Reply #167 on: Tue, 23 September 2014, 18:07:12 »
The orders are shipped. Awaiting tracking#s.
Offline exitfire401
« Reply #168 on: Tue, 23 September 2014, 18:10:37 »
good to hear! Thanks for the update
