Author Topic: 55g HHKB2 Mod  (Read 3045 times)
Offline mrelectric
55g HHKB2 Mod
« on: Tue, 24 June 2014, 06:21:59 »
Yo guys,
I've decided to keep my HHKB2 because the I really like the layout but is there any way of modding the HHKB2 to increase the weight? Are there any springs or anything like that I can buy?
Thanks in advance
Offline Latin00032
Re: 55g HHKB2 Mod
« Reply #1 on: Tue, 24 June 2014, 06:25:35 »
I think most people use a Real Force 55g tkl to harvest the domes.
I don't think you can just use the springs.
Offline mrelectric
Re: 55g HHKB2 Mod
« Reply #2 on: Tue, 24 June 2014, 06:27:36 »
Ugh, guess i'll just have to stick to using the 45g domes then, they're just way tooooo light, can't feel the rubber goodness.
Offline Latin00032
Re: 55g HHKB2 Mod
« Reply #3 on: Tue, 24 June 2014, 06:32:57 »
I modded my leopold fc660c with the 55g domes.
It does feel nice. It feels more tactile.
I had to remove an extra spring out of the spacebar though. I didn't know it was there till I put the 55g domes.
Offline mrelectric
Re: 55g HHKB2 Mod
« Reply #4 on: Tue, 24 June 2014, 06:35:52 »
Is it hard to do?
Offline Latin00032
Re: 55g HHKB2 Mod
« Reply #5 on: Tue, 24 June 2014, 06:41:29 »
I kind of winged it. There might be a standard way to do it, though.
I just took both cases apart. Unscrewed the support screws on both cases. Then swapped the domes. I didn't swap the springs. The springs are the same weight.
I had to manually aim on where the domes should align when swapping domes. That was the hard part. I don't know if there is an easier way.
It took about 3 hours to do at max.
Offline Smasher816
  • HHKB Master
Re: 55g HHKB2 Mod
« Reply #6 on: Tue, 24 June 2014, 15:07:54 »
If you keep the hhkb upside-down then you can just lay the domes in the top of the case. Should keep everything aligned for you.
Offline exitfire401
  • The Force is Re/\l
Re: 55g HHKB2 Mod
« Reply #7 on: Tue, 24 June 2014, 15:11:56 »
This is the proper way to do it. It insures that everything is lined up properly and that you won't be putting any screws through that precious cup rubber. It's not hard to do at all and only took me a little over an hours because I did it the wrong way first.
Offline probablypat
Re: 55g HHKB2 Mod
« Reply #8 on: Tue, 24 June 2014, 16:48:46 »
Hey guy!
I know the RF is expensive, but if you can get your hands on one it's totally worth it.
https://medium.com/@probablypat/keyboard-of-smiting-ed61dee89efd
Offline Latin00032
Re: 55g HHKB2 Mod
« Reply #9 on: Tue, 24 June 2014, 18:31:33 »
Hey guy!
Is this your article? Good read.
I modded my fc660c to 55g.
Feels great!
Re: 55g HHKB2 Mod
« Reply #10 on: Tue, 24 June 2014, 19:20:56 »
Hey guy!
Excellent article!
Offline Lammie
Re: 55g HHKB2 Mod
« Reply #11 on: Sat, 28 June 2014, 13:10:47 »
Great! Thanks!
Topre Realforce 55g
Topre Leopold FC660C 45g
Matias Quiet Pro Mini
Cherry ML G84-4100LPAUS
Cherry MX Green QFTK
Model M Unicomp 103
