Author Topic: Model F-122 Spacebar wire tab jam help  (Read 1999 times)
Offline Pacifist
  • on hiatus
« on: Tue, 24 June 2014, 16:28:05 »
I'm trying to get the stab on my f-122 to work, but its not. M-122 and F-122 spacebar doesn't function correctly on the F.
The problem I think is the wire goes into the tab, but when I press down, it doesn't go further into the tab, resulting in the wire bending instead of turning and more force required to push down the spacebar. Pulling the tabs up didn't do anything.
Is there any way of fixing this? Would removing the tops of the tabs work or some other method?
Offline Pacifist
  • on hiatus
Re: Model F-122 Spacebar wire tab jam help
« Reply #1 on: Tue, 24 June 2014, 17:56:27 »
ended up just jerry rigging a new stab out of twist ties. It works well enough
« Reply #2 on: Tue, 24 June 2014, 18:08:17 »
If you are trying to use a Model M spacebar, the bar size is the same but the wire is much fatter.
I have made new tabs out of bent sheet metal, epoxied down, and used the M spacebar. I removed the original tabs because they ended up in the way.
Wcass has a much more elegant method where sleeves fit into the M spacebar wire holders but an F-thickness wire goes into the tabs.
- D Trump 2026-10-24
Offline Pacifist
  • on hiatus
« Reply #3 on: Tue, 24 June 2014, 18:11:06 »
That may be the reason. Seller sold me the F-122 condition as seller refurbed, and it looks like it has M-122 keys instead of F-122 keys.
I have one of wcass's spacebar wires, is that way better than making my own tab?
edit: wcass spacebar is most amazing thing ever
« Last Edit: Tue, 24 June 2014, 18:15:03 by Pacifist »
« Reply #4 on: Tue, 24 June 2014, 21:02:12 »
just about. I had an early version that had some fitment issues, but after he got it worked out, it's amazing!
