Author Topic: [IC] - Copper and Brass plates  (Read 5338 times)
Offline The_Beast
  • I like wood ಠ_๏
« on: Wed, 25 June 2014, 19:18:58 »
Any interest in CNC milled copper or brass plates?
I already talked to my laser guy, but he said it's a no go for laser cutting copper or brass, so they'd have the be CNC milled. It just so happens that I now have access to a CNC mill. Since they're CNCed, I more than likely won't do removedable switch top cutouts (square cutouts with a round mill is imposable without a secondary process), , but I should be able to thicker plates.
Price isn't known since I don't have a time estimate on plates and I'm not sure exactly how they plate would be held during machining.
Re: [IC] - Copper and Brass plates
« Reply #1 on: Wed, 25 June 2014, 19:20:46 »
What kind of price are we looking at for say a 60%?
Offline mashby
  • What Up Shoney? (ツ)_/¯
    • Mashby
« Reply #2 on: Wed, 25 June 2014, 19:23:04 »
A copper epsilon and a poker plate would be awesome.
Offline The_Beast
  • I like wood ಠ_๏
« Reply #3 on: Wed, 25 June 2014, 19:24:27 »
Price isn't known. This is going to require tooling and maybe a specialized hold down system.
Offline AKmalamute
  • HHKB Scrub
« Reply #4 on: Wed, 25 June 2014, 19:31:49 »
I think I'm broke. Drooling, but broke.
And yes, for any who have a poker case with brass suit-cutouts, having a brass plate would be a nice touch.
HHKB-lite2, Dvorak user
Offline yicaoyimu
« Reply #5 on: Wed, 25 June 2014, 19:41:21 »
This sounds like a very interesting idea. Very interested.
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
« Reply #6 on: Wed, 25 June 2014, 19:56:18 »
Rough estimate, over or under $100?
Offline The_Beast
  • I like wood ಠ_๏
« Reply #7 on: Wed, 25 June 2014, 20:38:09 »
More than likely, but I can't be certain until I find out programing and machine time. Even if it's right at $100, it would still be WAY cheaper than CNCed plates from a machine shop.
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #8 on: Wed, 25 June 2014, 21:02:29 »
you had my curiosity, but now you have my attention
Offline geniekid
« Reply #9 on: Wed, 25 June 2014, 21:16:33 »
Are there material advantages of brass over aluminum/stainless steel?
Offline MrChunky
« Reply #10 on: Thu, 26 June 2014, 00:38:37 »
Brass would be significantly heavier. Copper is also quite soft. As for tortion properties, I would say aluminium is the weakest one (considering high grade alloys are not used), as for brass, steel and titanium, they are all very stiff so no palpable differences there I would say. I am not sure what other stuff matters?
Offline okwchin
« Reply #11 on: Thu, 26 June 2014, 08:53:39 »
I would on the other hand, be concerned about the practical implications of copper from a strength point of view. Unless you have a significant thickness, you will have a thick and heavy plate, but cannot expect to much from it strength wise. It will help over no plate, but it is not as ideal structurally. Its malleability is also a concern.
Brass on the other hand would be better. It will still give you a degree of patina (if you handle it a lot before installation) and has a degree of strength that is usable.
SS, Steel and Ti plates will still be your strongest options, but Al and Brass would be good too. Personally I dislike the oxidative nature of brass, but do enjoy working with it.
« Last Edit: Thu, 26 June 2014, 08:55:35 by okwchin »
Offline The_Beast
  • I like wood ಠ_๏
« Reply #12 on: Fri, 27 June 2014, 18:27:19 »
In this application, I don't really thing strength plays a huge part
Anyways, this would mostly be for people who want something unique or one off. How many brass or copper plates have you seen?
Offline okwchin
« Reply #13 on: Fri, 27 June 2014, 21:58:22 »
Copper (and brass) is certainly going to achieve the unique factor :) And i guess to put it into perspective, plate mounted switches are certainly strong enough by themselves, therefore I can agree that strength is not a primary concern.
