Author Topic: Linear Alps for Gaming  (Read 4987 times)
Offline vivalarevolución
« on: Thu, 26 June 2014, 06:52:39 »
Excuse me if this topic has already been discussed, but has anybody used Linear Alps switches for gaming?  What was it like compared to linear Cherry switches?
If Matias came out with a linear board, would you buy it?
Offline remdell
Re: Linear Alps for Gaming
« Reply #1 on: Thu, 26 June 2014, 09:09:30 »
I use to game a lot on complicated yellow linear Alps, particularly on a Zenith ZKB-2R.  Linear Alps actually work quite well for gaming.  I find them much more smoother than my lubed Cherry reds.  I actually game on both linear Cherry switches and Topre, so best I can describe linear Alps switches for gaming is like if Topre made linear switches.  Typing on Topre, for me anyway, felt like there was a magnet pulling the keys down after actuation.  The feeling is very 'glidey' and smooth.  Linear Alps is very similar in that regard in that it feels like there is a magnet pulling the keys down as your fingers lay and depress on them.  I played mostly FPS, MMOs, and action RPGs on the Zentih.  They all worked well.  I wish I could tell you how it works on League of Legends, but I've yet to try playing League of Legends on it.  I should probably game on this keyboard now, so I could give a better analysis after using so many other mechanical keyboards, but for now I'm just going to give you the impressions I felt when using it in the past.
I should note that the Zenith was around my third or so mechanical keyboard next to a Cherry G80 and a Dell AT101W.  I absolutely hated the lightness of the G80's switches (MX browns) after moving from scissor switches.  I kept making typos and pressing unwanted keys in games.  However, I rarely made typos on the Zenith because of it's weighty keys, slightly larger spacing, and lower profile.  The smoothness of the keys were what really opened my eyes to typing on more keyboards.  After using the Zenith for a few months, every single key of the mechs I've tried after just felt way heavier.  I made much less typos on my G80, and I made virtually no typos on my plate-mounted Cherry brown boards.  However, I still didn't make the switch to Cherry for gaming until I tried lubed reds and blacks.
Coming back to Zeniths (both green and yellow linear Alps) every now and then, I still find linear Alps to be a great typing experience.   I usually stick to my lubed Cherry reds (55g) and 45g Topre, but I like to bring out my other boards (the Zenith being no exception) to type on every now then.  The Zenith has a unique key profile, but I've grown accustomed to Cherry profile keys.  I've also grown accustomed to using only tenkeyless and 60% boards.  Really it's just the profile and size of the Zenith that's holding me back from using it again for gaming.
If Matias made a switch similar to yellow or green linear Alps, I'd probably buy them.  I haven't had the time or money to create a 60% linear Alps board, and I know Matias would probably feature a compact sized linear switch board if they were to create a linear Matias switch.
« Last Edit: Thu, 26 June 2014, 09:14:29 by remdell »
Rukia PC | RF87U Digilog | Norbaforce MKII Palm Desert | Zenith ZKB-2R | Datadesk MAC-101
Offline Defect
« Reply #2 on: Thu, 26 June 2014, 09:53:49 »
My issue with Alps is that there is no after market support for customization.   Linear stock MX is good, linear MX with spring mod (68g or Clear Spring) is amazing.
With alps...All I could do is steal springs from Matias switches.
Your use of Alps in gaming is more likely limited to whether the boards have 6kro or NKRO support.
« Reply #3 on: Thu, 26 June 2014, 10:26:39 »
Linear green alps on my Kingsaver was one of my favorite gaming experiences. The travel is slightly less than mx and the actuation is higher up so I feel like I had faster reactions. And they're really smooth so it's a lot of fun to mash.
Yes I'd buy linear matias alps.
Offline digi
  • elite af tbh
  • keyboard game on fleek
« Reply #4 on: Thu, 26 June 2014, 10:45:52 »
I really need to try that Kingsaver with Green Alps, that sounds like a wonderful combo.
« Reply #5 on: Thu, 26 June 2014, 13:06:05 »
Is that the Kingsaver that now had Blue Alps, or do you have two Kingsavers?
« Reply #6 on: Thu, 26 June 2014, 19:12:09 »
Really surprised that not more people have used Alps for gaming.
Offline jacobolus
« Reply #7 on: Thu, 26 June 2014, 19:38:36 »
I don’t really play computer games, but I imagine that green Alps would be very nice for it. They’re smoother than “vintage” MX black switches, a nice switch weight somewhere in between MX red and MX black, and a slightly higher up actuation point. If you added a buzzer or solenoid for a slight bit of audio-tacile feedback, I can imagine them being very good for quickly and precisely pressing keys.
If you really want to get fancy, there are also some Alps linear double-acting keys, with an extra actuation at the bottom if you press hard, which I can imagine being put to some creative uses by game players.
« Reply #8 on: Thu, 26 June 2014, 20:12:29 »
I like linear ALPS for gaming
it's nice
« Reply #9 on: Sun, 29 June 2014, 10:37:27 »
Originally my Kingsaver had linear green alps. I used them for two or three weeks before swapping the board to blue alps. Now I'm putting those linear green alps that I removed from the Kingsaver into my filco zero.
« Reply #10 on: Sun, 29 June 2014, 10:49:46 »
Cool, that will make for a nice Alps gaming board.
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #11 on: Sun, 29 June 2014, 13:54:13 »
pictures plz when u b done ;D
sounds great
Luga G80-1865/MX Reds + Dolch G80-1813/MX Blues + G80-3700HQAUS + DK9008G2 Pro/MX Browns Thick PBT + DK9008G2 Pro/MX Clears Thick PBT +  QFR TKL/Ghetto Greens + Cherry G80-1800/MX Blues + IBM Model M SSK Bolt Modded + IBM Model M + IBM Model F + IBM AT F + Cherry G80-1000 (HAD)/MX Vintage Blacks + Razer BWU/MX Blues + Leading Edge DC2214/Blue Alps + Compaq MX11800/Browns + Chicony 5181/Monterey Blues + Chicony 5161/MX Black Cherry Clone + Focus 2001/White Alps + Chicony 5191/White Futabas + Olivetti ANK27-101 + Dell (Old Logo) AT101/Black Alps + NMB RT8255C+/Black Space Invaders + Unitek K260/Green Alps + Apple M0116/Orange Alps + AEK II M3501/Cream Alps + AEK M0115/Orange Alps + NEC  APC412/Blue Sliders + NEC APC410/Blue Sliders + Omnikey /White Alps + Wang/Yellow Alps (Omrons) + Laser/White SMK + Fame/Blue Aruz + AEK II M3501/Salmon Alps + Zenith ZKB-2R/Green Alps + Wang 724/Orange Alps + DK1087/Green Alps + Zenith ZKB-2/Yellow Alps + Dell Old Logo AT101/Salmon-Pink Alps + Leading Edge AK1012/White SMK's + Magitronic SK-1030/White (Linear) Futaba's + Packard Bell/White (Clicky) Futaba's + Datacomp DFK101/White  Alps + SGI AT101/Dampened White Alps + NMB AQ6RT-72511/Grey Space Invaders (Hi-Tek) + Datacomp/Blue Alps + Phillips 2812/White Space Invaders (Linear) + Dah Yang K251/Vintage MX Blues + Chicony 5161/DS Caps/Vintage MX Blue + Archie-NMB AQ659ZRT-725/Black Space Invader (Tactile) + IBM Model M 71G4644 (RD) Bolt Modded with Soarers Converter + IBM Model M Silver Label 1390131 + Cherry G80-1501/Vintage MX Clears + Focus FK8000/Linear Futabas + Gateway 2000 Anykey Programmable/Maxi-Switch + Dell GY13PVAT101/Dye Sub Caps/Salmon Alps + Chicony 5161/White Alps + AST K0B101/Slider over RD + Qtronix QX-32H + Everex/NMB RT8255CW+ Black Space Invaders-Split Erase + Tandon/NMB AQ659ZRT-101A/Beige Space Invaders + Cherry G80-11903 MNRUS/MX Blacks + Apple IIGS A9M0330/SMK Whites + WYSE PCE/MX Blacks + Chicony 5160AXT/Clicky Futaba + Cherry G80-0528/Vintage MX Blacks + Dell AT101/Linear (Modded) Black Alps+Topre 55g
Offline False_Dmitry_II
« Reply #12 on: Sun, 29 June 2014, 18:39:28 »
Maybe, but two years ago there were no aftermarket springs for cherry either. People were getting POS with browns, and POS with clears and making ergo clears that way, which made them expensive.
I game just fine on anything I rotate through, and that now includes my dell with matias clicky.
Offline jacobolus
« Reply #13 on: Sun, 29 June 2014, 23:09:20 »
I really need to measure and spec out all the various existing Alps SKCL/SKCM springs (and Matias springs), so that we have an idea what kind of length and stiffness to look for. Then it would be really great to figure out a supplier to buy aftermarket springs from, possibly in a few varieties.
When you swap in the click/tactile leaves from Matias switches, plus an aftermarket spring, you can take most types of complicated Alps switch (white, black, salmon, whatever), even really worn out ones, and make it into something pretty nice (or e.g. nice linear switches out of any of the tactile/clicky kind).
« Reply #14 on: Mon, 30 June 2014, 01:59:52 »
I imagine modding them to be linear would be the easiest way to make really worn out switches fairly nice, well, if you like linear anyway. Also, besides the adding instability stuff.
