Author Topic: Unicomp and IBM parts interchangeability  (Read 1313 times)
Offline Muh Fugen
« on: Sun, 29 June 2014, 19:40:47 »
Is it possible to use replacement Unicomp pivot plate & spring assembly (part# PVPLASM) and replacement pointing stick caps (part# 49G2224) on a IBM model M-13 keyboard (part# 13H6705, manufactured by Maxi-Switch in 1998)?
« Last Edit: Sun, 29 June 2014, 19:42:29 by Muh Fugen »
Offline JPG
  • Model F is my new passion!
Re: Unicomp and IBM parts interchangeability
« Reply #1 on: Sun, 29 June 2014, 19:45:13 »
http://pckeyboard.com/page/category/Misc
There you go, they have both and should be compatible as far as I know
Offline E TwentyNine
    • Some of My Keyboards
« Reply #2 on: Sun, 29 June 2014, 20:00:06 »
Pivot plates definitely.  Pointer caps possibly are, but if not they likely carry both styles.  Email them, they'll tell you.
