Author Topic: Has anybody tried stuffing foam between the switches?  (Read 2403 times)
Offline Pacifist
  • on hiatus
« on: Mon, 30 June 2014, 22:10:16 »
I know that somebody used expanding foam on their filco (which turned out really messy) but has anybody tried to put foam between the switches? Maybe foam backer rods in small diameters just piled between the switches before soldering?
Maybe in combination with shelf liner behind the PCB, sound can be reduced a lot
Offline Flamingchook
  • There are no dumb questions, only forbidden ones.
Re: Has anybody tried stuffing foam between the switches?
« Reply #1 on: Mon, 30 June 2014, 22:44:01 »
I've thought about it. I am planning on getting a foam or rubber sheet and punching square holes in it for the switches and placing it between the pate and the PCB. I'm waiting for the universal plate GB before I do anything though.
Edit: for my Filco. If it works OK I'll probably do the same for my GH60s.
« Last Edit: Mon, 30 June 2014, 22:45:40 by Flamingchook »
MX: Filco Majestouch Metalic Blue 104-key w/ MX Brown, JD40 w/ MX Green, ErgoDox w/ MX Blue, GHPad w/ MX Blue. Topre: Realforce 87U 45g. BS: IBM Model M 52G9700 29-OCT-93
Soon™: GH60 w/ 62g MX Clear, [CTRL]ALT 60 w/ MX Green
Offline Pacifist
  • on hiatus
« Reply #2 on: Mon, 30 June 2014, 22:45:46 »
That's a good idea, but quite a lot of layering.
« Reply #3 on: Mon, 30 June 2014, 22:48:17 »
Not if I can get a thick enough sheet. I've got a shop nearby that specialises in rubber and foam so I'll have to have a look at what they've got.
Offline Pacifist
  • on hiatus
« Reply #4 on: Mon, 30 June 2014, 22:50:13 »
Oooo that sounds good.
