Author Topic: Where can I buy authentic Cheery MX switches down Australia?  (Read 1998 times)
Offline njfn
« on: Tue, 01 July 2014, 01:22:00 »
Looking for some Cheery MX Blue (80pcs), White(10pcs) and Green(10pcs) switches.
At the moment, I can only find them on eBay, but are from HK or China, which seems to be a bit expensive if buy these in bulk.
I found there are some cheaper ones on Taobao, but the seller doesn't do international shipping.
Any chance I can buy some switches locally?
Alienware 14 i7-4900MQ/16GB/256SSD+750HDD/1920*1080
MacBook Pro 15' i7-2.3G/16GB/512GB/NV GT750M/Retina
Logitech G700s / Razer Ouroborous / Logitech MX Revolution
Deck Hassium Pro 108 / KBTalking Pro
Re: Where can I buy authentic Cheery MX switches down Australia?
« Reply #1 on: Tue, 01 July 2014, 01:36:01 »
I haven't seen anywhere selling MX switches down here :(
You'd be hard pressed to find anything with MX green of clear locally, either (although PCCG did have QFS with MX green for a fww weeks).
Best bet is to find a Taobao proxy e.g. qtan.
Offline njfn
« Reply #2 on: Tue, 01 July 2014, 02:14:48 »
thanks rowdy,
it seems Taobao is the only option to get some rare switches. :)
Offline feizor
« Reply #3 on: Tue, 01 July 2014, 02:42:53 »
You can also use mechanicalkeyboards.com
Shipping is $15USD for 100 switches though. Rare switches like clear or green are very expensive on Tao Bao. 6-8RMB each, which is $1.05-$1.25 AUD each + proxy fees + shipping.
Offline njfn
« Reply #4 on: Tue, 01 July 2014, 23:52:24 »
Good point! thanks feizor!
Offline twiddle
    • Portfolio
« Reply #5 on: Wed, 02 July 2014, 00:25:04 »
You can get a very limited range of MX switches (mostly a couple variations on blacks) from www.element14.com.  Just search for MX1 and they'll come up. I considered trying to get something together where if enough of us nag them they might stock some of the other types, perhaps..
Offline feizor
« Reply #6 on: Sat, 05 July 2014, 21:03:06 »
http://au.element14.com/cherry/mx1a-11nn/switch-spno/dp/1180016
You're right twiddle, the mx black switches are pretty cheap on element14.
