Author Topic: extruding 3d printer material into molds  (Read 2327 times)
Offline Pacifist
  • on hiatus
« on: Fri, 04 July 2014, 00:17:20 »
Does anybody know if its possible to extrude plastic such as abs from a 3d printer into a mold to make a keycap? Only issue I see with it is clogging and solidifying before it reaches the bottom
Offline mkawa
  •  No Marketplace Access
  • (ツ)@@@. crankypants
Re: extruding 3d printer material into molds
« Reply #1 on: Fri, 04 July 2014, 00:25:42 »
what you're describing is aka injection molding. filament extruders can't handle this for a number of reasons, but the primary one is that filament deposition mechanics are not built to handle backpressure.
Offline jacobolus
« Reply #2 on: Fri, 04 July 2014, 01:47:34 »
You might find http://www.reddit.com/r/ResinCasting/ useful.
If you want to do injection molding, I think you’ll need some fancy expensive machinery.
Then again, https://www.kickstarter.com/projects/210417487/bench-model-plastic-injection-machine
« Last Edit: Fri, 04 July 2014, 01:49:24 by jacobolus »
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #3 on: Fri, 04 July 2014, 01:55:44 »
great resources thanks! sooner or later I gotta try it
Offline mkawa
« Reply #4 on: Sat, 05 July 2014, 12:03:54 »
there are a couple of "desktop injection molders", but they're basically low pressure casters. actual injection molding needs basically room-sized machinery and extremely high, dangerous pressures.
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #5 on: Sat, 05 July 2014, 12:17:57 »
every time mkawa replies to a thread, a unicorn dies... :P
let us dream, mkawa! :D
