Author Topic: Keycap sits weirdly on keyboard  (Read 3285 times)
Offline asgeirtj
« on: Thu, 10 July 2014, 13:52:14 »
I just bought this set
http://www.originativeco.com/collections/keysets/products/bsp-classic-beige
on a Filco mj2 tkl and the right shift button is very weird.  It's like it doesn't go all the way down and feels very weird.  Do you guys know what could be up?
Leopold FC900 w/ 67g Purple Zealios - Silver Duck Octagon w/ 62 Purple Zealios
Re: Keycap sits weirdly on keyboard
« Reply #1 on: Thu, 10 July 2014, 14:02:35 »
Is your white insert in the wrong way on one of the sides..? Common problem.
Also with bsp caps I believe the inserts are loose so you might need to stick in some tape or tissue to keep it in place.
  • Live long and prosper
« Reply #2 on: Thu, 10 July 2014, 14:03:54 »
Yeah, sounds like a misaligned stabilizer. Remove the cap and realign.
tp thread is tp thread
« Reply #3 on: Thu, 10 July 2014, 15:52:32 »
on some filcos, aftermarket keycaps will rub on the edge of the case. If it's not a stabilizer issue, look at that next.
Offline asgeirtj
« Reply #4 on: Thu, 10 July 2014, 16:37:43 »
The inserts are put on right,  what do i do if it rubs on the edge of the case?
Offline HPE1000
  • Keycap Paparazzo
« Reply #5 on: Thu, 10 July 2014, 16:46:54 »
So it is costar, are the little stabilizer nubs inside of the keycap facing the right way? As in the long side of them points towards the top of the keyboard (F key row)
I don't know if that is what you mean by they are put on right
« Reply #6 on: Thu, 10 July 2014, 16:48:37 »
nothing
i haven't seen a fix for this
i doubt BSP will rub tho
« Reply #7 on: Thu, 10 July 2014, 16:49:22 »
You can sand your case a bit safely.
Offline asgeirtj
« Reply #8 on: Sat, 12 July 2014, 07:55:46 »
I also tried the key on my other Filco and it is the same.
Offline PolaBurrr
« Reply #9 on: Tue, 15 July 2014, 08:55:59 »
DON'T SAND THE CASE! Instead, sand the inside edges of the keycap that lines up to the 2 plastic stabilizer brackets that rest in the plate. When thicker keycaps bottom out, the inside edge hits the plastic bracket at the four points, making it not bottom out properly unless you press harder, then it clicks past and bottoms out. I have experienced this multiple times with thick keycaps with costar stabilizers.
« Last Edit: Tue, 15 July 2014, 08:57:37 by PolaBurrr »
Offline asgeirtj
« Reply #10 on: Sun, 05 October 2014, 18:55:08 »
I now have the same problem with an ABS spacebar, is there somewhere a tutorial on how to sandpaper the insides of the keycap?
Offline Oobly
« Reply #11 on: Mon, 06 October 2014, 04:32:51 »
Sigh.... Costar stabs and thick keycaps.
The best fix: switch to Cherry stabs (clip the tabs if you want to remove the "mushiness"). The other fix, do what PolaBurr said and file the inside of the cap by the stabilisers.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Offline yomammary
« Reply #12 on: Tue, 07 October 2014, 07:03:44 »
Do you know when I could buy some cherry stabs?
RF 87u 55g | Leeku 1800
Offline jonathanyu
« Reply #13 on: Tue, 07 October 2014, 14:07:56 »
I believe is the stabilizer wire rubbing the wall of the caps, this happen to me in the past when I used imsto pbt on my filco
Offline Oobly
« Reply #14 on: Tue, 07 October 2014, 14:48:31 »
What I meant was to switch to a keyboard that has Cherry stabs, you can't swap the stabilisers on most boards between the two types. IvanIvanovich just ran a group buy for Cherry stabs and they're available from a few other places.
Offline yomammary
« Reply #15 on: Wed, 08 October 2014, 07:53:45 »
Guess I'll have to start practicing my filing skills.
