Author Topic: Poker II Mac Command Keys?  (Read 2046 times)
Offline cpt_lucid
« on: Sat, 12 July 2014, 09:03:07 »
I just get my Poker II with dark grey PBT caps in the mail and love it.  Is there any place I can get an Apple command key (either the symbol or "cmd" or "command") in a matching color?
Offline mashby
  • What Up Shoney? (ツ)_/¯
    • Mashby
Re: Poker II Mac Command Keys?
« Reply #1 on: Sat, 12 July 2014, 12:23:54 »
Not a lot of options unfortunately when it comes to Apple keys. To match the key cap profile that you have on your new Poker II (OEM), your best bet will be EliteKeyboards. They have the command key in Blue, Green, Lavender and Red. Bear in mind that these will be ABS and not PBT and pad printed, so they won't match exactly, but they are affordable and easy to buy.
As an Apple user myself, I've found buying custom key cap sets to be the best way to get a set without a "win key". They don't often include a command key, but they'll have something more unique, or generic that will work just as well. You'll find them in the Group Buys section of the site.
Hope that helps!
