Author Topic: AT-layout white space invader board, bidding at $32 shipped  (Read 3189 times)
Offline jacobolus
« on: Wed, 16 July 2014, 13:21:39 »
http://www.ebay.com/itm/161367899757
I asked the seller to pull a cap, and this keyboard apparently uses one-eyed white space invader switches. I’m pretty sure those are the linear kind.
Re: AT-layout white space invader board, bidding at $32 shipped
« Reply #1 on: Wed, 16 July 2014, 13:28:17 »
Mmmm, that AT layout. :)
Offline korrelate
  • iubeo stultum esse libenter
« Reply #2 on: Wed, 16 July 2014, 14:39:39 »
I just read up on this....
http://www.atarimagazines.com/compute/issue86/007_1_IBM_Compatibles.php
Says that Vendex computers were made by Samsung. Doesn't break out the keyboard though... probably farmed out to some other company in NK?
Topre REALFORCE
Offline jacobolus
« Reply #3 on: Wed, 16 July 2014, 15:18:10 »
If it has these Hi-Tek “space invader” switches, then the keyboard was very likely made by NMB. But yeah, Vendex was a New York company, and the computers were made by Samsung.
« Reply #4 on: Wed, 16 July 2014, 19:37:43 »
You and I both asked apparently.  He just got back to me on it as well, asking for any info I might have on it.  He had another interesting looking old board, but said that no caps came off and there were no identifiers: http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=151356362605&ssPageName=ADME:X:RTQ:US:1123
Offline jacobolus
« Reply #5 on: Wed, 16 July 2014, 21:26:33 »
You and I both asked apparently.  He just got back to me on it as well, asking for any info I might have on it.  He had another interesting looking old board, but said that no caps came off and there were no identifiers: http://www.ebay.com/itm/151356362605
I'm at least 90% sure that that’s green alps with dye-sub PBT keycaps. It looks identical to the later Zenith version, except for the little logo plate.
Speaking of Heath keyboards, these are interesting too: http://www.ebay.com/itm/161362824310
Low-profile ITW magnetic valve switches (the seller pulled a cap) http://deskthority.net/wiki/ITW_magnetic_valve
« Last Edit: Wed, 16 July 2014, 21:30:59 by jacobolus »
« Reply #6 on: Wed, 16 July 2014, 23:28:08 »
It could be, but it's some pricey Green Alps.
« Reply #7 on: Fri, 18 July 2014, 16:07:38 »
re-listed:
http://www.ebay.com/itm/151358446369
note that this ITW keyboard is one of the few rubber domes with NKRO.
In such a design the domes are mainly to be tactile as opposed to the linear version with springs.
Offline jacobolus
« Reply #8 on: Fri, 18 July 2014, 17:36:03 »
I wouldn’t really compare that to generic “rubber domes” – it uses a buckling rubber sleeve, but the switch uses a magnet to actuate rather than a membrane, so you don’t need to bottom out the switch for it to actuate.
