Author Topic: NMB Hi-Tek Space Invaders discussion topic  (Read 51260 times)
Offline Daniel Beardsmore
  • RIP
    • Boring twaddle
Re: NMB Hi-Tek Space Invaders discussion topic
« Reply #100 on: Tue, 04 November 2014, 13:40:56 »
I don't remember everything. If you guys would bother putting all this on the wiki we'd have somewhere reliable to look it all up instead of having to revert to Google in the hope we might be able to find something.
Bore Awards
« Reply #101 on: Tue, 04 November 2014, 13:59:35 »
if I can figure out how to get pictures up on the wiki, I'll be adding all the info on that new arabic unitek dah-yeng) KB
  • RIP
    • Boring twaddle
« Reply #102 on: Tue, 04 November 2014, 16:22:34 »
Bore Awards
Offline jacobolus
« Reply #103 on: Mon, 10 November 2014, 14:22:16 »
Got a keyboard with “Gundam” style linear space invaders. PCB says “NMB” and “HI-TEK CORPORATION” on it.
The most interesting thing IMO is that these keycaps don’t have the little grabber clips, but only the diagonal corner ridges, so they’re much easier to remove than later space invader keycaps.
« Last Edit: Mon, 10 November 2014, 14:24:27 by jacobolus »
  • RIP
    • Boring twaddle
« Reply #104 on: Mon, 10 November 2014, 14:50:58 »
Production dates on the PCB and ICs?
Bore Awards
Offline jacobolus
« Reply #105 on: Mon, 10 November 2014, 15:26:26 »
No case, and no dates on the PCB, but the ICs are all 83/84.
  • RIP
    • Boring twaddle
« Reply #106 on: Mon, 10 November 2014, 15:47:18 »
So now we just need the IC dates from the ones that don't say "Hi-Tek Corporation" on them.
Bore Awards
« Reply #107 on: Fri, 14 November 2014, 19:56:39 »
I got some in the other day (linear white and tactile black) and will be taking pictures of them soon.
Pro-tip: If you get a board with the caps with the little legs on the side, use a ring type puller and don't pull straight up, but slightly to the side.  You won't ever have an issue with the switch top coming off with the cap.
Offline jacobolus
« Reply #108 on: Fri, 14 November 2014, 20:08:59 »
The way I pull these is with a butter knife or similar sturdy flat piece of metal. You want to pry upward from under one side (side, not front/back) of the keycap while pushing sideways from the other side of the switch. In other words, push the keycap in the direction of the side that you’re prying up from the bottom. One of the little clips that hold the keycap down will snap free (the one on the side you’re prying), and then you can pretty easily push the keycap back the other way to disengage the other clip.
This is probably easier to demonstrate than to explain in words. :-)
I’ve found the most efficient way to remove a bunch of caps is to do them in batches: first unclip one side of the keycap for (e.g.) every other keycap, then come back and lift those all off, then unclip the rest, then lift those off. It’s actually pretty fast once you get a system going.
Of course, the easiest is if you have the old “Gundam” style of switches; then the caps don’t have the little clips at all and you can just lift them straight off.
« Last Edit: Fri, 14 November 2014, 20:10:58 by jacobolus »
« Reply #109 on: Fri, 14 November 2014, 20:19:04 »
I use the wire pullers (my Leopold is my favorite), and grab opposite corners, for everything else, but for Hi-Teks the kind that can grip the sides of the keys are the best. Avoid the corners of Space Invaders.
http://www.ebay.com/itm/New-White-Keycap-Puller-keypuller-for-gaming-keyboard-Filco-Cherry-Noppoo-PBT-/121315722001?pt=LH_DefaultDomain_0&hash=item1c3efb0311
- D Trump 2026-10-24
« Reply #110 on: Fri, 14 November 2014, 20:24:50 »
I've tried the wire puller from the corners, the ring puller is faster.  With the ring puller, you're literally rocking it one side then the other. It pops the cap off in seconds and is the fastest way to pull Space Invaders caps that I know of.  The one you linked to would be perfect.
Jacobulus, it's basically doing what you're doing, but it one fluid motion.  You rock to the side, then the other or pull up and it pops off.  I get each cap off about the same speed as a Cherry cap and faster than Alps caps or Topre.
Offline jacobolus
« Reply #111 on: Sat, 15 November 2014, 02:11:20 »
Erase-ease in the mail http://www.ebay.com/itm/291296707809?orig_cvip=true
I’m going to try to make a custom space invader board with a layout similar to this https://geekhack.org/index.php?topic=56095.msg1384819#msg1384819 (some keycaps won’t be the right legends; I might just dye many (or all) of them dark black and have them be blanks).
By the way the same seller has a non-erase-ease keyboard, quite yellowed, for cheap: http://www.ebay.com/itm/291296711230
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #112 on: Sat, 15 November 2014, 09:36:19 »
which are the gundam style switches again?
anybody gotta a link?
Luga G80-1865/MX Reds + Dolch G80-1813/MX Blues + G80-3700HQAUS + DK9008G2 Pro/MX Browns Thick PBT + DK9008G2 Pro/MX Clears Thick PBT +  QFR TKL/Ghetto Greens + Cherry G80-1800/MX Blues + IBM Model M SSK Bolt Modded + IBM Model M + IBM Model F + IBM AT F + Cherry G80-1000 (HAD)/MX Vintage Blacks + Razer BWU/MX Blues + Leading Edge DC2214/Blue Alps + Compaq MX11800/Browns + Chicony 5181/Monterey Blues + Chicony 5161/MX Black Cherry Clone + Focus 2001/White Alps + Chicony 5191/White Futabas + Olivetti ANK27-101 + Dell (Old Logo) AT101/Black Alps + NMB RT8255C+/Black Space Invaders + Unitek K260/Green Alps + Apple M0116/Orange Alps + AEK II M3501/Cream Alps + AEK M0115/Orange Alps + NEC  APC412/Blue Sliders + NEC APC410/Blue Sliders + Omnikey /White Alps + Wang/Yellow Alps (Omrons) + Laser/White SMK + Fame/Blue Aruz + AEK II M3501/Salmon Alps + Zenith ZKB-2R/Green Alps + Wang 724/Orange Alps + DK1087/Green Alps + Zenith ZKB-2/Yellow Alps + Dell Old Logo AT101/Salmon-Pink Alps + Leading Edge AK1012/White SMK's + Magitronic SK-1030/White (Linear) Futaba's + Packard Bell/White (Clicky) Futaba's + Datacomp DFK101/White  Alps + SGI AT101/Dampened White Alps + NMB AQ6RT-72511/Grey Space Invaders (Hi-Tek) + Datacomp/Blue Alps + Phillips 2812/White Space Invaders (Linear) + Dah Yang K251/Vintage MX Blues + Chicony 5161/DS Caps/Vintage MX Blue + Archie-NMB AQ659ZRT-725/Black Space Invader (Tactile) + IBM Model M 71G4644 (RD) Bolt Modded with Soarers Converter + IBM Model M Silver Label 1390131 + Cherry G80-1501/Vintage MX Clears + Focus FK8000/Linear Futabas + Gateway 2000 Anykey Programmable/Maxi-Switch + Dell GY13PVAT101/Dye Sub Caps/Salmon Alps + Chicony 5161/White Alps + AST K0B101/Slider over RD + Qtronix QX-32H + Everex/NMB RT8255CW+ Black Space Invaders-Split Erase + Tandon/NMB AQ659ZRT-101A/Beige Space Invaders + Cherry G80-11903 MNRUS/MX Blacks + Apple IIGS A9M0330/SMK Whites + WYSE PCE/MX Blacks + Chicony 5160AXT/Clicky Futaba + Cherry G80-0528/Vintage MX Blacks + Dell AT101/Linear (Modded) Black Alps+Topre 55g
« Reply #113 on: Sat, 15 November 2014, 09:56:31 »
The "soap dispenser" version:
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #114 on: Sat, 15 November 2014, 14:14:15 »
ooohhh, i just got one of those, looks like an F XT
very smooth
Offline XMIT
  • formerly jsoltren
« Reply #115 on: Tue, 02 June 2015, 11:38:53 »
Hello GH - klikkyklik sent me a PM asking about how to remove Space Invaders key caps. I wrote him a long response and thought I would share it here:
What jacobolus said is mostly correct. Though, you'll have a tough time with a ring style puller on wider keys. Plus the nubs on the ring style pullers wear pretty quickly.
Your very best bet is a Topre style stainless steel puller. That should work nicely. I usually use a wire key cap puller.
But yes: if you pull straight up you will remove the slider and possibly lose the spring and damage the hands. This is bad. Instead you want to roll the key cap off of the slider. I wouldn't use a rocking motion so much as a rolling motion.
I usually hold the key cap puller with the handle straight up and down (north/south) aligned with the center line of the key cap. Get the wires just barely under the left and right hand sides of the keycaps: enough to get a good grip but no more. Apply upward pressure until both wires have tension in them but not so much that you remove a key cap. Then, while still maintaining upward pressure, start moving the key cap puller to the right, rotating around the point where the right wire touches the key cap. lifting only the left wire.
That overly complicated explanation is, IMO, the best way to do it.
Watch out for the space bars. Most of the stabilized keys just pull right off. But the space bar uses something like a Costar mount. You may end up pulling inserts out of the sides of the spacebar on the underside of the spacebar. Be careful!
Offline Altis
« Reply #116 on: Tue, 02 June 2015, 22:52:05 »
XMIT, I also found the metal keycap puller easier to use. This is because the keycap and the slider are both flush at the bottom. I used the metal one and just grabbed the very edges and pulled up (not squeezing it all the way) and found this worked really well. Tough to explain.
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
« Reply #117 on: Wed, 03 June 2015, 03:13:44 »
With some practice, you can use wire pullers to more or less "roll" the caps off the sliders. Sometimes you can get it loose enough to pull it off yourself, sometimes it just comes off completely.
Offline jacobolus
« Reply #118 on: Fri, 05 June 2015, 04:40:07 »
For space invader switches, I’d skip the puller, and just use a single butter knife (or some similar flat piece of metal that won’t accidentally scratch the keycaps). The trick is pushing sideways and downward on one side of the keycap while prying upward on the opposite side. You can’t really effectively do that with any kind of standard keycap puller.
If you try pulling the caps upward with a standard keycap puller you’ll either break the plastic clips on the keycaps, or yank the slider out of the switch.
« Last Edit: Fri, 05 June 2015, 04:42:02 by jacobolus »
Offline hkrak
« Reply #119 on: Fri, 05 June 2015, 04:58:34 »
I use the exact same tool and method, minus the pushing sideways and downward part. Works great.
POK3R - Acer 6083 - QFR - NMB RT102 - Focus FK2002 - Goldstar Alps
« Reply #120 on: Fri, 05 June 2015, 07:11:33 »
For me, the hard part to re-learn was to avoid corners. On other styles, I always use wire pullers and try to get the wire well under opposite diagonal corners.
Absolutely the wrong thing to do with Hi-Teks - avoid the corners or you will be grabbing the wrong pieces. Only pressure the flats.
Offline chyros
  • a.k.a. Thomas
« Reply #121 on: Fri, 05 June 2015, 11:05:57 »
I'm not sure exactly what corners you're referring to but I've found that if you use wire pullers to pull off the far corners of the key CAPS (so not the sliders) it's pretty easy to dislodge the caps without pulling the slider.
Offline jerue
  • (Whenever that happens :P)
« Reply #122 on: Fri, 05 June 2015, 22:02:02 »
Before joining GH, I found an RT-101 for .54 at a thrift store. I cleaned/disassembled it and played around with actuation forces and whatnot (all beige switches w/pink for lock switches and green for spacebar). The Green space invader is probably one of my favorite switches...it's too bad I had no idea how to pull off the spacebar and ended up destroying the switch beyond repair. Then I did something even worse...and threw the whole board away. Caps and all. I now realize the grave error I made  :-\ :(
I'll have to post some pics soon. Even did the good ol' nickel trick as shown from...that other forum.
Offline False_Dmitry_II
« Reply #123 on: Sat, 06 June 2015, 00:45:02 »
I use a PCI slot cover. Just pry em up from the sides.
Not sure how you destroyed the spacebar, I can pull that with just fingers. And yes, throwing it away was a travesty. That even sounded fairly rare, all of mine are clicky black besides the white linear I also have.
