Author Topic: KBtalKing Doubleshot PBT 60% Keyset  (Read 2902 times)
Offline skcheng
    • Tenafly Dentistry
« on: Thu, 17 July 2014, 05:57:24 »
Does anyone have these?   Are they as nice as they look?
https://www.massdrop.com/buy/kbtalking-doubleshot-pbt-60-keyset
Can't tell if the Capslock is offset or centered?   I'm guessing centered which wouldn't work for my KMAC Happy, GON etc.....
Offline HendyZone
  • HHKB Elite
    • MechanicalKeyboards.co.id
Re: KBtalKing Doubleshot PBT 60% Keyset
« Reply #1 on: Thu, 17 July 2014, 07:05:36 »
That supposed to be the same with the fullset one sir
And the capslock supposed to be centered ;)
Offline Jixr
« Reply #2 on: Thu, 17 July 2014, 14:00:09 »
centered.
Note, I bought this set from MK.com, and it took 3 returns before I got a set that wasn't defective.
whites that didn't match, keys that had black spots in them, and other defects.
They look nice, and are thick, but the QC from the factory is crap, and build quality and finish are poor.
also, the esc key on the massdrop set won't match the rest of the keyboard, on the full set, the function row is taller and sloped differently than the rest of the keys, so it will look tacky ( see the pic i posted on the massdrop discussion thread )
Offline skcheng
    • Tenafly Dentistry
« Reply #3 on: Thu, 17 July 2014, 18:39:38 »
centered.
Thanks for the info.  I'll pass.   Plus all of my 60% boards require an offset CapsLock.  Oh well....
