Author Topic: Identifying: old keyboard, apparently made in Japan, unknown switch type (to me)  (Read 1955 times)
Offline voided
Hi all,
I've recently picked up a keyboard that has me beat. This is very solidly built, with metal bottom and thick plastic housing, and weighs around 2.6kg. Has many non-standard keys. Cable has been cut, but appears to have at least 8 cores. Keys are tall, doubleshots, with a distinctive arched shape. My photos show the keyswitch, which I have so far been unable to identify.
Keyswitches give a distinct click on both downstroke and upstroke that is quite similar in sound and feel to a buckling spring -- though the weight is more like my ALPS Orange keyboards.
I opened the bottom and found a code on the circuit board:  N86D-2525-R010/04 HANDAMEN MADE IN JAPAN
My google searches turned up a few similar codes, mostly related to very modern Fujitsu ultrasound machines. Not sure whether this is red herring...
I wonder, can anybody offer any clues either on the keyswitch type or on the identity of this keyboard?
Many thanks in advance.
Offline CaptLock
Not sure but I remember it is some Fujitsu swtich.
Looks like rubber dome over membrane most likely, but if someone knows for sure, chime in.
Offline bazh
must be 3rd gen of Jujitsu Leaf Spring
http://deskthority.net/wiki/Fujitsu_Leaf_Spring
« Last Edit: Fri, 18 July 2014, 09:39:09 by bazh »
HHKB Pro2 white
Newbie again
Offline voided
Ah...yes, that's a positive ID on the keyswitch. Thanks all -- and especially bazh for the name and link.
Offline jacobolus
Are you planning to do anything with this keyboard? Looks like a fun project to get it working.
Offline voided
Although I find the keyboard interesting and like the key feel, I don't think I'd particularly enjoy the layout even if I could get it working. I'm leaning towards narrower keyboards and this one could never be called narrow! Besides that, my skills currently don't extend to "nutting out" the protocol of a keyboard, installing add-on converters, etc.
So I will either keep this as a novelty or pass it on to someone who might do better things with it. Do you have any interest?
(A pertinent factor here might be that I am located in Australia...so shipping to almost anywhere can be quite expensive)
Offline Hak Foo
  • Make America Clicky Again!
You don't have to work out the protocol in a lot of cases... you can just bypass the original controller and wire the switch matrix directly to a new controller, with programmable behaviour.
Overton130, Box Pale Blues.
