Author Topic: Cherry Stabilizers + MX blacks PCB  (Read 162911 times)
Offline yuiop
Re: Cherry Stabilizers + MX blacks PCB
« Reply #350 on: Thu, 16 October 2014, 06:47:15 »
Although "pcb mounted" stab often comes with a bent wire, you need a straight wire if you're using it with a plate.
People who bought x7 or x6.2 pcb mounted stabs to use for their custom builds could have this problem.
They'll most likely have to bend their own wires due to vast majority of custom keyboards having pcb stab + plate combo.
Offline Nuum
« Reply #351 on: Thu, 16 October 2014, 12:32:39 »
I've ordered some plate mounted stabs from GWERkeys a few weeks ago and they came with the same "wrong" wire with the bent in it. I think this is the wrong wire, as it can not be used with a plate. To use it I had to bend it straight, rebend one of the hooks and shorten it a little bit.
Offline esoomenona
  • Gnillort?
« Reply #352 on: Thu, 16 October 2014, 12:36:36 »
I used a bent wire once. I didn't go through all the trouble Nuum did though. All I did was essentially level the bend with the legs.
Offline pix3l_fodder
« Reply #353 on: Thu, 16 October 2014, 14:57:24 »
ugh, this is annoying I thought the stabs would be a complete package.
Offline JaccoW
  • Fire Typer!!
  • Keyboard is Lava!
« Reply #354 on: Thu, 16 October 2014, 16:53:03 »
They are, it's just that custom boards use custom stabs. ;)
|||My other keyboards :
x
Offline strict
  • TKL Zealot
« Reply #355 on: Mon, 20 October 2014, 12:36:04 »
Not trying to cause more static but what does this mean for the GH60 orders that the Cherry plate stabs wont fit into the plates? Is there going to be someone making wires for those that I could sweet-talk into making some wires for me?
Offline DanielT
« Reply #356 on: Mon, 20 October 2014, 12:39:05 »
The plate ones have straight wire, only the PCB mount has the bent one. And this is only for the 6.25 the 7u has only straight wire.
Offline strict
  • TKL Zealot
« Reply #357 on: Mon, 20 October 2014, 12:52:47 »
The 6.25 Cherry plate stabs I received have the bend in them
Offline yuiop
« Reply #358 on: Mon, 20 October 2014, 14:54:37 »
PM me your address.  I'll send you one.
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #359 on: Tue, 21 October 2014, 07:43:58 »
Due to the issue with proper operation with the bent wire on the 6.25 plate mount. Those of you who ordered them that hasn't been sent out yet order will be delayed until some replacement straight 6.25 wires arrive to me in about 3 weeks. Those that already had the order sent out I will be happy to send again for cost of postage.
« Last Edit: Tue, 21 October 2014, 09:00:38 by IvanIvanovich »
Offline LechnerDE
« Reply #360 on: Tue, 21 October 2014, 08:18:27 »
Due to the issue with proper operation with the bent wire on the 6.25 PCB mount. Those of you who ordered them that hasn't been sent out yet order will be delayed until some replacement straight 6.25 wires arrive to me in about 3 weeks. Those that already had the order sent out I will be happy to send again for cost of postage.
If I am not mistaken you already shipped my order.
Could you please hold onto my replacement wires until you ship the PBT BlackOnBlack dyesubs?
Offline jorgenslee
« Reply #361 on: Tue, 21 October 2014, 08:42:20 »
If my order was not sent yet, can you send it otherwise? I have an extra 6.25 wire and I'm just gonna use the 7x anyway.
« Reply #362 on: Tue, 21 October 2014, 09:01:42 »
I meant PLATE mount 6.25... too early. For those of you who don't care about this issue I can still send the order, just let me know.
« Reply #363 on: Tue, 21 October 2014, 09:05:36 »
I can wait another 3 weeks.  Thanks for getting this resolved Ivan.
Offline DanielT
« Reply #364 on: Tue, 21 October 2014, 09:16:06 »
I don't care about this issue, so you can send my order. I had only one plate mounted 6.25 anyway, and as I don't use plates I could care less :thumb:
Offline Synjin
« Reply #365 on: Tue, 21 October 2014, 09:33:05 »
Isbtherebabway to find out if mine has been sent out or not?
« Reply #366 on: Tue, 21 October 2014, 09:41:51 »
Unless you had novelty dyesub keycap, your stabs order not send yet. I stopped sending them after the problem with the plate 6.25 was brought up until I had gotten something worked out to deal with it. Those order that aren't effected should be send out this week.
Offline Vitaly
« Reply #367 on: Tue, 21 October 2014, 09:42:42 »
Send the order, new keyboard waiting for Dolch. Wire not a problem.
« Reply #368 on: Tue, 21 October 2014, 10:23:48 »
+1
Offline GeorgeK
« Reply #369 on: Tue, 21 October 2014, 10:31:06 »
I can wait :) Cheers for sorting this bud
Offline Synjin
« Reply #370 on: Tue, 21 October 2014, 10:48:06 »
This means that I wont be getting mine until 3 weeks from now if mine is affected (I'm not sure and im too lazy to check what exactly I ordered)  ^_^. I'm not that worried since this just means that I will actually be getting the right wire to come with my stabs and I still haven't really ordered my key switches from MK.com that I need in order ot finally assemble my duck viper and eagles.
Offline phatdood9
« Reply #371 on: Tue, 21 October 2014, 11:43:50 »
Sorry to be "that guy," but does that mean 7x and 2x stabs are all good to go?
Excited to build up my vipers  :))
Offline christkind
« Reply #372 on: Tue, 21 October 2014, 12:02:14 »
You can send my order anyway, only care about the 7 plate mount. If that's not too much trouble for you. :)
« Reply #373 on: Tue, 21 October 2014, 13:01:38 »
Yes the Plate 2.x and 7 are fine as are all the PCB mount. Only plate 6.25 has issue. If you didn't order plate 6.25 or don't care about the problem and tell me so I will be shipping your orders this week.
Offline GeorgeK
« Reply #374 on: Tue, 21 October 2014, 13:03:42 »
Well in that case I won't wait as I didn't order any 6.25 plate :)  Does that mean my combined Dolch / stab order will soon be on its way?
« Reply #375 on: Tue, 21 October 2014, 13:18:18 »
Yes, those that also have Dolch will get it together.
Offline christkind
« Reply #376 on: Tue, 21 October 2014, 13:56:21 »
OK thanks, don't care for the 6.25 one. Do you want me to send you a PM or is this good?
Offline Lubed Up Slug
« Reply #377 on: Tue, 21 October 2014, 22:31:59 »
How do we know if our order has been shipped yet?
Offline Synjin
« Reply #378 on: Tue, 21 October 2014, 22:36:19 »
I just asked this question earlier. I was told that the only orders that had already shipped are the ones which contained some novelty keycaps.
« Reply #379 on: Tue, 21 October 2014, 22:45:04 »
Oh I see my bad
« Reply #380 on: Fri, 24 October 2014, 16:44:16 »
Some of you international that ordered PCB may receive email from me request for additional shipping. This will mostly apply to those that ordered more than 1 as it seems to be a more significant price difference. I'm not sure if the prices went up on shipping or if I simply grossly underestimated the weight of those PCB but don't be surprised by this. Sorry for any inconvenience but I simply can't afford to cover the difference.
If you feel it's simply not worth it, I can see about refund/transfer PCB to another buyer.
Offline Flamingchook
  • There are no dumb questions, only forbidden ones.
« Reply #381 on: Fri, 24 October 2014, 20:57:20 »
Thanks for the heads up Ivan.
MX: Filco Majestouch Metalic Blue 104-key w/ MX Brown, JD40 w/ MX Green, ErgoDox w/ MX Blue, GHPad w/ MX Blue. Topre: Realforce 87U 45g. BS: IBM Model M 52G9700 29-OCT-93
Soon™: GH60 w/ 62g MX Clear, [CTRL]ALT 60 w/ MX Green
« Reply #382 on: Fri, 24 October 2014, 23:11:00 »
AT - RU is shipped... unless your order is waiting for correct plate 6.25 parts.
Offline RickyJ
« Reply #383 on: Sat, 25 October 2014, 00:04:22 »
I got mine today along with the novelty dye-subs.  Thanks!
Currently GMMK Pro: lubed 68g U4T, FR4 plate, extra gaskets, etc
Offline Vitaly
« Reply #384 on: Sat, 25 October 2014, 04:00:23 »
Offline christkind
« Reply #385 on: Wed, 29 October 2014, 12:34:25 »
Amazing! Only 3 days to Austria :) Thank you so much!  :thumb:
« Reply #386 on: Thu, 30 October 2014, 19:05:20 »
If your order didn't have plate 6.25 in it, it's been sent.
As soon as I get in the replacement correct straight 6.25 wires for those I will finish sending the rest of orders.
Offline LechnerDE
« Reply #387 on: Fri, 31 October 2014, 06:42:17 »
My stabs arrived today - some are a little bent from shipping but this should be fixable :)
Thanks for the GB Ivan  :thumb:
Offline Karura
  • Professional Canadian
  • SKidata life.
« Reply #388 on: Fri, 31 October 2014, 13:19:05 »
Hello, just wanted to say that I'm looking for PCB-mounted (new, not the screw ones) stabs.
Please let me know if anyone has extras that they can sell me. Any size is good.
« Reply #389 on: Fri, 31 October 2014, 13:33:40 »
All of the PCB mount stabilizers sold in this group buy are the screw type. Is there a reason you don't want to use them?
Offline DanielT
« Reply #390 on: Fri, 31 October 2014, 13:42:32 »
Received my stabs :thumb: thank you Ivan, and thank you also for the sweets it was a nice surprise :cool:
Offline TBone
« Reply #391 on: Sat, 01 November 2014, 18:49:06 »
Ivan,
Do you have an ETA on the correct 6.25 stabs? Thanks for doing this again!
« Reply #392 on: Sat, 01 November 2014, 19:26:15 »
GMK said it would take 3 weeks for them to get some, plus maybe another week or something for them to turn up here.
Offline Synjin
« Reply #393 on: Sat, 01 November 2014, 21:38:55 »
So it would be approximately a month from now plus one to two weeks shipping to us?
« Reply #394 on: Sat, 01 November 2014, 21:47:32 »
Probably a little longer.  You need to factor in sorting time as well.  Ivan is reliable though and it will get done.
Offline Synjin
« Reply #395 on: Sat, 01 November 2014, 21:52:53 »
Yeah I really don't mind waiting the extra time in order to get a quality product
Offline Synjin
« Reply #396 on: Mon, 03 November 2014, 18:34:58 »
Just received my stabs ivan, I messaged you about some issues with the package.
Offline JaccoW
  • Fire Typer!!
  • Keyboard is Lava!
« Reply #397 on: Tue, 04 November 2014, 03:29:42 »
I had a 2x stabilizer with a PCB on one end and a plate mount on the other. Don't really mind though.
Just wished I had ordered more screw-on stabilizers.
Did anybody get the PCB to work yet?
x
Offline GeorgeK
« Reply #398 on: Tue, 04 November 2014, 04:26:07 »
I had a similar thing with my 7x plate mount - luckily I had a spare plate mount plastic bit kicking round...
« Reply #399 on: Tue, 04 November 2014, 09:19:08 »
Seriously?  :rolleyes:
