Author Topic: How is the Poker X a 40% keyboard?  (Read 1795 times)
Offline cribbit
« on: Fri, 18 July 2014, 15:42:48 »
Isn't 40% a 4x12 unit? 60% being Poker II (5x15), 75% being Race II (6x16). Poker X has the same layout as Poker II. I can't even figure out what the difference is between the X and the II.
I typed this post on my Slanck. I also developed a stronger, cleaner, easier handwiring method.
Offline intelli78
Re: How is the Poker X a 40% keyboard?
« Reply #1 on: Fri, 18 July 2014, 15:43:39 »
Poker X is a 60% keyboard just like the Poker II. The main difference is that Poker II has a plate, and slightly different function keys. Poker X is also discontinued.
Offline FrostyToast
  • Litshoard
« Reply #2 on: Fri, 18 July 2014, 15:53:31 »
I have seen several documentations where the Poker was misidentified as a 40% keyboard, it is in fact a 60%.
Quote from: elton5354
Offline Lastpilot
  • Power stance
« Reply #3 on: Fri, 18 July 2014, 15:56:07 »
It is 60%
Offline cribbit
« Reply #4 on: Fri, 18 July 2014, 16:02:08 »
Okay, thanks, just making sure I wasn't going crazy. Everywhere I see it it's labeled as 40%. I guess it's understandable, since by area it's closer to 40% of a fullsize board than 60%.
Offline cooldiscretion
  • Convicted guilty of being totally rad.
« Reply #5 on: Fri, 18 July 2014, 16:07:08 »
I believe I've seen some keyboards that were 60% referred to as 40% because they are 40% smaller then a traditional full-sized  keyboard - which is the same as saying 60%.
It sounds more correct to say 60% to me though.
« Reply #6 on: Fri, 18 July 2014, 16:48:45 »
I think it's the difference of measuring by area vs. number of keys. The poker, you see has none of the spaces between keys like you get between the arrowkeys and navcluster.
Identifying by # of keys as a percentage seems to have become the norm now, though.
