Author Topic: Two switch two unit key  (Read 1955 times)
Offline cribbit
« on: Fri, 18 July 2014, 16:05:41 »
Does this exist? Caps lock seems to be the largest non-stabilized key, but it only has one switch for it since it's typically 1.5. Anything 2 or more seems to always have stabilizers. Are there 2 wide keys which just have two switches connected into them, without stabilizers? Like say, backspace.
I typed this post on my Slanck. I also developed a stronger, cleaner, easier handwiring method.
Re: Two switch two unit key
« Reply #1 on: Fri, 18 July 2014, 16:12:44 »
Yes, on matrix keyboards like Tipro.
Also, this would be a good candidate for posting in Simple Questions, Simple Answers...
Offline cribbit
« Reply #2 on: Fri, 18 July 2014, 16:31:39 »
Thanks.
I would have posted there, if I knew it existed. Link?
Offline jacobolus
« Reply #3 on: Sat, 19 July 2014, 00:00:18 »
A guy posted this precise question at Deskthority very recently:
http://deskthority.net/keyboards-f2/two-switches-under-double-wide-keys-t8421.html
