Author Topic: New Mousepad Recommendation  (Read 3717 times)
Offline Dragowing193
  • Lab Monkey
« on: Sun, 20 July 2014, 16:50:39 »
I have used generic mousepads (like $5-10) for most of my PC history. My current one is getting rather ratty, so i'm looking for a new one. I don't have much room for a mousepad on my keyboard tray, so a small one would be preferable. Do non-generic mousepads have a noticeable difference, and if so any good recommendations? I do have arthritis and tendinitis, so that might factor in to the mousepad selection, but should not be limited to that parameter. I do have a keyboard wrist rest. Thank You.
Offline epzy
  • HHKB Fiend
  • ded
Re: New Mousepad Recommendation
« Reply #1 on: Sun, 20 July 2014, 17:33:58 »
Artisan mousepads are HIGHLY regarded.
http://geekhack.org/index.php?topic=36965.0
Offline FrostyToast
  • Litshoard
« Reply #2 on: Sun, 20 July 2014, 17:45:30 »
If I wanted a super wide mousepad that I could put my keyboard (up to a TKL) on, what would I want?
Quote from: elton5354
Offline epzy
  • HHKB Fiend
  • ded
« Reply #3 on: Sun, 20 July 2014, 17:49:14 »
The Corsair MM200 extended perhaps?
http://www.corsair.com/en-us/corsair-mm200-gaming-mouse-mat-extended-edition
Offline exitfire401
  • The Force is Re/\l
« Reply #4 on: Sun, 20 July 2014, 17:54:21 »
The Razer Goliathus has been my end all be all mousepad for a very long time now. I've been using a desklength for almost 4 years and I have a medium size that I throw in my laptop sleeve to take with me everywhere.
Offline CK Briefs
  • formerly calvins1
« Reply #5 on: Sun, 20 July 2014, 19:13:25 »
+1 to this
I could even sell you mine :P
Current Keyboards: Orion - 62g ergo clears;
A87 PS2AVR - 59g ergo clears; QFR - stock blues
Offline FrostyToast
  • Litshoard
« Reply #6 on: Sun, 20 July 2014, 19:38:07 »
+1 to this
Sounds like an intriguing offer, maybe I can bite once I have sufficient money.
« Last Edit: Sun, 20 July 2014, 21:21:37 by FrostyToast »
Offline nraymond
« Reply #7 on: Sun, 20 July 2014, 21:20:53 »
Years ago when I made the mistake of buying a Razer Lachesis mouse on release I went through a ton of mousing surfaces before I realized the sensor had serious design flaws (and of course you can't even buy the mouse any more, good riddance).  I found that Steelseries mouse pads work well, and are available in a variety of sizes.  They're my favorite cloth/rubber backed flexible mouse pad.
I've always been curious about the CS Hyde Company mouse pads, such as the C4-NGen, which are rubber backed, rigid top layer pads where the entire surface is teflon.  I've never tried it, but I imagine mouse movement would be pretty effortless!  http://c4mousepads.com
Offline missalaire
  • Great Finder of Great Finds
« Reply #8 on: Sun, 20 July 2014, 21:24:36 »
I love my Corsair MM600 and yellow Ducky OMG mousepads :D
« Reply #9 on: Sun, 20 July 2014, 21:25:36 »
I'd say get an Artisan pad, but they never last too long for me. They are however very nice, and there's a lot of options on surface type. Mionix makes some good cloth pads, and so does Steelseries.
BTW - I am a cloth pad man for life, so if you aren't just ignore this post :)
Offline Senthura
  • Your Doom
« Reply #10 on: Sun, 03 August 2014, 21:59:27 »
I've used Steelseries QCK series and have the NA'VI edition QCK+ that's downright huge. The Razer Goliathus mousepads are also highly regarded where I'm from.
Ducky Shine 3 TKL Blue switch & Green backlight
Offline paulen
« Reply #11 on: Sun, 03 August 2014, 22:06:58 »
glass FTW?
Offline silas1128
« Reply #12 on: Sun, 03 August 2014, 22:47:35 »
I've been using a XTRAC PADS Ripper XXL for a couple years, its held up well. There is some slight separation near the mouse now though. I've been looking to grab something new but I haven't decided if I want to buy another Ripper or try something like the corsair or razer.
Offline pcandkbguy
« Reply #13 on: Mon, 04 August 2014, 07:21:45 »
mtg mousepads are awesome, can be had for cheap on eBay
Offline caesar
« Reply #14 on: Mon, 04 August 2014, 07:23:42 »
