Author Topic: Mac G3 keyboard - mechanical?  (Read 5792 times)
Offline cribbit
« on: Sun, 20 July 2014, 20:01:51 »
Or just another membrane?
I typed this post on my Slanck. I also developed a stronger, cleaner, easier handwiring method.
Re: Mac G3 keyboard - mechanical?
« Reply #1 on: Sun, 20 July 2014, 20:30:50 »
Membrane.
Offline heedpantsnow
  • Old enough to know better
« Reply #2 on: Sun, 20 July 2014, 21:05:40 »
Sometimes I can't understand why Apple hasn't gone mech, given all the hipsters that use their products.
I'm back.
Offline thesupergeek
« Reply #3 on: Sun, 20 July 2014, 21:06:49 »
I have one from the G4 Cube, and it is certainly membrane, but I do not know about the G3. Looks like it though.
My collection:
GON HHKB (62g MX Clears), CM Storm Novatouch, Poker II (MX Blues)  ., HHKB 2 Pro ., Cherry G80 (MX Blacks), JD40 (In the mail as soon as Margo builds it!), Plank Keyboard (parts in the mail!)
Offline dante
« Reply #4 on: Sun, 20 July 2014, 21:09:38 »
It might fly for Matias switches especially with only two variants - not sure if Cherry is up to the task.
« Reply #5 on: Sun, 20 July 2014, 21:10:22 »
Or given how much they charge for their products.
Offline FrostyToast
  • Litshoard
« Reply #6 on: Sun, 20 July 2014, 21:11:00 »
If you want to go true mech hipster, you need to get alps aka Matias.
Quote from: elton5354
« Reply #7 on: Sun, 20 July 2014, 21:45:34 »
The last keyboard from Apple that had mechanical switches was the Apple Extended Keyboard II. Production ceased in 1994.
Offline divito
« Reply #8 on: Sun, 20 July 2014, 22:25:55 »
Well, Cherry has a hard enough time keeping with demand now.....Apple would blow the company to ****.
Varmilo (MX Grey) KeyCool 87 (MX Clear) Quickfire Stealth (MX Green)
Offline johndavis33
« Reply #9 on: Mon, 21 July 2014, 02:26:23 »
You forget Apple's commitment to form over function design philosophy. Remember that "worst keyboard" thread? The consensus was that Apple's aluminum keyboard is the worst that most people ever used. That keyboard is in the same price bracket as a QFR
HAVE AND WILL KEEP: HHKB - Printed white | Ducky Banana edition - Whites | Model M13 | Unidentified Goodwill keyboard - Simplified black ALPS
TOO BE SOLD: TG3 BL82 - Clears | Wheelwrite 5 - Buckling Springs typewriter
SOLD: Rosewill RK9000 - Blacks | QFR - Blues | Ducky G2 Pro - Greens |
IT WILL BE MINE: Northgate Omnikey - White ALPS
Offline Vanilla
  • 110% Snuggable
« Reply #10 on: Mon, 21 July 2014, 03:42:57 »
G3 & G4 keyboards feel pretty good to me with a softer force curve that drops all of a sudden when actuated.
Definitely not a bad membrane keyboard imho; if I was forced to use one, I would preferbly use either of these.
Also, the uni-"foot" that swings from the front of the keyboard to the back to prop it up is a pretty neat and distinctive design for the time and still is.
The G5 keyboard on the other hand was absolutely horrendous and a pain to clean when stuff works its way below to the clear bottom casing to contrast conveniently with the white inner casing.
« Last Edit: Mon, 21 July 2014, 03:46:09 by Vanilla »
« Reply #11 on: Mon, 21 July 2014, 05:31:17 »
Although I didn't mind the Apple aluminium keyboard, the one I had at work was the only keyboard that has ever repeatedly given me little electric shocks (static discharge).
