Author Topic: [SPRiT] PCB +Case +Parts (NEW Full Alu Case Buy)  (Read 299937 times)
Offline sprit
  •  Post Editing Timeout
  • Location: The Geek Symphosion :::::: Mechanical Engineering ::: Alta Magna Uniforma :::::: 哀吾生之須臾羨長江之無窮 ::
« on: Sun, 20 July 2014, 21:00:28 »
Moderation Note: Sprit has failed to successfully deliver/communicate on group buys in a satisfactory manner on multiple occasions in the past.  Order forms are removed per the moderator team. Sprit has been assigned a member group that removes his post editing permissions, and he will not be allowed to start any future group buys or advertise on geekhack in any manner.
140040-0  102476-1 105585-2  103713-3 97419-4  102084-5  143666-6 143658-7
Pics :  rpeterclark, Photoelectric
PCB + Case + Parts + Springs *
60%  Solid Alu Cases *
-   Model  A1 ,  A1 HHKB     -   Single Solid Alu Alloy
143654-8  143656-9  143658-10  143660-11  143662-12  143664-13  143666-14  143668-15
Acrylic Cases   -  40%  60%  68%  75%  87%  108%
-   Model  2S    :    15mm  thick  (Plate + 2 layers)  Slim     (supports  :  Face W,  B Face,  Nerd60,  most custom PCBs   *HHKB needs a comment)
-   Model  3S    :    15-18mm  thick  (2 or 3 layered)  Top flushes with Plate     (supports  :   Poker, Pure, GH60, Face W, B Face, Nerd60, Alps 60%, most custom PCBs   *KB V60 needs a comment)
-   Weight      :    Case only 550g - 750g Net,   Full Assembled  750g - 1,150g     (*Poker stock case :  120g)
-   Guide        :    https://geekhack.org/index.php?topic=60887.msg1488528#msg1488528           https://geekhack.org/index.php?topic=50580.msg1415531#msg1415531
Plates        :    Acrylic  /  Polycarbonate  / Alu Alloy
-   Heavy Acrylic       :    5mm thick High precision Laser machined,  All Colors       (supports  :   40%, 60%, 75%, 80%, TKL, 108%,  most custom PCBs)
-   Polycarbonate     :    3-5mm thick CNC machined,  Clear Transparent Only        (supports  :   40%, 60%, 75%, 80%, TKL, 108%,  most custom PCBs)
-   Alu Alloy              :    1.6mm,  2mm,  4mm  thick Laser or CNC Machined          (supports  :   40%, 60%, 75%, 80%, TKL, 108%,  most custom PCBs)
LSS  Station   (Lube Spring Swap)
-   A Simple & Easiest Way to Lube and Swap Your Switches!
-   LSS  Guide     :     https://geekhack.org/index.php?topic=55888.msg1746597#msg1746597
PCBs    ::   All PreSoldered   ::   SPRiT Edition
-   All Factory pre-soldered & Tested.   Designed & Manufactured in Korea,  Inspected  by SPRiT
-   ANSI + ISO in one PCB and Plate   (The very First from Korean customs,  Concept Design by SPRiT)
-   All Programmable Keys, SW & HW Keymap,  SW & HW Macro,  FN key at any position
-   Newly designed mounting Holes for the PCB and Case  (Design by SPRiT for Systematic Oscillatory reasons  *copyright)
-   60% W, 87% W, 110% W supports :  Standard  1.25x 1.25x 1.25x 6.25x  Winkey,  1.5x 1x 1.5x 7x 1.5x 1x 1.5  Winkeyless,   1.5x 1x 1.5x 6 x 1.5x 1x 1x 1.5   Winkeyless,    1x1.5x 7(6)x 1.5x1  60% HHKB
-   75% MX-mini W supports   :  1.25x 1x 1.25x 6.25x 1.25x 1x1x (1x1x1)  Winkey,    1.5x 1.5x 7x 1.5x 1.5x (1x1x1) Winkeyless
-   Supports All the current available Keycaps  (centered & off-centerd Capslock,  6x, 6.25x, 7x  Spacebar,  1x1 Backspace,  ANSI+ISO Shift & Enter)      -   https://geekhack.org/index.php?topic=50580.msg1179292#msg1179292        https://geekhack.org/index.php?topic=50580.msg1353538#msg1353538
Overviews & Guides
-   PCB  Keymap & FW      :   https://geekhack.org/index.php?topic=50580.msg1256970#msg1256970
-   LED Effects                  :   http://www.youtube.com/channel/UCLG-nNBTnoggGvpK5i9XM3w/videos          https://geekhack.org/index.php?topic=53618.msg1771544#msg1771544
-   Assemble Guide          :    https://geekhack.org/index.php?topic=56822.0             https://geekhack.org/index.php?topic=58969.0           http://imgur.com/a/nYWbK         http://imgur.com/a/9tzsv
-   Media                           :   https://geekhack.org/index.php?topic=72439.0        http://imgur.com/a/2vTc1         https://geekhack.org/index.php?topic=53618.msg1721116#msg1721116
Worldwide Stores
www.MechanicalKeyboards.com      USA
www.OriginativeCo.com                   USA
www.MechanicalKeyboards.co.id     ASIA
84870-1684880-1784882-1884884-19140036-2084932-2185058-2294914-2384886-2484888-2584890-2684892-2784894-2884896-2984919-3084926-3184928-3284930-3395446-3496204-3596206-3696401-3796403-3896411-3996417-4096601-4198400-4298407-4398409-4498885-4599416-46102084-47102088-48102189-49102474-50102476-51102482-52103723-53110256-5485051-55
« Last Edit: Tue, 24 January 2017, 18:22:04 by Moderation Team »
Offline sprit
Re: 60% Color Case - w LED - $55
« Reply #1 on: Mon, 21 July 2014, 08:59:27 »
-   This is a Simple GroupBuy.  :thumb:
-   Free to Join Any Members without any infos.    :thumb:
-   a part of my GB R2 to meet the Popularity and MOQ.
« Last Edit: Mon, 21 July 2014, 09:07:21 by sprit »
Offline numiru
« Reply #2 on: Mon, 21 July 2014, 09:06:05 »
Lovely cases Sprit! I love the frosty acrylic. Unfortunately I'll have to pass as I just purchased an aluminum 60% case from Pexon.
KUL ES-87
Offline sprit
« Reply #3 on: Mon, 21 July 2014, 09:10:02 »
Hello,  numiru !   ;)
Been a Nice Weekend?
Offline numiru
« Reply #4 on: Mon, 21 July 2014, 09:14:56 »
Hello,  numiru !   ;)
Yeah, how was yours Sprit? :)
« Last Edit: Mon, 21 July 2014, 09:26:49 by numiru »
KUL ES-87
Offline trizkut
« Reply #5 on: Mon, 21 July 2014, 09:22:44 »
love the cases!
one question - do you happen to have a picture of the pink color?
Offline sprit
« Reply #6 on: Mon, 21 July 2014, 09:27:56 »
love the cases!
Hello!  Will You please,  You can Show Your Pink!  I will  try to produce it.
I am ignorant on Pink color.  too many Pinks   ::)
Offline MrexD
  • aka mrwoodyxd
« Reply #7 on: Mon, 21 July 2014, 09:29:11 »
Interested! Would love to see what it looks like completely assembled, just to get a good idea of what it would look like in the end.
Awesome looking cases though.
Pok3r MX CLears
Offline sprit
« Reply #8 on: Mon, 21 July 2014, 09:41:23 »
You can Look  at the last Pic,  or  1 min !!   I need to boost my Blood nicotine Level    :o
http://geekhack.org/index.php?topic=50580.msg1407519#msg1407519
https://www.youtube.com/watch?v=J4eA1TqGN8w
and....
Model 2, 3 -  60%    Night Surprise Shot -11   https://www.youtube.com/watch?v=fBxEuQsdf7I
71845-0  71849-1  71867-2  71869-3
« Last Edit: Mon, 21 July 2014, 13:36:22 by sprit »
Offline MrexD
  • aka mrwoodyxd
« Reply #9 on: Mon, 21 July 2014, 10:09:43 »
Really cool. And the LEDs inside the case, are we able to change them ourselves? And do they have a separate controller to turn them on and off? or are they constantly on?
Pok3r MX CLears
Offline sprit
« Reply #10 on: Mon, 21 July 2014, 10:15:23 »
1 sec!  ...  Blood Pessure  adjusting....
http://geekhack.org/index.php?topic=33155.msg1407560#msg1407560
You can Just put  another  LEDs  to  Side  /Bottom  on Your any LED Keyboards. No electrical Issues. (up to 20~30 LEDs)    :thumb:
And  the Auto changing is by Muti 7 color LEDs,   Much easier way than by the Software or controllered, IMO    ::)
https://www.youtube.com/watch?v=J4eA1TqGN8w        https://www.youtube.com/watch?v=o2oAjCjCaUE
« Last Edit: Mon, 21 July 2014, 11:38:51 by sprit »
Offline sprit
« Reply #11 on: Mon, 21 July 2014, 10:15:47 »
love the cases!
Personally, I like pastel pinks (ones that tend to have more white and look less purple), kinda like this  http://www.colourlovers.com/color/FFD1DC/Pastel_Pink      >>>  I like tihis Pink too!!    ;)
If I were to get a color top and white frosty bottom, would the top color look brighter than normal?  >>> Sure!!  ;)
And which do you prefer?  White frosty/matte bottom with color top, or color bottom and white frosty/matte top?    >> For me? I Love  Both !!   ::)
Clear Top is strong enough against scratches if the material is good enough, imo.
« Last Edit: Mon, 21 July 2014, 13:38:09 by sprit »
Offline pmh1410
« Reply #12 on: Mon, 21 July 2014, 10:32:11 »
Oh Sprit, very nice housing for led ;)
Offline DanielT
Re: 60% Color Case - w LED - $55 (Pre-Order)
« Reply #13 on: Mon, 21 July 2014, 11:23:33 »
Hey sprit, I didn't see this thread before, this case is wicked  :thumb: Paycheck day is near so I might jump in ;)
Offline sprit
« Reply #14 on: Mon, 21 July 2014, 11:42:38 »
Hi!  Dear  Dan!  ;)
This GB goona be the End of My Case Model 1, 2, 3   =  This Series seems Completed !
« Last Edit: Mon, 21 July 2014, 11:44:54 by sprit »
Offline DanielT
« Reply #15 on: Mon, 21 July 2014, 11:54:50 »
So this is the last chance to get one...   :cool:
This case would go very nice with Galaxy Class key set, I might get my end game keyboard ;)
« Last Edit: Mon, 21 July 2014, 11:57:02 by DanielT »
Offline sprit
« Reply #16 on: Mon, 21 July 2014, 12:23:01 »
I will be back online in 10 hrs!
Have a Nice Day/ Nite  !   :thumb:
Offline Lain1911
  • God of the Wired
« Reply #17 on: Mon, 21 July 2014, 12:38:51 »
wow this is great!
Offline LechnerDE
« Reply #18 on: Mon, 21 July 2014, 13:02:20 »
These are looking great Sprit  :thumb:
Offline rippor
« Reply #19 on: Mon, 21 July 2014, 13:39:01 »
I'm kinda confused are the LEDs in the case? Is there any soldering required or do I just screw my poker II into place?
I'd like one I'm just confused as to how the LEDs work
Offline Zeal
    • Zeal Generation Inc.
« Reply #20 on: Mon, 21 July 2014, 14:32:01 »
I had this discussion with sprit yesterday, and he said the lower case LEDs are just soldered onto the regular switch LED legs below. You have the option to bend the side LEDs 45-60° to position the angle properly for proper lighting. :)
« Last Edit: Mon, 21 July 2014, 14:47:50 by Zeal »
Offline sprit
« Reply #21 on: Mon, 21 July 2014, 20:06:56 »
wow this is great!
Hello   Lain !   ;)
You got 60%  ?
Offline rippor
« Reply #22 on: Mon, 21 July 2014, 20:55:04 »
Thanks Zeal, just ordered my case
Offline FrostyToast
  • Litshoard
Re: 60% Color Case + LED = $55 (Ordering ~)
« Reply #23 on: Mon, 21 July 2014, 21:07:39 »
What are the dimensions of the 60% case?
I want to see if this will fit in my carrying case.
Also, if you haven't sent out my PCB yet, I will want this shipped with it if I buy it.
Quote from: elton5354
Offline sprit
« Reply #24 on: Mon, 21 July 2014, 21:24:37 »
Hello!  A.   I am going to ship Your PCB + Parts assembled  this week  on Friday.  ;)
Model 3  Case   :   310 x 112 x 18 mm
Poker  stock   :  ~ 300 x 102 x 26 (avg.) mm
« Last Edit: Tue, 22 July 2014, 21:04:30 by sprit »
Offline FrostyToast
  • Litshoard
« Reply #25 on: Mon, 21 July 2014, 21:35:00 »
In this image, it looks like there is green right on top of a clear middle layer. Is this kind of thing available with the Super Slim cases?
It looks like this case is the same height as the others.
Offline thestage
« Reply #26 on: Mon, 21 July 2014, 21:38:10 »
If I paid an invoice for a case as part of the R2 buy, is there any way I can change that order to one of these? There are colors available here that weren't available in that form just a few days ago, and this also has a clarified shipping option and the free LEDs.
Offline sprit
« Reply #27 on: Mon, 21 July 2014, 21:44:21 »
Sure!   Just send me an Order Form with new options  and comments Please!   :thumb:
Offline sprit
« Reply #28 on: Mon, 21 July 2014, 22:08:48 »
Yes!  Your are Right!!!  :)      -  this pic is Model 2 Slim  to show LED effects.
Model 3 Super Slim is  Top 5(8)mm + Bottom 8mm + Bumpon 2(5)mm  Structure.
Keycap level is  higher than Poker II.
« Last Edit: Mon, 21 July 2014, 22:12:04 by sprit »
Offline thestage
« Reply #29 on: Tue, 22 July 2014, 00:01:39 »
If I order through zeal for the US proxy shipping, I have to pay up front.  If I PM you the changes or submit an order form through you, can I still get the proxy shipping rate through him? Or do you have to refund my initial payment?
Offline sprit
Re: [GB] 60% Color Case + LED = $55 (Ordering ~)
« Reply #30 on: Tue, 22 July 2014, 00:12:33 »
If I order through zeal for the US proxy shipping, I have to pay up front.    >  Yes!  and His 1 Day Delivery is faster.
If I PM you the changes or submit an order form through you, can I still get the proxy shipping rate through him?  >  Sure!
Or do you have to refund my initial payment?   >>  You can  re-order thru him.  The Price and Accessaries are all the same.  and then I will refund for You.
Sure!  and  He will send Your changes to me for Doublecheck.   :thumb:
« Last Edit: Tue, 22 July 2014, 00:15:22 by sprit »
Offline KaboomTheory
  • Shrek is love, Shrek is life
« Reply #31 on: Tue, 22 July 2014, 00:40:34 »
How much is shipping to Los Angeles, CA 90029? You sent me an invoice but I want to know how much shipping is going to be around... because it might make me cancel.
« Reply #32 on: Tue, 22 July 2014, 00:40:47 »
--- nope
Offline sprit
« Reply #33 on: Tue, 22 July 2014, 00:45:14 »
Your 87% + Case+ parts  :  by Air  ~$18,   by Proxy  ~$13  I guess   ;)
Offline asdfjkl36
  • blue shirt guy
« Reply #34 on: Tue, 22 July 2014, 00:59:11 »
How much would a 60% be to 93550? Price for just a pcb? just a case? both?
THanks!
Offline sprit
« Reply #36 on: Tue, 22 July 2014, 01:31:22 »
THanks!
-  via  Proxy   (From Korea 2-4 Weeks)   :    ~ $15    ;)
-  via 1-Day DHL Delivery  (by Zeal)        :    ~ $20    ;)
by  Zeal  (North American Proxy Helper)   : 1-Day DHL Delivery
1kg    =  $20
1.5kg =  $22
2kg    =  $24
2.5kg  = $26
« Last Edit: Wed, 23 July 2014, 02:19:53 by sprit »
Offline sprit
« Reply #37 on: Tue, 22 July 2014, 05:59:19 »
Oh!  Thanks!    ;)
Are You OK  in this summer?
Offline thestage
« Reply #38 on: Tue, 22 July 2014, 07:11:35 »
Lets hope the pink turns out well. I just couldn't resist!
Offline sprit
« Reply #39 on: Tue, 22 July 2014, 07:44:40 »
You want  Translucent  PinK ,  yes?
« Last Edit: Tue, 22 July 2014, 07:57:37 by sprit »
Offline sprit
Re: [GB] 60% Color Case + LED = $55 (Order & Pay ~)
« Reply #40 on: Tue, 22 July 2014, 20:38:50 »
Some More Color Options  Updated!!    ;)
and Your 2nd Choices  for Colors!  ... etc
« Last Edit: Wed, 23 July 2014, 02:21:14 by sprit »
Offline sprit
Re: [GB] Poker - 60% Color LED Case = $55 : (Order)
« Reply #41 on: Wed, 23 July 2014, 10:39:07 »
 Color  examples :  Clear, White,  Red,  Black,  SkyBlue,  Green,  Yellow,  Orange,  Black,  Blue
72116-0
« Last Edit: Wed, 23 July 2014, 12:04:55 by sprit »
Offline PandaSPUR
« Reply #42 on: Wed, 23 July 2014, 13:04:17 »
Still kinda confused about how the LEDs work...
I would basically be given a bunch of loose LEDs that I need to solder onto my own PCB right?
Looking to get a case with lime on bottom and frosted clear on top.
Could you give an example of what the "Lime Transparent" color looks like? Is it the same as the green you just showed?
Home:
Das Keyboard - MX Browns - Vortex Grey Side-Printed PBT Caps
Work:
KBT Pure - iKBC Aluminum Case - MX Reds
Vortex Poker II - Frosty on Lime Acrylic Case - MX Clears
Offline Zeal
« Reply #43 on: Wed, 23 July 2014, 17:08:54 »
You'll be given a pack of LEDs that you can solder onto the pre-existing LED solder points, except this is on the underside of the PCB. You then bend the legs however you wish to give the acrylic case a glow around the boarder. :)
Lime transparent will look similar to this:
Sprit will post an updated picture later today. (I saw a potato picture that he took at night)
Offline sprit
« Reply #44 on: Wed, 23 July 2014, 21:43:42 »
Color  Samples  -  Red, Pink, Yellow, Orange
Color  Samples  -  Lime, Turquoise, Blue, Smokey Gray-Blue
72213-0  72215-1
« Last Edit: Wed, 23 July 2014, 22:41:21 by sprit »
Offline FrostyToast
  • Litshoard
« Reply #45 on: Wed, 23 July 2014, 23:37:50 »
(Attachment Link)   (Attachment Link)
That pink is epic! Definitely going to be my first choice if I ever want to go miami!
Also, if you guys want to know a little secret, Sprit told me that you can get a super slim 3 layered case  :eek:
Put a comment on the order saying:
5mm + 5mm + 7mm = Model 3 Zuper Slim * special 3-layered edition
I don't know if these kinds of cases will be limited or not, however I was able to make a special order with sprit!  ;D
Offline dragonken
« Reply #46 on: Thu, 24 July 2014, 00:01:28 »
Hi Sprit,
Can I ask to ship together with gold spring for saving shipping fee?
Regards,
dragonken
Offline DanielT
« Reply #47 on: Thu, 24 July 2014, 04:35:13 »
Do you have color samples also for purple ?
Offline sprit
« Reply #48 on: Thu, 24 July 2014, 04:42:14 »
Hello!
I got,  but it's in the Factory Now  to produce Samples!   ;)
72261-0
Offline lotus1109
« Reply #49 on: Thu, 24 July 2014, 08:25:40 »
Hi Sprit!
I am still looking forward a poker case that suits my preference! :P
May I know if you can produce one with thinner bezel?
If yes then I would definitely get 1!
I am minimalist lover
