Author Topic: Duck Viper and Eagle Group Buy  (Read 1137535 times)
Offline geogga
  • gosh dang GH and their GBs
Re: Duck Viper and Eagle Group Buy
« Reply #1100 on: Fri, 21 November 2014, 09:31:31 »
Thanks Elton, Duck0113 and TrueCustom!
My Duck Eagle is built with lubed Clear switches, Mill-Max SIP sockets, switch stickers, 2x3x4mm leds and Cherry 1800 keycaps.
Beautiful! Are those cherry 1800 keycaps hard to get?
« Last Edit: Fri, 21 November 2014, 09:35:25 by geogga »
Offline Razor Lotus
« Reply #1101 on: Fri, 21 November 2014, 13:33:21 »
for those of you who've used red LEDs as your main LED (not the default red ones below the PCB), do you have to add a resistor or something? Does it work normally if you just solder the red LEDs in?
Thanks! :D
Offline Vintage
« Reply #1102 on: Fri, 21 November 2014, 16:58:33 »
wow, love the LED colors man.
CM QFR w/ MX Reds  | Logitech G900
Offline adrl
« Reply #1103 on: Fri, 21 November 2014, 17:48:28 »
Thanks! :D
Are you talking about red led for switches?
Mine works fine. I'm using 1.8mm leds though.
Offline paobit
« Reply #1104 on: Fri, 21 November 2014, 20:01:30 »
Hmm is it still possible to lube the clear switches if I already assembled mine?
« Reply #1105 on: Fri, 21 November 2014, 20:04:52 »
get a tub of lube and dip the whole board in it
« Reply #1106 on: Fri, 21 November 2014, 20:10:21 »
Do it.
Offline paobit
« Reply #1107 on: Fri, 21 November 2014, 20:33:27 »
LOL might as well. Also when I'm trying to get a different keyboard layout..I don't see arrow key options on the 02D program? Or am I missing something?
Offline trizkut
« Reply #1108 on: Fri, 21 November 2014, 21:12:51 »
You need to change your locale to korean to see the arrows.  You can use AppLocale to change locale just for the 02d.exe
Offline elton5354
« Reply #1109 on: Fri, 21 November 2014, 23:43:08 »
Finally got mine soldered up!
Offline cooldiscretion
  • Convicted guilty of being totally rad.
« Reply #1110 on: Fri, 21 November 2014, 23:47:08 »
Wow, Elton.  That is some superb ****, son.  :thumb:
Offline Sygaldry
  • Edema Ruh
« Reply #1111 on: Sat, 22 November 2014, 00:12:58 »
Whoa. Are those cyan LEDs?
I've got cyan LEDs waiting for the Octagon :thumb: :thumb:
(this is tempting me to swap from Blue Grey to Black...)
null
Offline elton5354
« Reply #1112 on: Sat, 22 November 2014, 11:12:46 »
Yeah they're the cyan LEDs from aliexpress.  I wonder if I can replace the bottom side LEDs with these ones?
As for the inserts..I'm still packing them.  2/3 is done. I'm thinking of dropping them off on Monday.
Offline JaccoW
  • Fire Typer!!
  • Keyboard is Lava!
« Reply #1113 on: Sat, 22 November 2014, 11:23:10 »
Excellent! The Orion will finally be complete. ;)
|||My other keyboards :
x
« Reply #1114 on: Sat, 22 November 2014, 11:24:52 »
unless they are smd i dont think you can
Offline whentheclouds
« Reply #1115 on: Sat, 22 November 2014, 14:59:20 »
elton, can you take a few pictures of your board with the light off? i want to see how the LEDs look in the dark
Offline bazh
« Reply #1116 on: Sat, 22 November 2014, 16:28:37 »
I still have to wait for sprit to get my lube and spring before I can get mine done :(
HHKB Pro2 white
Newbie again
Offline tjcaustin
  • King Klaxon
    • Buy stuff
« Reply #1117 on: Sat, 22 November 2014, 21:03:17 »
So whenever I press any row 5 key, this viper that I'm working on completely spazzes out and the key logger shows it actuating all ctrl, alt, super, space and n and b keys in a huge, lag inducing stream.  How do I make with the fix?
Offline adrl
« Reply #1118 on: Sat, 22 November 2014, 22:23:51 »
Hmmm.
Check traces? Check solder? Did you change anything for the firmware?
Offline geogga
« Reply #1119 on: Sat, 22 November 2014, 22:43:15 »
Pictures when that happen plz. Probably my end game cherry board...KMAC after and then a Duck Eagle.
Missed this GB and deeply regret it...
Offline elton5354
« Reply #1120 on: Sat, 22 November 2014, 23:18:39 »
Try resetting the firmware?
Potato pic with no light at all
It looks more green irl
« Last Edit: Sat, 22 November 2014, 23:20:31 by elton5354 »
Offline tjcaustin
  • King Klaxon
    • Buy stuff
« Reply #1121 on: Sat, 22 November 2014, 23:38:32 »
Hmmm.
Nope, no firmware changes.  I've also reflowed all switches affected.  The other vipers I've made so far work fine, traces I can see look fine, but I wasn't thinking to look before I put the plate on to check the top of the pcb.
Offline adrl
« Reply #1122 on: Sun, 23 November 2014, 02:04:04 »
Hmmm.
You try what elton said?
Offline tjcaustin
  • King Klaxon
    • Buy stuff
« Reply #1123 on: Sun, 23 November 2014, 02:07:51 »
Hmmm.
I totally didn't see that.  But either way, I did try, but couldn't figure out how to get the bootloader to workrephrasing - I have a grasp of the bootloader software and such, but couldn't get the keyboard into control mode or whatever it's called.  I'm not a very smart man sometimes.
Offline adrl
« Reply #1124 on: Sun, 23 November 2014, 02:26:54 »
To enter dfu mode, you have to hold caps lock while plugging in usb.
Offline deci
« Reply #1125 on: Sun, 23 November 2014, 03:33:27 »
yeah also dont forget to install the avr drivers after you first put it in bootmode or flip wont be able to find it. that tripped me up for a little bit.
Offline paobit
« Reply #1126 on: Sun, 23 November 2014, 14:23:18 »
Offline tjcaustin
  • King Klaxon
    • Buy stuff
« Reply #1127 on: Sun, 23 November 2014, 17:03:43 »
Ok, flip sees keyboard and that's fine, I can get it in bootloader, but the o2d keymapper isn't saving the hex file I create now.  It says run time error '76' path not found
Offline adrl
« Reply #1128 on: Sun, 23 November 2014, 17:19:18 »
Rename it to something else.
The default naming scheme causes that.
Offline tjcaustin
  • King Klaxon
    • Buy stuff
« Reply #1129 on: Sun, 23 November 2014, 17:31:54 »
Now I know it isn't firmware based.  Time to disassemble and check under plate.
« Reply #1130 on: Sun, 23 November 2014, 17:51:25 »
Sorry to hear you're having troubles with your board.  I wonder if maybe some of the diodes were soldered on backwards before they shipped you the PCB.
If polarity is marked on the PCB, it might be worth checking over.
Offline feizor
« Reply #1131 on: Mon, 24 November 2014, 01:08:59 »
That's not a hardware issue.  Just create a new text file and save as  viper.hex then save over that file in o2d keymapper. The software has issues creating new files.
Offline tjcaustin
  • King Klaxon
    • Buy stuff
« Reply #1132 on: Mon, 24 November 2014, 01:32:15 »
I did that, I was able to reflash the firmware fine.  Same issues, though.
Offline feizor
« Reply #1133 on: Mon, 24 November 2014, 01:53:28 »
Ah sorry,  I read that out of context.
Offline feizor
« Reply #1134 on: Mon, 24 November 2014, 01:59:21 »
Are all the diodes soldered the right way?
Offline tjcaustin
  • King Klaxon
    • Buy stuff
« Reply #1135 on: Mon, 24 November 2014, 11:27:04 »
Yep, all pointed to the right side mods
Offline tjcaustin
  • King Klaxon
    • Buy stuff
« Reply #1136 on: Mon, 24 November 2014, 14:31:49 »
Something I just noticed, the caps LED is blinking what seems to be an error code and won't turn on solid when I press the caps lock
Could 2 quick flashes mean a specific fault?  If so, what?
Offline feizor
« Reply #1137 on: Mon, 24 November 2014, 15:13:32 »
The capslock led blinks indicate the layer you are currently on.  One blink for layer one,  two blinks for layer two etc.
So it would seem you are currently stuck on layer two. Try using mfn(3) + 1 to get back to layer 1.  ie quickly press mfn three times,  holding it down the third time and pressing the number 1.
Offline tjcaustin
  • King Klaxon
    • Buy stuff
« Reply #1138 on: Mon, 24 November 2014, 15:18:16 »
Ok.  Dang, I was hoping it would help diag.  Oh well.
Offline Sygaldry
  • Edema Ruh
« Reply #1139 on: Tue, 25 November 2014, 16:19:03 »
So um... those of you with Cherry profile caps (BSP or GMK) where are you getting 7u spacebars?
IMSTO is the only place I can find one (and they cost a boatload for shipping 5 dollars for the spacebar and 10 for shipping)
null
Offline MrChunky
« Reply #1140 on: Tue, 25 November 2014, 18:02:03 »
I think the ones on IMSTO's website are only for purchase with a BSP set, you can't buy them separately. At least that's what he said initially. That's how I got mine by the way.
Ivan's GMK sets also come with 7u spacebars.
Offline elton5354
« Reply #1141 on: Tue, 25 November 2014, 18:47:09 »
I've shipped most of the inserts out yesterday.  I have 10 or so left from the bottom of the list.  I haven't invoiced the ones that needs me to invoice yet. I'll do it tonight..
If you want them..PM me as I want to do them together at once.
Offline Fnzzy
« Reply #1142 on: Wed, 26 November 2014, 05:57:44 »
Sounds good. :thumb:
Now I need some double sided tape...
« Reply #1143 on: Wed, 26 November 2014, 12:56:57 »
Awesome! Now I need to decide if I should make one of my sets look frosted.
Offline JaccoW
  • Fire Typer!!
  • Keyboard is Lava!
« Reply #1144 on: Wed, 26 November 2014, 13:35:30 »
I have ordered two sets and intend to frost one of them. Should be able to post pictures when I get them.
x
Offline adrl
« Reply #1145 on: Thu, 27 November 2014, 15:01:03 »
Thanks Elton Chan!
Received my inserts.
Potato Pics
Don't forget to peel of the plastic!
Offline Fnzzy
« Reply #1146 on: Sat, 29 November 2014, 11:06:40 »
Got my inserts today, thanks Elton! Board looks a lot more complete now! Only waiting for cyan LEDs and the courage to replace the side LEDs :x
Offline Sygaldry
  • Edema Ruh
« Reply #1147 on: Sat, 29 November 2014, 11:39:12 »
Whoa all these boards look amazing with the inserts.
I see a lot of people want to try frosting/sanding these but someone should try laser engraving them to make interesting light designs!
null
Offline rockhawksam
  • I'm a big dirty **** Hawk
    • tanglingstars.com
« Reply #1148 on: Sat, 29 November 2014, 12:03:27 »
Are you going to desolder/resolder the whole board to put the LEDs in?
Offline Synjin
« Reply #1149 on: Sat, 29 November 2014, 12:10:16 »
How do you frost these? I was just going to sand it with a fine grit but im not sure if tharl work
