Author Topic: [IC] KMAC PCB + PLATE (NerD)  (Read 19708 times)
Offline Blackehart
Re: [IC] KMAC PCB + PLATE (NerD)
« Reply #50 on: Wed, 17 September 2014, 16:50:30 »
If I got this correct...
We can get a different pcb (the nerd), but we cant get a plate.
We can get a polycarbonate plate.
Will this polycarbonate plate fit in the kmac's aluminum housing?
« Reply #51 on: Wed, 17 September 2014, 16:54:52 »
ya just no alu plate
Offline Blackehart
« Reply #52 on: Wed, 17 September 2014, 18:19:11 »
Any chance an uncultured swine such as myself could get the plate and pcb assembled with switches through GON?
« Reply #53 on: Wed, 17 September 2014, 18:23:02 »
Probably. just ask him
Offline GON
  • Skype ID : GonsKeyboardWorks
    • GONsKeyboardWorks
« Reply #54 on: Wed, 17 September 2014, 21:57:52 »
Why not? ;)
Even though I have made/assembled/tuned HUNDREDs of keyboards for others, I myself don't have a full-tuned Custom Keyboard now.
So Ironical!
Offline Dreamre
    • kbdlife
« Reply #55 on: Thu, 18 September 2014, 09:10:52 »
Would it be possible to just have the resistors soldered on (of course for an additional cost)? Need this done for 2 PCBs!
Offline GON
    • GONsKeyboardWorks
« Reply #56 on: Thu, 18 September 2014, 10:04:49 »
Of course, I will add soldering options products too. ;)
So Ironical!
Offline GON
    • GONsKeyboardWorks
« Reply #57 on: Thu, 18 September 2014, 10:06:07 »
I'm designing a 1.5T Polycarb multi-layout Plate for KMAC. ;)
You guys will be able to use ISO layout with your KMACs. If this GB is successful.
So Ironical!
Offline GON
    • GONsKeyboardWorks
« Reply #58 on: Thu, 18 September 2014, 11:21:30 »
We've got an approval for this GB!
Now I'm taking orders
Refer to the following link
http://geekhack.org/index.php?topic=62878.msg1473056#msg1473056
So Ironical!
Offline Blackehart
« Reply #59 on: Thu, 18 September 2014, 17:57:26 »
ordered
Offline GON
    • GONsKeyboardWorks
« Reply #60 on: Sat, 20 September 2014, 19:02:02 »
Curious why anyone would make a custom plate without the ability to remove switch tops. Is there a negative side of doing that?
Cost of the extra cuts maybe and I've heard a few people say they think the cutouts aren't as stable.
Cost is not an issue. That makes no difference. ;)
So Ironical!
« Reply #61 on: Sat, 20 September 2014, 19:40:01 »
Any chance of an alu plate? I just don't really dig PC as a case material.
Offline GON
    • GONsKeyboardWorks
« Reply #62 on: Sun, 21 September 2014, 00:54:12 »
In that case, the plate should be 2T /w CNC-machining... that means cost will increase. I think it should be about $55 for 2T Plate.
If the plate does not support multi-layout including ISO, 1.5T will do but, in case it should support all layouts in a single plate design, 2T design is needed = cost increase.
If you do want AL 2T Plate, I will make it. But the Plate will have out line of KMAC1 Plate for compatibility with KMAC1/1.2/2.
Let me know.
GON
So Ironical!
