Author Topic: Are there any TKL Rubber Dome Boards?  (Read 22953 times)
Offline davkol
  •  Post Editing Timeout
Re: Are there any TKL Rubber Dome Boards?
« Reply #50 on: Tue, 05 August 2014, 13:43:26 »
Olympus CV-160
Offline Parak
« Reply #51 on: Thu, 07 August 2014, 10:18:57 »
BTW I'm not in a country under embargo or anything like that (technically, I'm in France).
Do you have some other link?
Yep:
http://www.ebay.fr/sch/i.html?_sacat=0&_nkw=olympus+cv-160
Offline spiceBar
    • ChessTiger.com
« Reply #52 on: Thu, 07 August 2014, 10:45:49 »
Yep:
OK so it's a keyboard for an endoscopy system. We are not even sure it is compatible with PC or Mac. :)
Offline noway
« Reply #53 on: Thu, 07 August 2014, 17:10:17 »
...OK so it's a keyboard for an endoscopy system. We are not even sure it is compatible with PC or Mac. :)
Not sure I could stomach a keyboard designed for an endoscopy but it would be better than having one designed for a colonoscopy as an Endgame Keyboard.
Offline Lu_e
« Reply #54 on: Thu, 07 August 2014, 17:20:48 »
http://i.imgur.com/NXS0ihz.jpg
Just say NO to ABS keycaps
Offline hasu
  • @tmk
« Reply #55 on: Fri, 08 August 2014, 03:37:49 »
FKB8769-511 appers to be a decent rubber dome TKL.
http://www.diatec.co.jp/shop/det.php?prod_c=1347
Offline Belfong
« Reply #56 on: Fri, 08 August 2014, 04:19:34 »
Is the ThinkPad USB that I have considered TKL? It's odd because it does have Numpad but it doesn't have the other middle layer Home-End-Page Up-Down cluster.
http://geekhack.org/index.php?topic=49084
Offline davkol
« Reply #57 on: Fri, 08 August 2014, 05:14:52 »
90% layout.
Offline dante
« Reply #58 on: Fri, 08 August 2014, 06:30:58 »
I asked about this a while back and a couple people said it sucked.
