Author Topic: Cheapest source of mx browns  (Read 1457 times)
Offline Prelim
« on: Sun, 03 August 2014, 05:33:39 »
Hi guys,
Is the Compaq MX11800 the cheapest source for mx browns or are other ones available at even lower prices?
2x GH60 revC - lubed Linjärs 65g / lubed H1s 65g with SPRIT 5mm acrylic plate | Dolch PAC - Cherry housing / Gateron sliders 65g and QMK clips | Raptor K1 G80-1890 stock
Floating on Cherry/GMK caps
Offline Oobly
Re: Cheapest source of mx browns
« Reply #1 on: Sun, 03 August 2014, 15:03:20 »
Hi guys,
A second hand MX11800 is probably the cheapest, but Mechanical Keyboards sell the loose switches in "bulk" for a decent price (and you don't have to desolder them from an existing board): http://mechanicalkeyboards.com/shop/index.php?l=product_list&c=55
Buying more keycaps,
it really hacks my wallet,
but I must have them.
« Reply #2 on: Sun, 03 August 2014, 16:44:26 »
You can sometimes get G80-8113 and 8200 for cheap. I got two G80-8200 HUAUS for $44 shipped once. Usually you can resell the keycaps for an even cheaper price.
Offline Prelim
« Reply #3 on: Mon, 04 August 2014, 09:54:29 »
thanks guys, guess the mx 11800 is still the better choice then  :thumb:
