Author Topic: Do all noppoo choc mini keyboards have wireless functionality?  (Read 4765 times)
Offline P3TC0CK
« on: Sun, 03 August 2014, 06:12:43 »
Just found out they were while I was looking at 84 key keyboards for someone else. I can't believe I didn't read or hear about it when I was asking around about wireless keyboards. Looks like it's built by the same company as my plum keyboard. Case material, feet, symbols, and the wireless adapter are all the same.
Hope buyer's remorse doesn't set in  :confused:
petcock
[pet-kok]
noun
1. a small valve or faucet, as for draining off excess or waste material from the cylinder of a steam engine or an internal-combustion engine.
Offline Sagii
  • Time to bust some nails
Re: Do all noppoo choc mini keyboards have wireless functionality?
« Reply #1 on: Sun, 03 August 2014, 06:34:24 »
No, not all Choc minis have wireless capability. AFAIK there're only those who were sold on Massdrop a few weeks ago that are actually wireless!
Offline SlotH42
  • one slow step for sloth
« Reply #2 on: Sun, 03 August 2014, 11:40:23 »
the wireless and the wired are both on Massdrop right now. I'm thinking about the wireless one for work, they seem nice in blue or red with the back light option.
MP-GBL4 (red) Poker II (clears) Realforce R2TL 55g
Offline Sagii
« Reply #3 on: Sun, 03 August 2014, 12:05:56 »
The nice thing is that they actually come with POM keycaps, even if they are backlit ^_^
Offline P3TC0CK
« Reply #4 on: Sun, 03 August 2014, 17:07:55 »
I think the 15 dollar difference is absolutely worth it. It uses the same wireless set up as my plum morphling keyboard, and the fact that you're able to use any mini USB cable you want is in my opinion enough to warrant 15 dollars more, let alone the bonus wireless functionality you get. I'm not sure if the caps are actually POM on the wireless ones though. My keyboard were listed as POM in the seller stats but in the images for my keyboard they were listed as ABS.
The keycaps on the wireless listing look like the same material as mine:
petcock
[pet-kok]
noun
Offline Oobly
« Reply #5 on: Mon, 04 August 2014, 02:47:43 »
I believe they are POM, but coated like many backlit ABS sets. You can do the water test to check (if they float they're ABS, sink they're POM).
I don't like the fact that they're coated, I'd rather feel the POM material directly.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Offline P3TC0CK
« Reply #6 on: Mon, 04 August 2014, 04:03:53 »
They sink. Strange, I don't know why the description for my keyboard would list them as ABS in their advertising.
petcock
[pet-kok]
noun
Offline Novus
  • Formerly the1onewolf
  • Mondai nothing~
« Reply #7 on: Mon, 04 August 2014, 04:40:41 »
Likely because they were confused.
I think noppoo has sold keyboards with all three keycap materials or at least from what I've read.
Offline Sagii
« Reply #8 on: Wed, 06 August 2014, 04:15:41 »
Yep, you're right.. the "older" backlit (that are not from the massdrop sales) were ABS, while the nonlit "older" were PBT, and then we have the massdrop ones that are POM no matter what ^^  there might be more variations though, I dunno
Offline shawn24
« Reply #9 on: Wed, 06 August 2014, 10:03:57 »
the new one with blue tooth has the box clearly claims that it is a double-model keyboard(wired and wireless)
and also it has vacancy to install AAA battery
Offline Remedy
« Reply #10 on: Wed, 06 August 2014, 11:39:40 »
What model has bluetooth connectivity? The wireless models listed on massdrop and amazon right now both have 2.4GHz ...
