Author Topic: Model F problem  (Read 2639 times)
Offline 1391406
Model F problem
« on: Mon, 04 August 2014, 09:17:57 »
I have two terminal Model F's, and it seems my backup is experiencing a curious issue. My right arrow is registering as both, the right arrow and Numpad 4, resulting in the number 4 being displayed followed by a cursor movement to the right when actuated. Aqua Key Test confirms that it's registering both keys. HID listen displays the following when the right arrow is actuated:
r6B +5C d5C r6A +4F d4F
rF0 r6B -5C u5C rF0 r6A -4F u4F
I've already tried re-seating the key cap multiple times to no avail. I then tried to remap the right arrow to, well, the right arrow, but I don't know how to un-assign Numpad 4 to it.
Any ideas?
Offline E TwentyNine
    • Some of My Keyboards
Re: Model F problem
« Reply #1 on: Mon, 04 August 2014, 09:54:27 »
Next thing I would do is open it up and clean it.
Re: Model F problem
« Reply #2 on: Mon, 04 August 2014, 09:55:37 »
Though if you're using Soarer's stuff and you don't use the numpad I believe you can map a key to nul.
Offline 1391406
Re: Model F problem
« Reply #3 on: Mon, 04 August 2014, 10:02:16 »
I'll try that for the heck of it.
Okay that worked, which sucks because I actually do use the Numpad from time to time. Thanks for the suggestion, by the way.
« Last Edit: Mon, 04 August 2014, 10:06:45 by 1391406 »
Re: Model F problem
« Reply #4 on: Mon, 04 August 2014, 10:33:01 »
Odd that it should manifest in the 4 and not the 1.
Could you have debris floating around in the underworld?
- D Trump 2026-10-24
Offline 1391406
Re: Model F problem
« Reply #5 on: Mon, 04 August 2014, 11:06:25 »
Quite possibly, as this is the Model F I performed the ANSI mod on.
« Last Edit: Mon, 04 August 2014, 18:25:38 by 1391406 »
Offline 1391406
Re: Model F problem
« Reply #6 on: Mon, 04 August 2014, 18:26:02 »
By the way, what's the best way to clean the PCB? Damp cloth? No alcohol, I assume.
Re: Model F problem
« Reply #7 on: Mon, 04 August 2014, 22:23:20 »
alcohol should be fine.
Offline 1391406
Re: Model F problem
« Reply #8 on: Tue, 19 August 2014, 23:31:59 »
UPDATE:
Okay, so the problem turned out to be that I had both, my F-122 and AEK plugged in simultaneously. Once I unplugged the AEK, the F-122's key registration issues resolved themselves.
Re: Model F problem
« Reply #9 on: Wed, 20 August 2014, 07:17:54 »
It has been my experience that a Teensy does not play well with others, and that only one Teensy is allowed at a time.
