Author Topic: Removing paint from caps  (Read 1873 times)
Offline Demetrium
« on: Mon, 04 August 2014, 16:56:44 »
I've got a CMStorm Trigger and the black coating on the WADS keys is starting to rub off. I sanded off the top of of a key to test to see how it would look but it seems like there's a lot of black paint on the inside blocking the back-light from coming through.
I kind of want to try taking off all the paint to see what a "clear" key would look like. If I left them overnight in rubbing alcohol or something like that would it take the black out? Any advice/suggestions from modders?
Re: Removing paint from caps
« Reply #1 on: Mon, 04 August 2014, 16:59:31 »
For a more consistent look, you might be better off getting hold of 3 transparent keycaps.
