Author Topic: Monoprice 9433  (Read 3418 times)
Offline Upcboy
    • Perfect Aim
Monoprice 9433
« on: Wed, 06 August 2014, 12:31:23 »
I was able to talk my boss into purchasing me a Monoprice 9433 Any one have any experience with this board? Any idea what the modifier sizes are? The Windows key seems tiny. Also Any suggestions for cheap Blank keycaps?
Re: Monoprice 9433
« Reply #1 on: Wed, 06 August 2014, 12:35:21 »
There was some discussion about it here
http://geekhack.org/index.php?topic=44659.0
Offline Upcboy
    • Perfect Aim
Re: Monoprice 9433
« Reply #2 on: Wed, 06 August 2014, 13:26:45 »
I had a look over it. but they don't really decided what size the modifiers at the bottom are... is there a way to figure out other than guessing? Any suggestions on Blank keys?
« Last Edit: Wed, 06 August 2014, 13:34:58 by Upcboy »
Offline engicoder
Re: Monoprice 9433
« Reply #3 on: Wed, 06 August 2014, 13:32:35 »
Whoops.
Re: Monoprice 9433
« Reply #4 on: Wed, 06 August 2014, 15:18:19 »
appears to be 1.5 / 1 /1.5 ---space--- 1.5 / 1 / 1 / 1.5
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
Re: Monoprice 9433
« Reply #5 on: Wed, 06 August 2014, 15:24:58 »
I would concur with this which would make the spacebar 6 unit.  That is kind of a tough size to find.  Not included in GB's very often.
The two common space bars are 6.25 which is 1.25 for all modifiers and 7 unit which is 1.5/1/1.5/7/1.5/1/1.5 iirc.
Offline AKmalamute
  • HHKB Scrub
Re: Monoprice 9433
« Reply #6 on: Wed, 06 August 2014, 15:42:39 »
While the one I bought was from the classifieds here, I'm 90% sure that's what I type on at home, and yes ... that's the layout. 6x spacebar like Melvang says.
HHKB-lite2, Dvorak user
Re: Monoprice 9433
« Reply #7 on: Wed, 06 August 2014, 15:46:56 »
though I'm told that signature plastics can make them. If you need one you can check their inventory or ask them about having one made.
Offline Melvang
Re: Monoprice 9433
« Reply #8 on: Wed, 06 August 2014, 15:51:19 »
Fair warning though on having SP make something.  Even if they have a mold for it, anything that has to be manufactured has a minimum $100 cost.  They will make one for you, its just going to cost that much.
Offline Oobly
Re: Monoprice 9433
« Reply #9 on: Wed, 06 August 2014, 16:52:42 »
If you just want blanks, you don't need to replace the spacebar, so any blank set that has 1.5x mods and a few extra 1x bottom row caps will do. Unfortunately I can't think of any cheap blank black sets that have those.
Even Ivan's GB for thick blank black PBT caps doesn't have 1.5x mods since they didn't reach MOQ.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Re: Monoprice 9433
« Reply #10 on: Wed, 06 August 2014, 21:03:01 »
You get get ABS or PBT blanks for $1 each from SP. They have a variety of colours in stock, and 1x and 1.5x are common sizes:
http://keycapsdirect.com/key-capsinventory.php
Offline Upcboy
    • Perfect Aim
Re: Monoprice 9433
« Reply #11 on: Wed, 06 August 2014, 23:01:09 »
I dont plan to spend much on this keyboard since it is a cheap keyboard to get me by for now. I might Just replace the qwert part with blanks and leave the modifiers alone.
Offline Oobly
Re: Monoprice 9433
« Reply #12 on: Thu, 07 August 2014, 06:03:00 »
In that case, these may look nice: http://www.banggood.com/PBT-87-Blank-White-Key-Caps-For-Cherry-MX-Keyboard-p-84084.html
I was going to recommend the blank black POM set from Banggood (they used to have an 84 key set and an 87 key set), but I don't see it listed any more unfortunately.
Offline Oobly
Re: Monoprice 9433
« Reply #13 on: Fri, 08 August 2014, 02:54:16 »
