Author Topic: ErgoDox Acrylic Case?  (Read 4160 times)
Offline jameslr
« on: Wed, 06 August 2014, 23:06:28 »
So, given that you can buy Edox PCBs for $40 / set from MK.com, what would it cost to source a plain acrylic case? Sorry if this is derailing your sale thread, but I'm definitely interested in building an Edox with your kit.
CM Novatouch | Filco MJ2 TKL w/ HID Lib | REΛLFORCE 87U 55g | CM QFR
Re: ErgoDox Acrylic Case?
« Reply #1 on: Wed, 06 August 2014, 23:18:58 »
I don't know who would be willing to get cases cut. That is the only missing piece of the puzzle. If someone can do that, that would be awesome!
Offline jameslr
« Reply #2 on: Wed, 06 August 2014, 23:37:15 »
I found a free design for a litster edox case that you can get cut on Ponoko for around $23 plus shipping. Might be cheaper if you use basic transparent acrylic, but I chose dark blue. Total for an edox without switches or caps with your kit would be around $110 assuming you source the PCBs and teensy from MK.com ($39 and $23 respectively shipping included).
Edit: I'm not sure which thickness of acrylic you need. But that was using 3mm blue acrylic. I'm assuming you'll need thicker acrylic for the material so that price probably isn't accurate.
« Last Edit: Wed, 06 August 2014, 23:55:30 by jameslr »
Offline byker
  • Literally Canada
« Reply #3 on: Wed, 06 August 2014, 23:39:56 »
Link please?  :D
Offline jameslr
« Reply #4 on: Wed, 06 August 2014, 23:43:22 »
Sorry JD, we should probably move this discussion to making stuff forum. Here's the link for reference though.
http://www.ponoko.com/design-your-own/products/ergodox-top-and-bottom-pieces-litster-case-11458
« Reply #5 on: Thu, 07 August 2014, 00:35:27 »
That is actually just the top and bottom plates for the case, which should be 3mm. You were missing the 3 middle layers, which should all be 5mm thick.
Offline byker
  • Literally Canada
« Reply #6 on: Thu, 07 August 2014, 00:38:15 »
Woah! This thread got moved!  :p
Could you use those, then put a spacer in between? Like the JD40?
« Reply #7 on: Thu, 07 August 2014, 00:42:52 »
You would at minimum also need the switch plate (layer 3). And that's the one that would add the most cost, due to the number of cuts.
Offline byker
  • Literally Canada
« Reply #8 on: Thu, 07 August 2014, 00:50:26 »
Czarek from deskauthority seems to have one of the cheapest options: http://falbatech.pl/prestashop/index.php?id_category=12&controller=category
ErgoDox Aluminium CNC switch plate for 15 Euros
Offline jameslr
« Reply #9 on: Thu, 07 August 2014, 07:44:36 »
Yeah and after looking at his case - I think I'd rather have the one he makes from PVC. It's 50 Eur + shipping and taxes. Not bad at all considering it's CNC machined. It looks like he's going to have a limited run of black PVC very very soon per his thread on DT. Still, with shipping and taxes bringing it to almost 70 Eur ($95 usd) you might be better off just buying the MD kit since you get switches with it. Unless you're in Europe of course, then it's a great deal.
« Reply #10 on: Thu, 07 August 2014, 08:50:44 »
Those black ergodox PCB's are awesome.....
Offline byker
  • Literally Canada
« Reply #11 on: Thu, 07 August 2014, 11:50:10 »
Yeah those are pretty cool!  :thumb:
