Author Topic: ErgoDox assembly blunder  (Read 2934 times)
Offline kwayso
« on: Fri, 08 August 2014, 14:45:04 »
I am currently assembling an ErgoDox kit (massdrop) and I have committed an embarrassing mistake.  I soldered the Teensy board on backward (all 24 pins), and I have been having a very hard time desoldering it.  I have tried a desoldering braid, solder sucker, and a desoldering iron with little success.  I just can't seem to remove all the solder from the joints.  Does anybody have any tips or obvious things to do?  I am starting to reach my wits end.
Offline FrostyToast
  • Litshoard
Re: ErgoDox assembly blunder
« Reply #1 on: Fri, 08 August 2014, 14:46:30 »
If you can't suck up the solder, then you should put a little more solder on the joint which will make it easier to suck it all up.
Sometimes the amount is just to small to suck up.
Quote from: elton5354
« Reply #2 on: Fri, 08 August 2014, 14:50:50 »
Yeah, that's a hard one. I tried removing the Teensy from my first Phantom without much success.
But I now have a Hakko 808 desoldering gun. If you don't mind paying shipping both ways, I will remove the Teensy for you, free of charge.
Or, I have an extra PCB (only one side) that I bought from MD for $22, and I would sell it to you for what I paid. Always there as a backup plan if you want me to try removing the Teensy from yours first.
Offline absyrd
  • CPT HYPE PADAWAN
« Reply #3 on: Fri, 08 August 2014, 14:51:36 »
Hell of a kind offer here. :D
Offline kwayso
« Reply #4 on: Fri, 08 August 2014, 20:49:34 »
PM sent to jdcarpe, and I want to be sure to publicly thank you for the kind offer!
Offline Grendel
« Reply #5 on: Fri, 08 August 2014, 21:04:18 »
Pretty much the only way to get it out w/o specialized equipment is to cut it off the board (cutting all pins through the plastic spacer) and then pulling the pins one by one. Not for the faint of heart :/
- I'm game !
« Reply #6 on: Fri, 08 August 2014, 21:12:15 »
You're welcome. :)
Yeah, that's what I ended up doing with the Phantom. After lifting a pad or two. You can ask boost, that Phantom PCB I gave him was pretty messed up. RIP Phantom #1. It gave its life so that the Skeldon case could live.
« Reply #7 on: Fri, 08 August 2014, 21:36:46 »
I had to do that one one build: it was no fun at all.
I would also like to mention that it can depend on what solder you use. I received one ergodox that I had to desolder and it was tough! When I resoldered it, I desoldered a few components just to check and it was very easy. I can send you some strings of my solder if you like, that way should you need to make repairs or solder something else you'll have easy-to-desolder stuff.
« Reply #8 on: Sat, 09 August 2014, 13:17:11 »
PM me I'll give you my address.  I have a solder reflow station that can be used to desolder the device from the PCB.
::edit:: or just keep me in mind lol
« Last Edit: Sat, 09 August 2014, 13:22:18 by Binge »
