Author Topic: keyboard with integrated arrow and numpad  (Read 1558 times)
Offline optoabhi
« on: Sat, 09 August 2014, 21:32:21 »
Are there any keyboards that have the layout like quickfire tk ?
Online Findecanor
Re: keyboard with integrated arrow and numpad
« Reply #1 on: Sun, 10 August 2014, 12:00:09 »
Roccat Arvo (rubber dome) and maybe one or two DIY Asian boards.
Offline absyrd
  • CPT HYPE PADAWAN
« Reply #2 on: Sun, 10 August 2014, 12:09:23 »
Plum 96
Some Phantoms
Offline optoabhi
« Reply #3 on: Sun, 10 August 2014, 13:46:18 »
I am sorry I dint understand what you meant by "some phantoms"
The plum layout has the Insert/Home/ PgUP in the same row as a standard keyboard. which is good. I wanted that. The quickfire TK has it one row down and that may cause a issue.
Offline Oobly
« Reply #4 on: Mon, 11 August 2014, 02:37:57 »
The Phantom is a custom keyboard with many possible configurations that uses a Teensy 2.0 as a controller. The PCB and mounting plate support having TK style layout, so some of them have been configured like that. You could get a Phantom PCB and plate and put it together how you want, but you'd have to build your own case or get a case from a TK or other board with that layout.
I agree about the PLUM layout being better. I have a Roccat Arvo and found myself hitting the wrong keys when editing text. I don't actually use the numpad so I prefer TKL layout since it doesn't have the extra keys in between the arrows and edit group so I can go by touch better.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
