Author Topic: VOTE: CHERRY MX GREEN or BUCKLING SPRING  (Read 15533 times)
Offline Oobly
Re: VOTE: CHERRY MX GREEN or BUCKLING SPRING
« Reply #50 on: Mon, 11 August 2014, 09:11:56 »
UNICOMP IS SELLING buckling spring KEYBOARD FOR UNDER 100$  SO WHY NOT BUY FROM THEM?
i am trying to build the ultimate gaming keyboard so first i like to know what most gamers prefer to type on.
Then I guess you should have asked "What keyswitch do gamers like most".
For most I guess it would be MX Reds or Blacks. For me and some others, MX Clears. There are already a lot of gamer boards with Reds. That's why I'd offer one with Blacks or Clears.
I like Clears because they are very tactile, but they don't have hysteresis (actuation and reset points in different places) and you can "hover" with them like you can with linear switches (MX Reds and Blacks) due to the actuation point being just below the tactile bump, so you can use it as a reference. That makes them nice for gaming AND typing for me.
All switches can be used for gaming and it's largely a personal preference, but some switches have physical limitations which make them "less good". Buckling Springs and MX "clicky" switches like Blues and Greens have hysteresis. Buckling Spring switches are also usually harder to press and require further movement before actuating than most others. Topre switches have a force curve that makes it hard not to bottom out when you press them, whcih makes it difficult / impossible to "hover" them. Normal rubber dome keyboards actuate on bottom out, so you have to press the key all the way to the bottom to actuate it.
FranBunnyFFXII mentioned that the reason they want a buckling spring keyboard for gaming is the tactility, but they may not have been aware of MX Clear switches which have tactility, but not hysteresis and actuate 2mm down and can be "hovered". It's not a good idea to make a product based on just one person's opinion, so it's good that you're asking here. You'll get lots of opinions and most of them will be different from each other  ;) So don't just go by my opinion, either.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Offline domoaligato
« Reply #51 on: Mon, 11 August 2014, 09:34:46 »
I personally game with my gh60 with ergo clears. If I had a 60% bs board then I would use it.
« Last Edit: Mon, 11 August 2014, 09:37:08 by domoaligato »
« Reply #52 on: Mon, 11 August 2014, 10:20:24 »
60% BS has been a dream of mine for a while  ;D
Offline FoxWolf1
  • 154
« Reply #53 on: Mon, 11 August 2014, 12:09:06 »
Neither.
I mean, I suppose that if I had to choose between only these two, and specifically with gaming in mind, I'd pick the buckling spring, since the tactile and auditory feedback of BS is more precisely aligned with the activation than, AFAIK, any other switch, but I'm not super enthusiastic about either BS or MX Green.
Of course, if you do go the BS route for a gaming keyboard, you will have to work out a way of implementing acceptable rollover, unlike Unicomp. An NKRO membrane (there are a couple of Korean market dome keyboards with this) or Model F-style capacitive sensing would do. A "gaming optimized matrix", on the other hand, is not acceptable, since these are just 2KRO with marketing bull****, even if they claim a large rollover number by measuring incorrectly (rollover is measured by the worst-case scenario, not the best).
Offline LechnerDE
« Reply #54 on: Mon, 11 August 2014, 12:15:01 »
Why are you guys so focussed on the gaming part?
From the OP:
NEW:" my understanding that BUCKLING SPRING is for GAMING why some of you say its not for gaming?
is it or isn't it?
i am developing a new gaming keyboard...
Yeah, I read that, but just because it says gaming doesn't mean I can use it for whatever I want!
Or are we talking about an Orbweaver thingie and not a regular TKL/Fullsize board here?
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #55 on: Mon, 11 August 2014, 13:38:20 »
i don't game, but do some serious typing...........
bs-- not even a contest :cool:
........and yes i have both
Luga G80-1865/MX Reds + Dolch G80-1813/MX Blues + G80-3700HQAUS + DK9008G2 Pro/MX Browns Thick PBT + DK9008G2 Pro/MX Clears Thick PBT +  QFR TKL/Ghetto Greens + Cherry G80-1800/MX Blues + IBM Model M SSK Bolt Modded + IBM Model M + IBM Model F + IBM AT F + Cherry G80-1000 (HAD)/MX Vintage Blacks + Razer BWU/MX Blues + Leading Edge DC2214/Blue Alps + Compaq MX11800/Browns + Chicony 5181/Monterey Blues + Chicony 5161/MX Black Cherry Clone + Focus 2001/White Alps + Chicony 5191/White Futabas + Olivetti ANK27-101 + Dell (Old Logo) AT101/Black Alps + NMB RT8255C+/Black Space Invaders + Unitek K260/Green Alps + Apple M0116/Orange Alps + AEK II M3501/Cream Alps + AEK M0115/Orange Alps + NEC  APC412/Blue Sliders + NEC APC410/Blue Sliders + Omnikey /White Alps + Wang/Yellow Alps (Omrons) + Laser/White SMK + Fame/Blue Aruz + AEK II M3501/Salmon Alps + Zenith ZKB-2R/Green Alps + Wang 724/Orange Alps + DK1087/Green Alps + Zenith ZKB-2/Yellow Alps + Dell Old Logo AT101/Salmon-Pink Alps + Leading Edge AK1012/White SMK's + Magitronic SK-1030/White (Linear) Futaba's + Packard Bell/White (Clicky) Futaba's + Datacomp DFK101/White  Alps + SGI AT101/Dampened White Alps + NMB AQ6RT-72511/Grey Space Invaders (Hi-Tek) + Datacomp/Blue Alps + Phillips 2812/White Space Invaders (Linear) + Dah Yang K251/Vintage MX Blues + Chicony 5161/DS Caps/Vintage MX Blue + Archie-NMB AQ659ZRT-725/Black Space Invader (Tactile) + IBM Model M 71G4644 (RD) Bolt Modded with Soarers Converter + IBM Model M Silver Label 1390131 + Cherry G80-1501/Vintage MX Clears + Focus FK8000/Linear Futabas + Gateway 2000 Anykey Programmable/Maxi-Switch + Dell GY13PVAT101/Dye Sub Caps/Salmon Alps + Chicony 5161/White Alps + AST K0B101/Slider over RD + Qtronix QX-32H + Everex/NMB RT8255CW+ Black Space Invaders-Split Erase + Tandon/NMB AQ659ZRT-101A/Beige Space Invaders + Cherry G80-11903 MNRUS/MX Blacks + Apple IIGS A9M0330/SMK Whites + WYSE PCE/MX Blacks + Chicony 5160AXT/Clicky Futaba + Cherry G80-0528/Vintage MX Blacks + Dell AT101/Linear (Modded) Black Alps+Topre 55g
Offline mapple
« Reply #56 on: Mon, 11 August 2014, 14:00:07 »
buckling spring - cause i love them
In God We Trust
Offline Kravid
« Reply #57 on: Mon, 11 August 2014, 14:12:01 »
BS please
Offline Quardah
    • DeliTech
« Reply #58 on: Mon, 11 August 2014, 14:23:32 »
Yeah for gaming
Mx Clear
Green and BS are bad choices...
See my blog here : https://delitech.live
Poker II - Brown MX
Ducky One II TKL - Silver MX
TEX Shinobi - Clear MX
Offline osman99
  • follow the smoke to the riff filled land
« Reply #59 on: Mon, 11 August 2014, 15:24:18 »
MX Greens are the bomb... except I haven't tried bs yet
Offline Jalberstone
« Reply #60 on: Mon, 11 August 2014, 16:59:28 »
Buckling spring please
Offline Parak
« Reply #61 on: Tue, 12 August 2014, 00:23:05 »
I don't even get the point of this thread. OP is a new member, comes in claiming to be making a new keyboard, doesn't provide any credentials or capability details, and most likely doesn't even know what it takes to create a buckling spring keyboard.
People really need to be a little more critical in here. And by a little I mean a lot.
Offline LechnerDE
« Reply #62 on: Tue, 12 August 2014, 00:28:53 »
I guess nobody expects OP to actually deliver and they just stated their personal favorite for fun?!
Offline Elrick
  • Hype Master
  • Keyboard Orgasmist
« Reply #63 on: Tue, 12 August 2014, 00:52:37 »
The non-gamers will squeak for BS every time but the gamers will always go for the cherry, has always been the same in the past here on GH and will always happen in the future as well.
Good luck to anyone wanting to create a BS keyboard from scratch that has at least 25 nkro  :thumb: .
Offline tribade
« Reply #64 on: Tue, 12 August 2014, 01:43:34 »
Yep!  I don't think anyone here read the OP and thought, "Gee this guy seems legit and has a wealth of keyboard knowledge, can't wait to see what he puts out!"  I'm pretty sure everyone is just ****ing around with the idea of a new BS board.
KMAC mini w/ blacks | Realforce 87uw 55g w/ Digil0g case | KMAC w/ blacks | Duck Viper w/ clears
"Te occidere possunt sed te edere non possunt nefas est."
« Reply #65 on: Tue, 12 August 2014, 09:23:11 »
OP was probably Ripster just trying to stir up emotions.
- D Trump 2026-10-24
Offline Oobly
« Reply #66 on: Tue, 12 August 2014, 16:02:42 »
Offline xybre
  • clickityclackclickityclack
    • Music and Stuff
« Reply #67 on: Tue, 12 August 2014, 17:12:29 »
Buckling Spring.
It's slightly nicer than Greens because the reset point is identical to the actuation point, so there's no chance of losing a keypress. But generally a lighter action key is prefered by most gamers. I haven't run into much issues with my Unicomp, but I've not been gaming with it heavily yet either (only some Elite Dangerous).
GON NerD 60 & Duck Eagle & Unicomp Ultra Classic & Das Keyboard Ultimate
Offline False_Dmitry_II
« Reply #68 on: Wed, 13 August 2014, 13:35:28 »
BS
I really don't see why everyone just assumes this to be so. I rotate between clicky types and game just fine on all of them despite possibility of 2KRO. From BS, to Matias, Monterey Blue, Space Invaders, etc. None of which are cherry.
« Reply #69 on: Wed, 13 August 2014, 13:37:32 »
That's how I read this thread.
Offline Quardah
    • DeliTech
« Reply #70 on: Wed, 13 August 2014, 13:49:39 »
Same here.
Who cares about OP all we see is an open door to yell how hipster***s we are in here.
Lol just kidding love you guys.
Poker II - Brown MX
Offline Senthura
  • Your Doom
« Reply #71 on: Wed, 13 August 2014, 13:58:54 »
I want greens. TKL greens.
Ducky Shine 3 TKL Blue switch & Green backlight
Offline GSimon
« Reply #72 on: Wed, 13 August 2014, 22:32:47 »
Ya'll are toasting in a roll bread
Offline sagi22n
« Reply #73 on: Wed, 20 August 2014, 20:39:58 »
so for typing or gaming buckling springs is what everyone want.
i am going to build one with some function options and better layout.
Offline GL1TCH3D
« Reply #74 on: Wed, 20 August 2014, 22:39:11 »
I wouldn't say bucklings are great for gaming either... I also like greens because I imagine they're easier to mod; being cherry mx and all
Offline xixihaha2008
« Reply #75 on: Thu, 21 August 2014, 00:10:22 »
buckling spring clearing!!!
Offline Oobly
« Reply #76 on: Thu, 21 August 2014, 00:55:32 »
Nope. For typing, NOT gaming. For gaming I want Cherry MX Blacks or Cherry MX Clears.
Good luck with that. Please post updates here on GH. I think the "Making Stuff Together" subforum is the best place for this.
Offline FrostyToast
  • Litshoard
« Reply #77 on: Thu, 21 August 2014, 00:59:48 »
60% buckling spring
what do you mean which one will be buckling and which green?
not sure its passable buy i can check
He means that he wants a buckling spring keyboard with only 61 or so keys on it in total. I am on my phone right now so I won't link you anything but look up the poker keyboard and you will see
Quote from: elton5354
