Author Topic: Ever buy the same keyboard again?  (Read 19434 times)
Offline Sygaldry
  • Edema Ruh
Re: Ever buy the same keyboard again?
« Reply #100 on: Sat, 14 February 2015, 23:22:42 »
Bought HHKB Type-S, then traded it away.
Then bought another.
Never going without an HHKB again.
null
Offline wyatt8740
  • Machine code enthusiast
« Reply #101 on: Sun, 15 February 2015, 19:10:47 »
I know model M collectors would love having multiples to play with, but what about Filcos and what not?
Yeah, I do model M's. But I've only bought one - I've never 'bought a keyboard twice'. That's because my first Model M was free, and I bought the second (for less than $20!)
I don't usually collect things, but when I do, they're from the 70's, 80's, and 90's. My typing speed: 79 WPM
IBM Model M 1386303, 1987 / IBM Model M 1391401, 1993 / IBM Model M 59G7980, 1993 / Unicomp "Mini M" UT40E7A (modded), 2021 / Dell AT101W, 1994 (Black Alps) / Apple Extended Keyboard (Orange Alps), 1987 / Sun Type 5, unknown year (Rubber Dome)
Offline falkentyne
« Reply #102 on: Sun, 15 February 2015, 19:41:33 »
Just bought a 2nd ducky shine 4 69 fire edition.
Offline Snowdog993
  • Grace Under Pressure
  • Justifiably Clueless.
« Reply #103 on: Sun, 15 February 2015, 19:44:19 »
Yes, and the one you bought....  did you get it working yet?
Offline wyatt8740
« Reply #104 on: Sun, 15 February 2015, 19:49:39 »
Only by swapping the controller or using it with the 3161 terminal.
I'm fine like that for now, thinking when I have time I'll make a membrane matrix decoder with my arduino.
Thanks for remembering, though! :)
Offline Snowdog993
« Reply #105 on: Sun, 15 February 2015, 20:06:59 »
I think you can get a controller for it from clickykeyboards if I am not mistaken.  You might want to check that out.
http://www.clickykeyboards.com/index.cfm/fa/items.main/parentcat/33739/subcatid/0/id/586770
I hope I helped you!
Offline MPZ
« Reply #106 on: Tue, 17 February 2015, 04:15:51 »
I wish I had...
Which is to say that I have yet to find a keyboard that I really gel with. I'm hoping the Noppoo EC108-Pro I'm in the current massdrop for will suit me- if it's close, I might go on the hunt for one of those all-30g Topre boards that they discontinued a year or two ago. But once I find a keyboard I love, I will probably buy two- though it does depend what direction the market is going in, and whether it's new/in production or not.
-MPZ
