Author Topic: [IC] Smart 68 Keyboard Set (GB is live)  (Read 292758 times)
Offline pfrederi
Re: [IC] Smart 68 Keyboard Set (updated LED swapping video)
« Reply #250 on: Thu, 11 December 2014, 02:32:51 »
Would it be possible to do a group buy without Massdrop?
Offline Battou62
« Reply #251 on: Thu, 11 December 2014, 08:05:27 »
I hope this project becomes available in a TKL form factor one day.
Offline Sygaldry
  • Edema Ruh
« Reply #252 on: Thu, 11 December 2014, 15:03:37 »
Yes. Definitely possible.
But whoever ends up running the GB will have to comb through the countless electronics factories in China to find one that can produce the board for a price low enough that enough people will join to meet MOQ.   :-[
MD is our best bet at this point  :(
null
Offline pfrederi
« Reply #253 on: Thu, 11 December 2014, 20:36:36 »
We just need to group buy a Chinese factory... Hmmmmm
Massdrop is busy trying to push their Infinity keyboard which may qualify as being one of the ugliest keyboards I've ever seen.
Bummer
Offline nandop
  • May your keystrokes always be true.
« Reply #254 on: Fri, 12 December 2014, 09:57:51 »
Bummer
In terms of aesthetics, I absolutely agree with you. Through a business perspective, that metal plate that serves as the feet (in some layouts) is really genius for saving money and resources. But still, I didn't buy it and most likely won't unless its PCB only.
Sprit 60%, White MX 78g Au | Planck Ortholinear 40% Clear MX | Phantom TKL Browns 110g Au
Offline Sygaldry
  • Edema Ruh
« Reply #255 on: Fri, 12 December 2014, 18:36:58 »
Bummer
They offered just the PCB and normal plate to use with other cases in the initial group buy.
There was no need to buy the bent frame/case.
null
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #256 on: Sun, 14 December 2014, 02:20:16 »
I need one!
Offline Digitize
« Reply #257 on: Tue, 16 December 2014, 22:06:16 »
this keyboard is starting to grow on me. Just the idea of being able to swap switches or led in and out without soldering is really cool.
Offline PocoLoco
« Reply #258 on: Fri, 26 December 2014, 18:31:26 »
OMFG my dreams have come true tell me when i can buy this
Offline Joebroniee
« Reply #259 on: Sat, 27 December 2014, 03:12:25 »
it'll be a while my friend. just keep on praying
Offline PocoLoco
« Reply #260 on: Sat, 27 December 2014, 10:28:18 »
I know that it will be a while till we are able to get hold of this but maybe we will be lucky some day soon. I will be waiting for more news.
Offline taylordcraig
« Reply #261 on: Wed, 07 January 2015, 22:31:50 »
is this till going to happen?
I'm holding my breath and might pass out soon.
Offline SacKRoll
« Reply #262 on: Sat, 10 January 2015, 22:07:09 »
I think it isn't, but I hope be wrong about it.  :'(
Offline GL1TCH3D
« Reply #263 on: Mon, 26 January 2015, 16:55:46 »
I'm working with a manufacturer about a TKL.
They already produce keyboards so it would be more a modification off a current model. They're supposed to be testing the hotswapping right now.
« Reply #264 on: Mon, 26 January 2015, 17:08:29 »
I'll help test!  :D
Offline GL1TCH3D
« Reply #265 on: Mon, 26 January 2015, 17:13:29 »
I'll help test!  :D
Pretty sure the plane ticket to China wouldn't be worthwhile xD
I'll make sure to get one here myself if it works for testing.
Offline Joebroniee
« Reply #266 on: Tue, 27 January 2015, 10:59:18 »
finally a little light of hope =D
Offline STARLORDCOFFEE
  • @albertmeetsworld
« Reply #267 on: Wed, 28 January 2015, 14:20:18 »
I need this In my life more then I need oxygen...don't you dare try to persuade me otherwise!!
       Model M              BL82          JD45          HHKB        RF
Offline tuantruong
« Reply #268 on: Wed, 28 January 2015, 14:47:54 »
is the TKL version going to be a low-profile keyboard? I'm not a fan of low-profile cases, but really interested in hot swap PCB idea.
Offline LechnerDE
« Reply #269 on: Thu, 29 January 2015, 05:26:04 »
I am even more interested in a TKL version of this.
Please keep us updated!!
Offline GL1TCH3D
« Reply #270 on: Thu, 29 January 2015, 06:00:00 »
No =[
I mean anything is possible with enough money I have to consider what will be the most popular without creating a whole new product (since that would require a new set of tools and such)
Offline pasph
« Reply #271 on: Thu, 29 January 2015, 07:31:53 »
It will also have the FN key on the front side?
Offline GL1TCH3D
« Reply #272 on: Thu, 29 January 2015, 08:14:47 »
the one that I'm pursuing does not have a front side FN key. It's standard TKL with the main difference being the hot swapping switches
Offline pasph
« Reply #273 on: Thu, 29 January 2015, 13:27:55 »
Also hot swapping leds?
Offline ImBZppl
« Reply #274 on: Fri, 30 January 2015, 20:38:31 »
A TKL would certainly be interesting but what about the cost? I would expect it to go up as well.
Offline ccc24
  • HHKB , Ergodox
« Reply #275 on: Fri, 30 January 2015, 22:00:51 »
From what I read so far, the manufacturer is testing hot swapping on one of their current models. So hopefully if they can streamline the entire group buy or w.e we could get the price down.
Offline ImBZppl
« Reply #276 on: Sat, 31 January 2015, 14:24:52 »
Will there be a cnc aluminum case on the tkl?
Offline GL1TCH3D
« Reply #277 on: Sun, 01 February 2015, 01:32:14 »
Unlikely.
As I mentioned before it's based off a current product that they manufacture.
Though the PCB should be standard TKL if you really want to transplant the PCB and such to an Alu case if you really wanted
Offline justify
  • Great news!
« Reply #278 on: Sat, 07 February 2015, 07:44:43 »
is this still happening?
Offline daerid
    • Rossipedia
« Reply #279 on: Mon, 09 February 2015, 11:55:13 »
The 68% is really the first compact idea that I've seen that I feel would be really usable for me (the 660 form factor is close, but just not quite there). As long as the controller on this is programmable (and hot swap switches/leds? WHAAAAAT?), I would buy this in a heartbeat.
Offline Blungo
« Reply #280 on: Wed, 18 February 2015, 07:06:16 »
Where do I buy this?
Offline Moralless
« Reply #281 on: Wed, 18 February 2015, 07:42:03 »
A GB for this keyboard never made it to GH (sadly  :'()
Although they did have a very limited run on some asian forum (I can't recall the name sorry). You're only chance to ever get this would probably if someone who was in the limited run GB decided to sell theirs, but that is very unlikely.
Offline Rotaku
  • Too Based
« Reply #282 on: Thu, 19 February 2015, 08:03:21 »
Wait, what is exactly happening here that is stopping the group buy from happening?
Not toooo active on GH anymore, if you need me, shoot me a PM on Reddit! /u/IchibanXD
Offline Ripudio
« Reply #283 on: Thu, 19 February 2015, 14:51:58 »
I believe the manufacturer went out of business :(
Offline Sygaldry
  • Edema Ruh
« Reply #284 on: Thu, 19 February 2015, 15:21:29 »
https://www.massdrop.com/vote/compact-60-ish-sized-with-discreet-arrow-keys
Massdrop apparently is in the process of finding a new manufacturer and bringing this KB back to life. I don't think they've made any progress let alone put forth a significant amount of effort to do so though.
null
Offline Asininity
« Reply #285 on: Sat, 21 February 2015, 02:12:01 »
This is such a cool idea in my mind that I really do hope they find  a way to bring it back. I don't have the spare cash to afford it now but soon.
Offline sethk_
  • Grand Master Wizard Pizza
  • www.kbdhub.com
    • My webstore
« Reply #286 on: Sat, 21 February 2015, 02:13:43 »
Well, I think they did this just by using SIP sockets.
Offline xtazy222
« Reply #287 on: Sat, 21 February 2015, 03:40:47 »
So is it dead for the TKL version?
Offline GL1TCH3D
« Reply #288 on: Sun, 22 February 2015, 12:27:53 »
Haven't heard anything since it supposedly went to prototyping.
They didn't charge me anything but just never got back to me. I'll see if I can get in touch with them at some point
« Reply #289 on: Wed, 04 March 2015, 12:59:26 »
Really sad, couldn't care less for a tkl really. The smart68 was something new and innovative.
Also, hot swap LEDs can be accomplished with SIP sockets, the switches use a special contact in the pcb that they can clip in to.
Offline GL1TCH3D
« Reply #290 on: Wed, 04 March 2015, 16:14:47 »
I agree the smart68 was something else. Still any keyboard with hotswappable switches is interesting to me.
Offline feng
« Reply #291 on: Tue, 10 March 2015, 20:31:20 »
I might have to do this along with DeeLong. Massdrop says they don't have the confidence to do the group buy yet since it's a new product. They might consider in the future if a GB on GH goes well.
Offline bahamot
    • bistropolis - dine with style
« Reply #292 on: Tue, 10 March 2015, 21:23:06 »
The keycap is the only thing that concern me.
How hard it's to get he keycaps set that fits this keyboard?
Offline derezzed
« Reply #293 on: Tue, 10 March 2015, 21:41:23 »
This is one of the most beautiful boards I've seen.  If I had the money, I'd be all over this when it becomes available.  But I do have reservations about the function bar.  I have large hands and I find it a bit awkward to put my thumbs on the side of my keyboard case and reach my fingers beyond the home row.  Still, it's a really nice board.
« Reply #294 on: Tue, 10 March 2015, 21:43:52 »
Very easy, most new keysets have a short shift.
« Reply #295 on: Thu, 12 March 2015, 00:19:42 »
Please make the Smart68 happen Feng. I have full faith in you!
You can also put a FN key on a regular switch.
Offline bahamot
« Reply #296 on: Thu, 12 March 2015, 01:44:55 »
+1 that!
Offline bahamot
« Reply #297 on: Mon, 16 March 2015, 04:16:48 »
@feng, do we need to solder for the fn button at the side keyboard case?
Offline Sygaldry
  • Edema Ruh
« Reply #298 on: Mon, 16 March 2015, 04:41:06 »
This needs to happen!
null
Offline KnivesM
« Reply #299 on: Mon, 16 March 2015, 13:55:46 »
Hopefully this ends up happening, such a cool concept.
Others
