Author Topic: [IC] Smart 68 Keyboard Set (GB is live)  (Read 219772 times)
Offline kys
Re: [IC] Smart 68 Keyboard Set
« Reply #50 on: Thu, 14 August 2014, 09:31:33 »
i'm interested as well
Offline pasph
« Reply #51 on: Thu, 14 August 2014, 09:49:05 »
Interested
Online HoffmanMyster
« Reply #52 on: Thu, 14 August 2014, 10:40:52 »
I like this.  I would buy one.
Not a fan of the modifier layout and sizing though.  I'd much rather see a 1x left win or the option to omit that entirely, shift the spacebar over, and have another function key on the right.  But that's just me.
Offline taylordcraig
« Reply #53 on: Thu, 14 August 2014, 11:00:28 »
THIS!
1.5 1.5 7 1.5 1.5 1 1 1 for life
Offline lhl
    • random($foo)
« Reply #54 on: Thu, 14 August 2014, 12:34:28 »
Wow, this looks fantastic, definitely interested, physical build looks close to perfect!
That being said, I'd definitely want to be able to customize the layout in a lot of ways (caps->ctrl or fn, windows key to fn, being able to customize the fn layer). Programmable would be great, but firmware customizability would be even better.
Offline Vibex
  • Love y'all
« Reply #55 on: Thu, 14 August 2014, 12:43:33 »
I would be in for one, sounds really cool. :thumb:
Offline Data
« Reply #56 on: Thu, 14 August 2014, 12:45:31 »
THIS!
But... how will I do Win+L and Win+R?   :-[
« Reply #57 on: Thu, 14 August 2014, 14:16:54 »
THIS!
Have one of them as a hidden windows key! CTRL ALT space WIN (CTRL/ALT/MENU/FN)
Your keyboard has never looked prettier! [I use win+E all the time, R, didn't know about L!]
« Reply #58 on: Thu, 14 August 2014, 14:58:12 »
THIS!
I have never found a need for right ctrl or right alt to exist, so I would make one of those an fn key and the other the win key.
In the above, hyper would be win and code would be fn.
It makes win+E a bit more awkward, but I'm okay with that.
« Reply #59 on: Thu, 14 August 2014, 15:07:22 »
THIS!
Exactly. I just two hand most win combos now. No problem really, left hand is always over there anyway. :P
[Hoff I keep finding we have more and more similar keyboard tastes.]
Offline Data
« Reply #60 on: Thu, 14 August 2014, 16:11:36 »
So you're saying I should trade a 2-key combo for a 4-key combo?
You're not a big fan of efficiency I take it?  ;D
Yeah, maybe.  I don't really use the R-Alt or R-Ctrl.  Would make Win+L a lot easier, but shifts the hand acrobatics over to Win+R.  Not sure how I feel about two-handing a Win+R combination.  I'd have to try it.
« Reply #61 on: Thu, 14 August 2014, 17:31:31 »
I'm sorry, four key combo? It's still just win+r.
I'm saying remove the superfluous 1.25 mods [right win, right ctrl, right alt]
I wrote (CTRL/ALT/MENU/FN) to mean your last 1.5 mod could be whatever you wanted.
On a tkl you don't need FN.
As Hoff pointed out, r-Alt and r-Ctrl are nearly useless.
And I personally don't use the menu key, but some people might.
Offline Latin00032
« Reply #62 on: Thu, 14 August 2014, 19:59:47 »
THIS!
Ditto!
Offline Data
« Reply #63 on: Fri, 15 August 2014, 08:05:57 »
OK, I totally misunderstood what you were suggesting.  When you said a hidden Windows key, I thought you were saying it could be the spacebar and Ctrl+Alt+Space would simulate the Win key.  That would make Win+R (for example) a 4-key combo.   :confused:
Thanks for clearing it up for me.
Offline ComradeSniper
  • HHKB Pro
« Reply #64 on: Fri, 15 August 2014, 09:17:02 »
This is pretty awesome. I'm not a big MX fan but I might get one of these anyway.
Offline berserkfan
« Reply #65 on: Sun, 17 August 2014, 13:07:45 »
I am relieved to see that it is a 68key.
Please continue making small keyboards, Feng.
As long as it doesn't offer enough keys (functionality) for me, I will not spend my $300. Whew.
otherwise the design features are too awesome to miss. I'd be overspending as usual...
Offline inanis
  • Truly Literally The Cloud
    • SEALWoodworking
« Reply #66 on: Sun, 17 August 2014, 13:31:44 »
I almost can't imagine spending that much on a keyboard, but then I read the description again, and I can't imagine not getting this. Consider me very interested. I've been looking for a 60%-ish layout + arrow keys that is both aesthetically appealing and customizable. You are making all my dreams come true.
Offline epicepee
« Reply #67 on: Sun, 17 August 2014, 13:37:48 »
Does anybody happen to know how these hot-swappable switches work?  Some kind of female header, I assume.  I'm looking to build a keyboard, and I might want to try that.
« Reply #68 on: Sun, 17 August 2014, 17:19:55 »
Sorry, just a little bump,
do we have a timeline for this buy?
« Reply #69 on: Sun, 17 August 2014, 17:28:25 »
Feng mentioned if it works out with massdrop a GB could start in approx 3 weeks. Hopefully that happens!
« Reply #70 on: Sun, 17 August 2014, 17:50:13 »
Yeah I was hoping for a little update on this. :)
Offline Hanni
« Reply #71 on: Sun, 17 August 2014, 20:34:38 »
Great work.  :thumb:
The most difficult is to find a reason to get one. :D The price without switches could be one reason.
« Last Edit: Sun, 17 August 2014, 20:41:56 by Hanni »
Offline OPs_Creepy_Uncle
« Reply #72 on: Sun, 17 August 2014, 23:45:51 »
Would buy!
« Reply #73 on: Sun, 17 August 2014, 23:47:01 »
I'd have to say yes, yes I would buy this.
« Reply #74 on: Sun, 17 August 2014, 23:49:30 »
Feng, I forget, did that tentative price of $300 include any switches? Or just a kit?
Also, it needs to be a nice purple. If any color has to be included, definitely purple :)
« Reply #75 on: Sun, 17 August 2014, 23:56:54 »
Support for 1.5-1.5-7-1.5-1.5-1-1-1 bottom row. I beg you!
Offline dakuzo
« Reply #76 on: Mon, 18 August 2014, 00:00:14 »
Time to start saving funds for this one.
Digilog Realforce 87u - 45g - GMK Dolch
Leopold FC660C - JTK WoB
GoN Nerd Crystal TKL - 62g Mx Blacks - JTK PoW
Duck Octagon - Gateron Blacks - Miami Odessa R4
Offline Emmiya
« Reply #77 on: Mon, 18 August 2014, 00:25:49 »
edit:
« Last Edit: Fri, 22 August 2014, 18:46:50 by Emmiya »
Offline GSimon
« Reply #78 on: Mon, 18 August 2014, 00:32:25 »
I like this board a lot, the keyboard layout works fine for me too.
Lots of great features, can't find one really sore spot about it. Interested in seeing what colors are available, and by that what I really mean is I hope black/red is an option :D (or bronze)
Offline ruiner17
« Reply #79 on: Mon, 18 August 2014, 01:07:55 »
I'm in.
+ Love the layout, exactly what I have been looking for.
+ Love the hot swapping
Only issue I can see is the Fn switch when using a wrist rest which I do.
Offline Heliosphere
« Reply #80 on: Mon, 18 August 2014, 01:32:32 »
Can I use plate mount switches on these or would I need PCB mount?
Offline miled
« Reply #81 on: Mon, 18 August 2014, 01:36:26 »
Absolutely stunning design, and a 60% layout that is both sensible, familiar and useful for those who rely heavily on home, end, delete and arrow keys. This is the best 60% board I've ever seen and I want one now, gorramit!
Would love a PCB mount version with a PCB flush case, and the ability to use 1.25x modifiers on the left so as to have room for 3 1x modifiers on the right with a standard size spacebar. Otherwise this is perfect.
« Last Edit: Mon, 18 August 2014, 07:29:49 by miled »
Offline bazh
« Reply #82 on: Mon, 18 August 2014, 01:48:15 »
along with alu, carbon fiber is doing good job adding the cost :(
HHKB Pro2 white
Newbie again
Offline RED-404
« Reply #83 on: Mon, 18 August 2014, 02:01:35 »
Yeah, I would love to see this PCB in a Poker compatible form factor ready to go. Just add your own case, plate, switches and keycaps, no soldering needed.
Offline bazh
« Reply #84 on: Mon, 18 August 2014, 02:07:53 »
I think the key of solder-free pcb is these little guys, shouldn't be hard if we had anybody doing this in GB so we could buy and put into our own keyboard (we already had hot-swapable led now, just the sw pin that need making)
HHKB Pro2 white
Newbie again
Offline byker
  • Literally Canada
« Reply #85 on: Mon, 18 August 2014, 02:33:29 »
Wow this is really cool! Might have to save up for yet another keyboard!  :p
« Reply #86 on: Mon, 18 August 2014, 02:53:17 »
Now that's a sexy keyboard.
Which controller?
ISO?
Offline MrChunky
« Reply #87 on: Mon, 18 August 2014, 03:03:38 »
Yes, yes and yes! Everything I have been missing is now here!
Offline pasph
« Reply #88 on: Mon, 18 August 2014, 03:31:00 »
Any chance for ISO support?
Offline Clydae
« Reply #89 on: Mon, 18 August 2014, 03:55:42 »
This is beautiful! Definitely interested.
Offline slapstick
« Reply #90 on: Mon, 18 August 2014, 04:05:47 »
This is something I'd definitely be interested in, regardless of the layout.  ;D :D ;D
Offline rayuki
  • RAAAAAAR
« Reply #91 on: Mon, 18 August 2014, 05:46:12 »
have been afk from geekhack for a while (buying wise)  but this would bring me back for sure. can't wait to try a rainbow of switches. count me in for sure
Offline mikochu
« Reply #92 on: Mon, 18 August 2014, 06:47:32 »
My interest is piqued.  What's the expected timeline for production?
Offline Patchwrks
« Reply #93 on: Mon, 18 August 2014, 08:24:12 »
(´・ω・`)denko-chan~~~내 스레드
Offline johnhamelink
« Reply #94 on: Mon, 18 August 2014, 09:15:58 »
Just saw this on Reddit - I'm interested!
Offline salcan
« Reply #95 on: Mon, 18 August 2014, 09:26:46 »
I'm interested. Looks incredible.
Offline Elocutive
« Reply #96 on: Mon, 18 August 2014, 10:44:18 »
Down for one or two. Really like the idea
LZCE- Black, red, ergo clears
Wanting Skeldon
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #97 on: Mon, 18 August 2014, 11:07:52 »
I love the layout and the overall concept. I don't understand why carbon fiber... but still very interesting project.
Offline bazh
« Reply #98 on: Mon, 18 August 2014, 11:32:52 »
This.
I think the point of using carbon fiber in products is the weight it can save, but using it with an alu housing, I don't see why
HHKB Pro2 white
Newbie again
Offline uberknarf
« Reply #99 on: Mon, 18 August 2014, 12:44:18 »
I'm in. Love the look of this. I just couldn't jump into a 60% board without my arrow keys, particularly with the steep learning curve. This tackles that problem, and tacks on the incredible option of hotswappable switches and LEDs.
Absolutely bomber.
