Author Topic: My DIY Caps  (Read 344322 times)
Offline Krytone
  • ᕦ(ò_óˇ)ᕤ
    • Krap Shop
Re: My DIY Caps
« Reply #1150 on: Thu, 01 February 2018, 18:33:58 »
Tryin to see if putting in a visor works....
Midas Cats  :p
Code: [Select]
Midas Cats
Dope!
Cheers!
When the CopyCat sale though?
Maybe this month. Will depend on how my resin cooperates with me  :-\
TGR Jane CE | TX-CP | ZZ96 | HHKB | Ducky Shine 3 | Atreus | Infinity Ergodox | IBM Model M | Smart Pad | Taobao Acrylic 96 | TGR910 SE | RGB96 | M4-A | Moon
Pending: Exent | EM7 | M-60 | Kira EXS | 910 Poly | Kn210 | Alice
Offline Krytone
  • ᕦ(ò_óˇ)ᕤ
    • Krap Shop
Re: My DIY Caps
« Reply #1151 on: Sat, 03 February 2018, 01:35:19 »
Trying to bring this guy to life again  :rolleyes:
Offline mogo
Re: My DIY Caps
« Reply #1152 on: Sun, 04 February 2018, 11:05:49 »
It's a lovely cast! :D
Re: My DIY Caps
« Reply #1153 on: Mon, 05 February 2018, 05:40:10 »
And why not - it's a solid design and looks like you've got the double shot parts perfect :thumb:
Offline TonyD
    • dtronixs
Re: My DIY Caps
« Reply #1154 on: Wed, 07 February 2018, 04:51:41 »
+1 great looking caps
Offline Krytone
  • ᕦ(ò_óˇ)ᕤ
    • Krap Shop
Re: My DIY Caps
« Reply #1155 on: Wed, 07 February 2018, 19:46:46 »
Offline Krytone
  • ᕦ(ò_óˇ)ᕤ
    • Krap Shop
Re: My DIY Caps
« Reply #1156 on: Wed, 07 February 2018, 19:48:26 »
Mr Cupido
Offline DALExSNAIL
  • 𝖋𝖚𝖈𝖐 𝖆𝖑𝖕𝖘
Re: My DIY Caps
« Reply #1157 on: Sat, 10 February 2018, 14:08:57 »
Mr Cupido
My inner weeb NEEDS one (or more) of these
Offline Krytone
  • ᕦ(ò_óˇ)ᕤ
    • Krap Shop
Re: My DIY Caps
« Reply #1158 on: Sat, 24 February 2018, 06:41:48 »
Bringing back the old designs...
Offline UsualSuspectXXX
  • (⌐■_■)⊃━☆゚.*・。゚
Re: My DIY Caps
« Reply #1159 on: Sat, 24 February 2018, 22:00:50 »
Love seeing the JS2.0 make a comeback, especially this green colorway.
Any chance of rebooting the JS1.0?
Offline Krytone
  • ᕦ(ò_óˇ)ᕤ
    • Krap Shop
Re: My DIY Caps
« Reply #1160 on: Sun, 25 February 2018, 01:17:31 »
Sir, yes sir!
  • (⌐■_■)⊃━☆゚.*・。゚
Re: My DIY Caps
« Reply #1161 on: Sun, 25 February 2018, 09:46:40 »
Sir, yes sir!
Yes!
Offline Krytone
  • ᕦ(ò_óˇ)ᕤ
    • Krap Shop
Re: My DIY Caps
« Reply #1162 on: Sun, 25 February 2018, 11:52:01 »
Some moar...
Offline Krytone
  • ᕦ(ò_óˇ)ᕤ
    • Krap Shop
Re: My DIY Caps
« Reply #1163 on: Fri, 16 March 2018, 04:34:21 »
Re: My DIY Caps
« Reply #1164 on: Fri, 16 March 2018, 05:15:00 »
This thread always makes me laugh - 'DIY Caps', but when you open it you find another 5 shot masterpiece!
Offline mogo
Re: My DIY Caps
« Reply #1165 on: Fri, 16 March 2018, 09:37:36 »
True! Maybe it's time to change the thread title to something more descriptive, like "Krytone's Krap Karnival"  :))... wait, on second thought, maybe that much alliteration is a bad idea...  :-X
Offline Krytone
  • ᕦ(ò_óˇ)ᕤ
    • Krap Shop
Re: My DIY Caps
« Reply #1166 on: Fri, 16 March 2018, 22:16:27 »
omg that is so wrong in so many ways that i wanna do it  :))
Offline Krytone
  • ᕦ(ò_óˇ)ᕤ
    • Krap Shop
Re: My DIY Caps
« Reply #1167 on: Fri, 16 March 2018, 22:26:42 »
Some moar skulls...
Offline kgolden
Re: My DIY Caps
« Reply #1168 on: Sat, 17 March 2018, 16:52:12 »
Those skulls are pretty sick.. nice work
Offline Vloshko
Re: My DIY Caps
« Reply #1169 on: Sat, 17 March 2018, 22:30:12 »
I'm diggin those skulls too. I'm quite fond of the illuminated maker logo/signature on the back.
Keycap Compendium
Discord: Vloshko#1327
Key Cap Wishlist
2019: Configure Optimal Audio Settings
HHKB Pro 2, Model M, Unicorn X Legend, ESPECTRO 96, SaiB CP, E8-V1.
  • (⌐■_■)⊃━☆゚.*・。゚
Re: My DIY Caps
« Reply #1170 on: Sat, 17 March 2018, 22:34:21 »
Some moar skulls...
Oh damn. Crowned Skulls getting a nice reboot!
Offline gr4v3m4n
    • my store
Re: My DIY Caps
« Reply #1171 on: Mon, 26 March 2018, 17:00:47 »
hi there, i just got a pressure pot and i’m encountering some problem.
i’ve tried casting under pressure 3 times now and for some reason my resin doesn’t want to cure, it just stayed in elastic mode i’ve tried to balance the mixture using scale still the same result. does pressure affect the curing prosess? cause i have the same problem with my silicone curing under pressure, seems that it took longer to cure. i dont know if my silicone and resin is expired  cause i just bought them.
i cant get access to most common type of resin you guys use like smooth-on or alumilite so i just have a non branded d-80 resin and i use rtv silicone.
Offline Krytone
  • ᕦ(ò_óˇ)ᕤ
    • Krap Shop
Re: My DIY Caps
« Reply #1172 on: Mon, 26 March 2018, 20:54:40 »
I actually use a local resin and silicone brand here in Malaysia so i dont think that matters. Also, i havent experienced pressure affecting the curing time. What i can guess is that either you dont mix them enough or you use less catalyst/hardener thats why it cures slower. Try to refine those 2 points and see what happens. Else if it still doesnt and you already followed the proper instruction of your resin/silicone, you need to contact your supplier to ask why.
I also used expired resin/silicone and they work just fine. The only difference they have with non-expired materials is that expired ones is more thicker and harder to stir but still usable. Hope that helps and GL.
Offline gr4v3m4n
    • my store
Re: My DIY Caps
« Reply #1173 on: Mon, 26 March 2018, 21:04:37 »
i use 2 mixing cup to measure the volume which i use over again after i clean ofcourse, i did the same thing with the silicone its easier to clean the cup. is it possible thats the cause? its impossible to clean spotless but i’ve been doing that since the beginning and i’ve had no problem until i try preessure casting. but i’ll try more detailed measuring and mixing, thanks for the reply.
Offline Krytone
  • ᕦ(ò_óˇ)ᕤ
    • Krap Shop
Re: My DIY Caps
« Reply #1174 on: Mon, 26 March 2018, 21:16:09 »
i use disposable cups for resin and silicone cause cleaning them is a pain and time consuming. Try it with a fresh cups and see if that helps. Also make sure you stir really well. One thing i always notice when transitioning from potless casting to using pressure pot is you got used to careful stirring which is not required already and just have a go at it and dont mind the bubbles since that would go away when being pressured.
Offline gr4v3m4n
    • my store
Re: My DIY Caps
« Reply #1175 on: Mon, 26 March 2018, 21:20:18 »
ok, will do. thank you so much
Offline Krytone
  • ᕦ(ò_óˇ)ᕤ
    • Krap Shop
Re: My DIY Caps
« Reply #1176 on: Fri, 11 May 2018, 05:22:19 »
NSFW random sculpts  :blank:
Re: My DIY Caps
« Reply #1177 on: Fri, 11 May 2018, 09:46:40 »
I love it.
Offline Waateva
Re: My DIY Caps
« Reply #1178 on: Fri, 11 May 2018, 10:05:39 »
I love it.
Of course you do
Offline mogo
Re: My DIY Caps
« Reply #1179 on: Fri, 11 May 2018, 10:18:09 »
Oh my.  :blank:
Offline gr4v3m4n
    • my store
Re: My DIY Caps
« Reply #1180 on: Fri, 11 May 2018, 10:22:23 »
BALLSSS
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
Re: My DIY Caps
« Reply #1181 on: Fri, 11 May 2018, 12:25:25 »
Offline Krytone
  • ᕦ(ò_óˇ)ᕤ
    • Krap Shop
Re: My DIY Caps
« Reply #1182 on: Sat, 12 May 2018, 01:06:42 »
Offline Montaberne
Re: My DIY Caps
« Reply #1183 on: Sat, 12 May 2018, 19:43:06 »
Ok wow. That's awesome! Great work.
