Author Topic: Lot of 7 TG3 keyboards $60 shipped  (Read 4535 times)
« on: Fri, 15 August 2014, 08:47:39 »
I don't know why you'd want 7, but a good deal on these is usually $20-25 shipped for one.  These look to be in fantastic shape for 7, making each board $7.50.
http://www.ebay.com/itm/TG3-Electronics-BL82-Series-82-key-LED-Backlit-Keyboard-with-touchpad-lot-of-7-/291218537703?pt=PCA_Mice_Trackballs&hash=item43cdfa3ce7
They are typically MX Blacks, but some models will have Clears.
Re: Lot of 7 TG3 keyboards $60 shipped
« Reply #1 on: Fri, 15 August 2014, 08:54:27 »
The pic shows a serial port for the connectors if that matters to anyone.
Also do these usually say motorola on them??
Tempted to buy these and sell the switches.
« Last Edit: Fri, 15 August 2014, 08:56:01 by SpAmRaY »
« Reply #2 on: Fri, 15 August 2014, 09:02:13 »
They don't usually say Motorola on them, not that I've seen.
And if someone is short of cash and willing to do a little work, they're definitely worth it for the switches, caps, and stabilizers.  That's, what, 574 switches between the boards?  Sell them at $0.25 a pop, more for the Greys on the space bars, and you're more than doubled your investment and you haven't even sold the caps and stabilizers yet.  Say you get $5 a set of caps for another $35 total.  Then, depending on what stabs these have (I believe it's Cherry), you can make probably another couple of bucks on each board.
Definitely worth it just for parts.
« Reply #3 on: Fri, 15 August 2014, 09:03:08 »
Assuming these aren't some old custom rubberdome job  :))
And it isn't clear they are all the model pictured either since the box seems to be for two different models.
The title says BL82 but the pic is of the KBA-BLT
« Reply #4 on: Fri, 15 August 2014, 09:03:57 »
Yeah, I doubt that.  It's the right model number and TG3 still advertises those as 5 million actuation switches with gold crosspoints.
« Reply #5 on: Fri, 15 August 2014, 09:04:07 »
Are these the boards with splashguards? Or is that the other TG3 board that doesn't have the trackpad?
« Reply #6 on: Fri, 15 August 2014, 09:05:13 »
You want a splashguard? I think I've got one.
« Reply #7 on: Fri, 15 August 2014, 09:05:33 »
I think all TG3 BLT and BL-82 models have the splashguard, but I can't say with certainty.
« Reply #8 on: Fri, 15 August 2014, 09:06:52 »
Hm ok. I've been in the hunt for the non-mousepad version with a splashguard. I'm always forgetting which model is which...apparently it's the BL-82?
« Reply #9 on: Fri, 15 August 2014, 09:08:40 »
Yup.
« Reply #10 on: Fri, 15 August 2014, 09:14:39 »
Wasn't me, but somebody bit on it. Oh well I didn't really want to desolder 7 of those anyway :p
Hopefully someone with an 808 or similar.  :))
« Reply #11 on: Fri, 15 August 2014, 09:16:14 »
Well, I gave you guys like 30 minutes. You snooze, you lose. :))
Offline osi
« Reply #12 on: Fri, 15 August 2014, 09:27:03 »
Nice snag
« Reply #13 on: Fri, 15 August 2014, 09:28:52 »
I kinda figured you got these JD. ;)
I'm only going to cry if it turns out they are ALL clear switches.  :-\
BTW what happened to no more eBay stuff because of your bad luck  :))
« Reply #14 on: Fri, 15 August 2014, 09:29:18 »
Also, thank you again, nubbinator. Always looking out for us. :D
« Reply #15 on: Fri, 15 August 2014, 09:30:11 »
Trying to recover from your Chyron I see JD :P
« Reply #16 on: Fri, 15 August 2014, 09:31:11 »
eBay is a roulette wheel to me. Sometimes a royal flush, sometimes you crap out. :))
Offline absyrd
  • CPT HYPE PADAWAN
« Reply #17 on: Fri, 15 August 2014, 09:38:35 »
I hope he gets all clears!
« Reply #18 on: Fri, 15 August 2014, 09:40:42 »
If he does he knows what to do with them per my PM  :o
In all seriousness though I'm fairly certain I've got at least ~100 brand new clears I bought but just can't find them :facepalm:  :'(
« Last Edit: Fri, 15 August 2014, 09:43:49 by SpAmRaY »
Offline Thechemist
« Reply #19 on: Fri, 15 August 2014, 09:49:44 »
TG3-BL82 with 4 lights on the spacebar and clear switches did not come with one to my knowledge anyways.
Offline Thechemist
« Reply #20 on: Fri, 15 August 2014, 09:51:00 »
These should be black switches with splash guard.
« Reply #21 on: Fri, 15 August 2014, 10:12:55 »
I didn't think about this when I bought the lot, but many of those keycaps will work great with the JD40.
Kinda happy right about now. :D
« Reply #22 on: Fri, 15 August 2014, 10:14:47 »
Um....new plans for my JD40:
1) Buy TG3 from jdcarpe via begging and absurd offers.
2) Install splash guard and blacks into jd40
3) Win at keyboards
Offline Thechemist
« Reply #23 on: Fri, 15 August 2014, 10:30:09 »
They do fit nice on a jD  :)) and you can desolder the switches.
« Reply #24 on: Fri, 15 August 2014, 22:39:26 »
3) Win at keyboards
I thought you got a splash guard already. I just found my "other" spare one.
Anyway I can say this is the lowest price I've seen on these since ivan posted those $10 shipped ones in the main keyboards forum a year or two back.
Not sure about that grey case though.
« Last Edit: Fri, 15 August 2014, 22:42:28 by dorkvader »
