Author Topic: Chicony KB-5981 - what switch is this?  (Read 4217 times)
Offline klikkyklik
    • Klikky Klik
« on: Fri, 15 August 2014, 15:16:35 »
My brother just turned up one of these, and says that the keyswitches emit a click before the keycaps bottom out.  I would have thought it had Alps white keyswitches, but the stem is a "+" style!  Are these indeed Alps white?  They wouldn't be Cherry, would they?
« Last Edit: Fri, 15 August 2014, 15:21:20 by klikkyklik »
Offline ComradeSniper
  • HHKB Pro
Re: Chicony KB-5981 - what switch is this?
« Reply #1 on: Fri, 15 August 2014, 15:41:19 »
Looks like some Cherry clone due to the lack of any sort of marking on the switch.
« Reply #2 on: Fri, 15 August 2014, 15:41:48 »
I've got a board like this, like 95% sure it's these switches.
Offline klikkyklik
    • Klikky Klik
« Reply #3 on: Fri, 15 August 2014, 15:50:24 »
You guys rule.  Thank you!
Offline jacobolus
« Reply #4 on: Fri, 15 August 2014, 17:44:27 »
How do you like these switches?
« Reply #5 on: Fri, 15 August 2014, 18:41:13 »
Is your keyboard well used, and do all keys work? I have heard that the Aristotle switch does not last very long, but I might have mixed that up with them being more frail and breaking easily if you try to open them.
I had a keyboard with them, but desoldered all the switches. I like that they are more tactile than Cherry MX Blue. Unfortunately, the sliders can not be transplanted into Cherry MX housings. (I've tried)
« Reply #6 on: Fri, 15 August 2014, 20:47:20 »
I have a whole bag of them from a genovation keypad. They are terrible.
You can see some interior shots here: https://www.flickr.com/photos/dork_vader/sets/72157646364734605/
Offline klikkyklik
    • Klikky Klik
« Reply #7 on: Sat, 16 August 2014, 06:38:46 »
I have not had the chance to use them - I'm hoping to borrow the board from my brother to see what they feel like.  The whole ordeal with this board has been fun for me because I've learned about Cherry clones, and I like learning.
I do understand however that the switch endurance/quality might not be up-to-snuff, so as far as creating a board from these switches is concerned - probably a bad idea.  Still, I want to experience them at least.
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #8 on: Sat, 16 August 2014, 12:16:37 »
Yeh the only good thing about Aristotle switch is it pin compatible with Cherry MX. Well they are still better than rubberdomes I guess. Chicony is not bad otherwise if you can tolerate the bigass enter key and only 2KRO.
Offline Karura
  • Professional Canadian
  • SKidata life.
« Reply #9 on: Sat, 16 August 2014, 19:05:10 »
I have one of these too, from 1996!
