Author Topic: help me find RGB set  (Read 1934 times)
Offline Jixr
« on: Sun, 17 August 2014, 20:49:46 »
EDIT:
I'm looking for a RGB(Y) keycap set, that has the short right shift ( and preferably fn ) for a KBT pure style layout.
Much prefer OEM profile to cherry.
I can always go WASD to make a set, but would prefer something a bit more higher end.
« Last Edit: Sun, 17 August 2014, 20:55:55 by Jixr »
Offline tbc
Re: help me find RGB set
« Reply #1 on: Sun, 17 August 2014, 20:52:52 »
mechanicalkeyboards.com
« Reply #2 on: Sun, 17 August 2014, 21:10:40 »
Does anyone make OEM rgby sets? Maybe RGB off a stock poker or something.
SP sets would be DCS
GMK is cherry ( http://www.geekkeys.com/gmk-rgby-doubleshot-keyset/)
Offline Jixr
« Reply #3 on: Sun, 17 August 2014, 21:31:57 »
yeah, I saw that set, and $50 is quite expensive.
I'm just not sure how well the cherry profile will mix with OEM profile
( I plan to use them with Vortex Dub shot PBT caps )
Offline Oobly
« Reply #4 on: Mon, 18 August 2014, 07:40:15 »
Maybe get som Tai Hao sets and mix and match them? Not sure where you can get the 1.75x right shift, though.
AFAIK, the only ones with 1.75x right shift are Cherry profile.
If I were you, I would get a full GMK set that you like (say Dolch perhaps) and then those GMK mods that SpAmRaY linked to. You won't find higher quality keycaps than those!
Buying more keycaps,
it really hacks my wallet,
but I must have them.
