Author Topic: (rant) I think im going to give up on lubing switches and stickers  (Read 18719 times)
Offline Altis
Re: (rant) I think im going to give up on lubing switches and stickers
« Reply #50 on: Wed, 03 September 2014, 12:26:29 »
meh, I do it the lazy way, a syringe and press the stem down and add 1 drop, easy peasy and feels just as good as my greased, oiled and stickered switches that I got off someone else.
Can you please elaborate on this?
I'm on the fence about trying to lube some switches, but the idea of desoldering a 104-key board and taking it all apart is really discouraging... it's a little much, even for me.
Offline Jixr
« Reply #51 on: Wed, 03 September 2014, 13:27:11 »
Yeah, I just have a syringe full of the lube, ( synthetic teflon oil ) and just remove the keycap, press the stem down and add a drop on each slider point, done and done.
Offline Altis
« Reply #52 on: Wed, 03 September 2014, 21:48:50 »
That would sure save a lot of trouble... no issues with contacts then? And they seemed to be smoother?
My first attempt at lubing switches was Alps black, and a few of the keys had some issues with the contacts for a while afterwards.
Offline Jixr
« Reply #53 on: Thu, 04 September 2014, 12:05:41 »
originally yes, I had issues, but thats because I was just using waaay too much lube. but using the syringe and very lightly lubing the sliders has not caused any problems for me.
I can't tell the difference between a traditionally lubed one and the way I do it, but while I don't think lube can hurt, I do think its pretty over hyped. I'd much rather take a worn in switch than a freshly lubed new switch.
