Author Topic: A couple of 122-key IBM Model F's  (Read 20734 times)
Offline jacobolus
Re: A couple of 122-key IBM Model F's
« Reply #50 on: Sat, 23 August 2014, 03:32:39 »
Oh darn. I offered $80 for the $189 one, he countered with $130, and then a couple days later messaged me saying to offer $100 and he’d accept it. I missed the email until now, and looks like it sold at $130. Oh well.
« Last Edit: Sat, 23 August 2014, 04:17:27 by jacobolus »
Offline pr0ximity
« Reply #51 on: Tue, 26 August 2014, 09:59:23 »
All this talk of the challenge makes me want to give this a go in the future when I have some additional workshop space and time. What's a fair price for these? Seems to be pretty varied, based on condition and the seller's knowledge of what s/he has.
Offline berserkfan
« Reply #52 on: Tue, 26 August 2014, 10:15:57 »
my leather punch (which was old and I spent some time with a file sharpening) over wood did a great job at cutting a hole in just about anything. I got a new one with the express purpose of using it to punch holes in material for model Fs.
I don't get it; a leather punch is for belts and the holes are perpetually way too small. How do you guys chance on precisely the correct diameter for Model F barrels?
Offline E TwentyNine
    • Some of My Keyboards
Offline 1391406
« Reply #54 on: Tue, 26 August 2014, 11:05:44 »
Pretty much. Prices range from approx. $100 to $200.
Offline berserkfan
« Reply #55 on: Tue, 26 August 2014, 12:18:38 »
Something like this:
http://www.harborfreight.com/hand-tools/punches/9-piece-hollow-punch-set-3838.html
Aha..
rather than buy all that stuff just to create my own membrane I think I'll just get someone to make it for me...
« Reply #56 on: Tue, 26 August 2014, 13:46:20 »
The barrels are 1/2" diameter (13mm) but the "buttresses" on the AT & 122 make the 5/8" (16mm) a better choice.
Alternatively, you could just snip a little bite out where the buttress comes through.
For the XT style barrels, the stand-off is a little post.
With the art foam like I use, you could probably just push the barrels in and the foam would deform itself around the alignment tabs. With harder or tougher materials, it might not work as well.
- D Trump 2026-10-24
« Reply #57 on: Tue, 26 August 2014, 13:48:21 »
1/2" leather punch
Does not fix the problem of the first guy trying to make them.
1/2" punch and snip the corner for the buttress was the plan. Would have worked too if I could get it back together with the foam being too thick.
« Last Edit: Tue, 26 August 2014, 13:50:09 by dorkvader »
