Author Topic: model M key cover removal tool?  (Read 3947 times)
Offline wellington1869
« on: Fri, 12 June 2009, 01:33:18 »
is there one?  Whats the best way to remove just the key covers quickly and not the whole key? Is there an off the shelf tool? Or should I just bend a paperclip? (wont it scratch the key when it (invariably) slips as I pull?). Etc. Thanks for any ideas :)
using: ms 7000/Das 3
« Reply #1 on: Fri, 12 June 2009, 01:38:53 »
Quote from: ripster;95646
Hooleon.
Much faster than the wire version.
omg, thanks man. I love seeing dedicated tools (ie, dedicated to a single task :)  Perfect. oh wait a minute tho - this is for the whole key or the keytop (ie, removable key cover on the keys)?
« Reply #2 on: Fri, 12 June 2009, 01:44:36 »
interesting, hoolean has two items it calls "key top pullers" and one item (the classic wire one) which it calls "key puller". Clearly there's a diference - but then when you read the description of each, they each say they're for pulling 'keys'.  But what I want is a 'key top' puller, not a key puller.  SO what to do? Can anyone verify that the non-wire pullers here are key TOP pullers and not KEY pullers?
http://hooleon.com/miva/merchant.mvc?Screen=CTGY&Category_Code=KT-P
« Reply #3 on: Fri, 12 June 2009, 01:48:03 »
excellent. thanks bro. :)
« Reply #4 on: Fri, 12 June 2009, 01:50:49 »
holy crap, they want $8 for shipping!!!
Ok, does anyone have an extra one they want to sell me? I'll pay you retail so long as you put it into a regular 40 cent envelope!!!  (Retail + 50 cents i'll give!)
[update: *sigh*, bit the bullet and bought it :) ]
« Last Edit: Fri, 12 June 2009, 03:40:06 by wellington1869 »
« Reply #5 on: Thu, 18 June 2009, 17:32:04 »
Hooleon.
Much faster than the wire version.  ONLY for pulling the key caps off of two piecers.
btw, this baby was/is perfect. I'm a keycap pulling machine.
Offline wheel83
« Reply #6 on: Thu, 18 June 2009, 17:57:09 »
my fingers are strong enough to pull of most of the caps. i think its from the buckling springs lol
I <3 BS
Offline greynolds
« Reply #7 on: Fri, 19 June 2009, 16:10:47 »
Quote from: ripster;95650
Don't get the red one - garbage.  Use the wire one for pulling entire keys.  The white one for keytops only.
Wave them at strange people in the NYC subway to clear a path.
I was given a couple of pullers that look just like the red one recently when I sent my Zenith keyboards off for repairs.  For the Alps keycaps, that style of puller seems to work really well.
Offline itlnstln
« Reply #8 on: Fri, 19 June 2009, 16:13:25 »
I had a hard time getting Alps keys off the red one.  The wire is far superior.  Alps keys tend to fit very tightly, the red puller kept slipping off.  I haven't had a problem with the red puller on Cherrys or Buckling Springs, but the wire one is a much better design.
Offline lowpoly
« Reply #9 on: Fri, 19 June 2009, 16:23:53 »
Original Alps keycap puller:
The green thingy is a keycap inserter. I think.
