Author Topic: any way to fix a broken switch?  (Read 5483 times)
Offline Special K
« on: Fri, 12 June 2009, 14:51:31 »
The L key on my Dell AT101W seems to be broken.  About half the time when I press it, the keypress isn't registered.  Sometimes more than one keypress is registered, and the rest of the time it works correctly.  This behavior just started a couple days ago.  Before that it worked fine.
Is there any way to fix this?  I suspect buying a new switch wouldn't be a cost-effective solution, as I only paid $15 for this board to begin with.  Also I bought it used.
Filco FKBN104MC/EB
Filco FKBN104M/EB2
IBM Model M 1391401 - 11/13/87
Quote from: ripster
LOL - we're on post #163 of this mega-thread and you've gone from"keyboard n00b" to "keyboard sn0b".  We've done our job.
Offline itlnstln
« Reply #1 on: Fri, 12 June 2009, 15:06:20 »
You can try switching the guts out with a rarely-used key like Scroll Lock.  If that doesn't work, there might be bigger problems with the switch, and you will have to decide if you are willing to commit to some soldering work.
Offline chimera15
« Reply #2 on: Sun, 14 June 2009, 04:52:38 »
Quote from: Special K;95775
Yeah, just get a desoldering tool, and move a switch from one of the alt's on the right or left side that you would never use.  That's why they put them there right? lol
Alps boards:
white real complicated: 1x modified siiig minitouch kb1903,  hhkb light2 english steampunk hack, wireless siig minitouch hack
white with rubber damper(cream)+clicky springs: 2x modified siig minitouch kb1903 1x modified siig minitouch kb1948
white fake simplified:   1x white smk-85, 1x Steampunk compact board hack
white real simplified: 1x unitek k-258
low profile: 1x mint m1242 in box
black: ultra mini wrist keyboard hack
blue: Japanese hhk2 lite hack, 1x siig minitouch pcb/doubleshot dc-2014 caps. kb1903, 1x modified kb1948 Siig minitouch
rainbow test boards:  mck-84sx
Offline Special K
« Reply #3 on: Sun, 14 June 2009, 10:44:39 »
Quote from: itlnstln;95784
Do I need a soldering iron to "switch the guts out" with a different key?  Your post seems to say that I don't, but chimera15's post below seems to say that I do.
Are you saying I can either exchange the internals of the switch, which doesn't require a soldering iron, or exchange the entire switch, which does require a soldering iron?
Filco FKBN104MC/EB
Filco FKBN104M/EB2
Quote from: ripster
Offline IBI
« Reply #4 on: Sun, 14 June 2009, 14:20:31 »
Quote from: Special K;96227
Yes, Assuming the switches on the Dell are mounted in such a way that you can open them up while they're still soldered down.
Owned: Raptor-Gaming K1 (linear MX)(Broken), IBM Model M UK, Dell AT102W, Left-handed keyboard with Type 1 Simplified Alps.
Offline cchan
« Reply #5 on: Sun, 14 June 2009, 15:24:38 »
Quote from: IBI;96285
They are.
HP Envy17: Core i7-2760QM, 8GB DDR3, 128GB Crucial m4 + 750GB Hitachi, Windows 7 Home Premium x64, Cherry ML4100, Logitech M500, HP zr22w
IBM Thinkpad X60: Core Duo T2400, 2GB DDR2, 128GB Samsung 830, Xubuntu 12.04 x86, Cherry ML4100, Logitech M205, HP zr22w
Raspberry Pi Model B: BCM2835, 0.25GB DDR2, 8GB Samsung SD card, Raspbian Wheezy, human interaction devices as above
Offline chimera15
« Reply #6 on: Mon, 15 June 2009, 00:39:46 »
You can open the switch and swap out some of the internals, however this can be difficult, and sometimes results in the key feeling off.  It's a lot simplier just to leave the internals alone, desolder the switch completely, and solder in a new one.  Once you have a desoldering tool, and a soldering iron, it's pretty easy to do, take you about 5 minutes.
Alps boards:
Offline Special K
« Reply #7 on: Tue, 16 June 2009, 21:37:49 »
Quote from: chimera15;96378
D'oh, I don't have a soldering iron either, although I do know how to solder.  A quick amazon search shows a basic Weller costs ~$40:
http://www.amazon.com/Weller-WLC100-Soldering-Hobbyist-Yourselfer/dp/B000AS28UC/ref=sr_1_1?ie=UTF8&s=hi&qid=1245206136&sr=8-1
They have a more expensive model for ~$83 that looks like the ones I used in college:
http://www.amazon.com/Weller-WES51-Analog-Soldering-Station/dp/B000BRC2XU/ref=sr_1_6?ie=UTF8&s=hi&qid=1245206197&sr=8-6
I guess repairing keyboards is cost-prohibitive unless the keyboard is really expensive, you know you will be repairing a lot of them, and/or you already have the necessary equipment.
Filco FKBN104MC/EB
Filco FKBN104M/EB2
Quote from: ripster
Offline chimera15
« Reply #8 on: Wed, 17 June 2009, 15:34:06 »
Quote from: Special K;96939
Just go to radioshack, they have desoldering and soldering tools that work fine.  I wouldn't imagine it would cost you more than $20-30.  Get the silver solder too.
This is the one I use. Works fine.  $11.
http://www.radioshack.com/product/index.jsp?productId=2062731
Silver solder $5.50
http://www.radioshack.com/product/index.jsp?productId=2062725
Soldering iron  Dual wattage $11
http://www.radioshack.com/product/index.jsp?productId=2062730
I've got digital controlled soldering irons, and really expensive stuff for soldering, but I always come back to the simple stuff cause it's easy to plug in and set up and gets the job done.
« Last Edit: Wed, 17 June 2009, 15:39:35 by chimera15 »
Alps boards:
Offline skriefal
« Reply #9 on: Wed, 17 June 2009, 18:46:10 »
It may be just a bit of dust or dirt inside the switch, preventing it from operating consistently.  I had that happen with a Northgate Omnikey with white Alps switches.  Popped off the cap, grabbed a can of "compressed air", and used it to blow into the switch internals while manually operating the switch plunger a few times.  That seemed to resolve the issue... at least until the dust decides to relocate again!
Offline Special K
« Reply #10 on: Mon, 06 July 2009, 17:00:16 »
Quote from: skriefal;97225
You might be right.  I recently noticed that I'm not having the problem with the L key anymore.  Now it works fine.  I didn't even do anything to clean or change the switch.
« Last Edit: Mon, 06 July 2009, 22:05:27 by Special K »
Filco FKBN104MC/EB
Filco FKBN104M/EB2
Quote from: ripster
Offline huha
« Reply #11 on: Mon, 06 July 2009, 22:03:10 »
Quote from: ripster;96946
That expensive Weller is the one to get.  I have one.  Highly recommended.
Best feature - auto turnoff.  Saved me from burning the house down many a time.
Expensive Weller for $80? What a toy. Real men use Weller's Magnastat soldering irons. If you've worked with them once, you don't ever want anything else. Trust me.
-huha
Unicomp Endurapro 105 (blank keycaps, BS) // Cherry G80-3000LSCDE-2 (blues, modded to green MX) // Cherry G80-3000LAMDE-0 (blacks, 2x) // Cherry G80-11900LTMDE-0 (blacks, 2x) // Compaq G80-11801 (browns) // Epson Q203A (Fujitsu Peerless) // IBM Model M2 (BS) // Boscom AS400 Terminal Emulator (OEM\'d Unicomp, BS, 2x) // Dell AT102DW (black Alps) // Mechanical Touch (chinese BS) Acer 6312-KW (Acer mechanics on membrane) // Cherry G84-4100 (ML) // Cherry G80-1000HAD (NKRO, blacks)
Offline talis
« Reply #12 on: Mon, 06 July 2009, 23:59:44 »
Quote from: huha;101471
-huha
The magnastat ones are nice, but they don't work well if you want to use lead free solder.    The melting point of 97/2.5/.5 solder is about 40C (100F) higher then the older 63/37 lead solder.  Its hard to find tips that will reach that temp.  The analog/digital ones usually let you dial the temp up high enough to work with it.
The one on the left is a magnastat.
The tip is the second from the right, it has a little magnet on the bottom that looses its magnetic properties at a particular temperature, that in turn turns the heat on and off to the iron.
I know I promised a soldering tutorial, took about 70 pictures the other day.  I just need to organize them all and put the rest together.
« Last Edit: Tue, 07 July 2009, 00:11:45 by talis »
Offline talis
« Reply #13 on: Tue, 07 July 2009, 00:39:30 »
Quote from: talis;101486
Looks like digikey is actually stocking a few of the tips for lead free solder.
Offline huha
« Reply #14 on: Tue, 07 July 2009, 20:42:41 »
Quote from: talis;101489
Got any article/ordering numbers?
-huha
Offline talis
« Reply #15 on: Wed, 08 July 2009, 01:29:09 »
Quote from: huha;101659
-huha
They seem to have two sets, one is 700F, one 800F.  I assume the 800's are for Sn/Ag/Cu, even if its higher then I'd run a digital station.  The 700F tips work fine for tin/lead, but I find is  too cold to get proper wetting for lead free.
I've never actually used my magnistat station for anything but tin/lead solder, but it looks like these should work for lead free :
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=PTA8-ND
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=PTC8-ND
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=PTS8-ND
« Last Edit: Wed, 08 July 2009, 01:32:41 by talis »
Offline GreeN
« Reply #16 on: Thu, 09 July 2009, 06:34:58 »
Quote from: Special K;101439
Are you a user of macro/hot-key utilities by any chance? Auto Hotkey in particular still has some odd bugs in windows which can cause very similar occurrences
Offline GreeN
« Reply #17 on: Thu, 09 July 2009, 09:33:05 »
Quote from: ripster;101863
I haven't heard of that one.  Source?
For me it works fine all the time.  It may be buggy when trying to get a script to act properly but once it does it's been completely transparent - never missed a keypress.
Simply out of experience, on multiple computers. Auto Hotkey seems to reproduce odd input variations when simultaneously actuating a command whilst transferring in/out of DX windows, for example. I find them hard to reproduce personally, but I have experienced extremes of multiple keys not functioning until I erase all instances of AHK
Offline Special K
« Reply #18 on: Thu, 09 July 2009, 10:58:34 »
Quote from: GreeN;101853
No, I've never used any of those utilities before.
Filco FKBN104MC/EB
Filco FKBN104M/EB2
Quote from: ripster
