Author Topic: [GB] LED Color Cover Changer for Cherry Mx Switch [Closed, SHIPPING]  (Read 90230 times)
Offline mrbread
Re: [GB] LED Color Changer for Cherry Mx Switch (just less than $1)
« Reply #50 on: Mon, 01 September 2014, 12:29:57 »
Precisely, though the exact shade of purple is unknown because it depends on the intensity of blue and how strong the red LED is.
True, but you can adjust the brightness of the color on most keyboards, so I guess it depends on the cover.
Thanks.
Hey, I have a few questions that I want to ask before buying this. I have a keyboard with red LED that means if I buy the pack with blue cover it will actually give me purple instead of blue, right? From my understanding this is a cover to put on top of the led and under the key cap, all I have to do is remove the key cap, put on the cover and put back the key cap to make this work, right? (Just want to make sure the steps are easy and doesn't require anything else). Thanks.  :)
The step is easy. You just have to put these covers on over the LED. No soldering or other steps required.
Thanks, I have placed an order. Let me know if there is any problem or not.
Thanks for your great support! All invoices have been already sent to you guys.  :D
Paid. I know I am fast.
The info. looks alright.
Thanks.
Offline keypro
  • * Commercial Vendor
« Reply #51 on: Tue, 02 September 2014, 10:43:36 »
All invoices are being sent out! Prepare for your wallet  :p
Offline davedebris
« Reply #52 on: Tue, 02 September 2014, 11:13:33 »
I feel like a lot of people wondered the same question I wondered which was "I have xxxx color LEDs, will xxxx LED cover work?"
.... this helped me try and envision the results best. HTML color wheel mixer. Hope this helps.
http://www.w3schools.com/tags/ref_colormixer.asp
Offline keypro
« Reply #53 on: Tue, 02 September 2014, 12:16:24 »
That's such a great link demonstrating how the color will turn out when they're mixing. I should have realized about the instruction of colors. I will post a bunch of picture when I have various LED colors on my hand. Thank you for the reference though.  :thumb:
Offline keypro
« Reply #54 on: Thu, 04 September 2014, 01:26:58 »
The order list
metalliqaz (invoiced)
LechnerDE (paid)
Heliosphere (paid)
jessa  (paid)
nhatientri (paid)
B. T. Nguyen (paid)
strikerpxs (paid)
A. gomez (paid)
The Mad Professor (paid)
khemist (paid)
C. D. Mortier (paid)
C. Knudsen (paid)
H. Vargas (paid)
quake4mhg (paid)
davedebris  (paid)
moosiey (paid)
J. Tastnesen (paid)
TKMaximus (paid)
mrbread (paid)
A. Hemmings  (paid)
HendyZone (invoiced)
Katushkin (paid)
Raymond Phuong (invoiced)
Wainwright (invoiced)
Offline PandaSPUR
« Reply #55 on: Sat, 06 September 2014, 18:26:54 »
Placed my order :D
Home:
Das Keyboard - MX Browns - Vortex Grey Side-Printed PBT Caps
Work:
KBT Pure - iKBC Aluminum Case - MX Reds
Vortex Poker II - Frosty on Lime Acrylic Case - MX Clears
Offline keypro
« Reply #56 on: Sat, 06 September 2014, 20:57:09 »
Placed my order :D
The invoice has been sent to you. Thanks for your support. :D
Offline PandaSPUR
« Reply #57 on: Sat, 06 September 2014, 20:59:18 »
Placed my order :D
Paid  :thumb:
Home:
Work:
Offline keypro
« Reply #58 on: Mon, 08 September 2014, 12:06:35 »
Offline keypro
« Reply #59 on: Mon, 08 September 2014, 12:07:44 »
Offline kolashnikov
« Reply #60 on: Mon, 08 September 2014, 14:12:13 »
I may have missed something, but the OP lists pink among the 7 available colors and the order form has purple instead. These appear to be distinctly different colors according to Manchias' pic. Am I correct in guessing that his Y and U keys show purple and his arrow keys are colored pink? If so, which of these two are actually for sale?
Offline keypro
« Reply #61 on: Mon, 08 September 2014, 21:58:14 »
You're correct. It is actually purple color not a pink one. I will post all of these led color being shining on my backlight caps.
Offline keypro
« Reply #62 on: Mon, 08 September 2014, 22:31:16 »
Here are the photos of my aliens with 7 different colors on Poker II kb. The colors don't look as good as good how they actually are because of the light in my room and my weak photography skill. From Left to Right
Red
Orange
Yellow
Purple
Light Green
Dark Green
Offline kolashnikov
« Reply #63 on: Tue, 09 September 2014, 13:28:38 »
Many thanks for the clarification and additional pictures!
Offline quake4mhg
« Reply #64 on: Wed, 10 September 2014, 01:23:57 »
They look awesome
Offline keypro
« Reply #65 on: Wed, 10 September 2014, 11:17:13 »
You're welcome!
They look awesome
All invoices are being out again!
Offline ImBZppl
« Reply #66 on: Thu, 11 September 2014, 21:11:25 »
Hmm, is it possible  to change my color choices? I haven't paid yet so should I submit a new order?
I may actually want to add some more as well.
« Last Edit: Thu, 11 September 2014, 21:19:23 by ImBZppl »
Offline keypro
« Reply #67 on: Thu, 11 September 2014, 21:39:01 »
Yes, you can still change and add the order. Just send me PM which colors you want to change and I will edit the invoice.
Offline ImBZppl
« Reply #68 on: Sat, 13 September 2014, 01:02:53 »
Okay I PMed you a revised list of colors.
Offline keypro
« Reply #69 on: Sat, 13 September 2014, 19:33:35 »
all invoice are being sent out!  :p
Offline ImBZppl
« Reply #70 on: Mon, 15 September 2014, 01:38:26 »
Thanks for letting my add to the order. Invoice Paid.  :)
Offline keypro
« Reply #71 on: Tue, 16 September 2014, 11:18:48 »
You're very welcome. Thank you for your payment though :)
Offline The Mad Professor
  • Ex Scientia, Rabies
« Reply #72 on: Wed, 17 September 2014, 10:36:36 »
Found out I need to order more. Second order made.
Mad Science means never stopping to ask "What's the worst that could happen?" - Schlock Mercenary
Offline keypro
« Reply #73 on: Wed, 17 September 2014, 12:52:52 »
 :-X The invoices have been sent to you and others. Thanks!
« Reply #74 on: Wed, 17 September 2014, 13:14:02 »
...aaaaand paid.
Offline xybre
  • clickityclackclickityclack
    • Music and Stuff
« Reply #75 on: Wed, 17 September 2014, 14:47:22 »
I just put in for 44 sets, I hope thats still possible!
I'm getting a GON and a duck Eagle soon with white LEDs and I'm looking to tint them. :D
GON NerD 60 & Duck Eagle & Unicomp Ultra Classic & Das Keyboard Ultimate
Offline Aidenknives
« Reply #76 on: Wed, 17 September 2014, 20:15:35 »
Just submitted a form for 30 sets! Awaiting invoice! :thumb:
Offline Aidenknives
« Reply #77 on: Thu, 18 September 2014, 11:43:13 »
Invoice paid!
Offline xybre
    • Music and Stuff
« Reply #78 on: Thu, 18 September 2014, 11:49:20 »
Invoice paid!
Also, please use the address from PayPal since its formatted correctly. I think Google mangled the one on the order form (or else I screwed up).
Offline keypro
« Reply #79 on: Thu, 18 September 2014, 12:31:52 »
Invoice paid!
Could you send me your address via PM? Just to make sure that your address is correct. Thank you for your great support  ;D
Offline xybre
    • Music and Stuff
« Reply #80 on: Thu, 18 September 2014, 12:34:41 »
Invoice paid!
Done :)
Offline Aidenknives
Any upcoming shipping dates?? Just got my white LED Poker and way too excited! :eek:
Offline keypro
You can expect the shipping date around in the end of this month  ;)
Offline spenghammer
Is it too late to get in on this??
Offline keypro
It's not too late. You are free to order some. I'm still taking orders until the end of this month.
Offline mrbread
I was wondering if I want to add more packs to my previous order that I had already paid, how are they calculated? Lets say I placed an order of 15 packs and I paid, now I want to add 5 more packs. Thanks
Offline spenghammer
Wicked! Thanks :D  Order incoming:D
I would imagine that, since the monetary part of the first transaction is complete (i.e. - the invoice is marked as "paid" by Paypal), you place a new order for the five additional packs.
Offline keypro
your old and new invoices will be calculated separately.
Offline mrbread
Ah thanks.
Ah thanks.
Offline keypro
all invoice are being sent out!  :p :p
I'd just like to say thank you to keypro for doing this.
I had wanted a way to change the color of the LEDs in my keyboards without replacing the LEDs entirely.
My original plan was to use stained-glass paint to cover the LEDs and do it that way, but these things are so much easier to use.
Offline keypro
I'm glad for running this gb and thank you for all the great supports in helping me answer many questions in this thread. I will keep continuing find good stuffs for the GH members. Maybe something like wooden wrist rest and poker 2 kb bag for poker fans. I'm quite busy on making some secret stuffs for upcoming event.  :p
Offline LechnerDE
That sounds interesting! Looking forward to that special event  :thumb:
Offline Lord of Narwhals
  • You can call me NaLo
    • A selection of posts chosen with care, prior to remembering your indifference to them.
Do these make the bottoming out distance shorter? If so will using these with O-rings be a problem?
In the end.. the keyboard's most grand form of existence is as an ethereal bridge between man and machine..    Each depression of the keys, evanescent.. Our transitory thoughts crashing into the web, carving canyons through the internet wasteland such that life may once again flourish..
HHKB Pro 2 Poker II [MX Red]
Offline keypro
I'm not quite sure about it. Let wait some pros answer would be much better. :-X
Offline ImBZppl
I am worried if these will fit under the poker 2 pbt keys. Can you check since it looks like you have a poker in the screenshots.
Offline keypro
Yes, poker 2 stock keycaps fits nicely, if you place those correctly.
Offline Aidenknives
Just sent you a PM regarding my accidental message to you about canceling an order. Just clarifying that I do NOT want to cancel. Thanks!  :thumb:
Offline ImBZppl
Thanks, I was worried the thickness of the PBT would cause them to not fit correctly. I wonder if these will fit under the vortex backlit PBT pom keycaps too. If you have them can you check those as well?  :)
