Author Topic: BenQ XL2411Z 144hz dirt cheap  (Read 3534 times)
Offline ApocalypseMaow
  • Kitteh Overlord
  • Say WHAAT...
« on: Mon, 25 August 2014, 12:11:55 »
  • Kitteh Overlord
  • Say WHAAT...
Re: BenQ XL2411Z 144hz dirt cheap
« Reply #1 on: Mon, 25 August 2014, 12:13:30 »
Offline AKmalamute
  • HHKB Scrub
« Reply #2 on: Mon, 25 August 2014, 12:46:17 »
I'm old-school; I don't like widescreen monitors, and the typical lack of clarity that flat panels provide make my eyes hurt.
 But I see they have a decent enough attempt in the 16:10 field here although sadly it doesn't have a USB hub at that price.
HHKB-lite2, Dvorak user
« Reply #3 on: Tue, 26 August 2014, 13:41:33 »
I plan to take two 16:10 monitors mounted vertically for a sweet 5:4 setup. I really liked the 5:4 CRTs.
Offline halfkiller
« Reply #4 on: Fri, 29 August 2014, 11:21:06 »
Interesting that thee are still a lot of non widescreen aspect users out there. I prefer 16:10 and 21:9 aspect ratio myself hehe.
« Reply #5 on: Fri, 29 August 2014, 17:22:34 »
widescreen is best used vertically for text and forum browsing.
One issue with widescreen is that I'll be using dual monitors and then it ends up being super wide.
Depending on what you use them for, a single fullscreen "main" monitor flanked by a vertical widescreen monitor could be a great layout.
Offline HipsterPunks
  • Gangnamember
« Reply #6 on: Fri, 29 August 2014, 17:33:54 »
I own a xl2420te, solid monitor. Would love to pick up one of these for dual monitor setup. Is this site reliable?
sell ass and eat out
Offline AKmalamute
  • HHKB Scrub
« Reply #7 on: Fri, 29 August 2014, 17:52:39 »
That's how my work machine is set up. And my gaming rig at home, now that I think about it... RH monitor at 16x12, left at 12x19. (all numbers are " * 100 " like a tachometer  ;D  )
Offline theeattre
« Reply #8 on: Fri, 29 August 2014, 17:58:37 »
yeh, bhphoto is way legit. purchased from them on numerous occasions.
« Reply #9 on: Fri, 29 August 2014, 18:53:45 »
B&H is one of the most relaiable sites there is. They even have a really sweet physical location in new york.
Yeah I had my widescreen laptop set up vertically driving a 4:5 monitor next to it. The laptop was set up to browse GH and stay on IRC/Skype/email all the time and the other monitor was great for everything else.
Offline lolkey
« Reply #10 on: Sun, 31 August 2014, 14:02:00 »
I would wait. The 24" g-sync monitors are due very soon, and these might even drop more when the G line drops from BenQ. But, if you need it now and don't plan on upgrading to a g-sync GPU, this is a great monitor. This is the best 24" gaming monitor at the moment, unless you want to spend $500+ on an Eizo.
Here is a tool to help tweak the 2411z if you get a v2 firmware - http://www.blurbusters.com/benq/strobe-utility/?source=sidebar
« Last Edit: Sun, 31 August 2014, 14:05:08 by lolkey »
filco ninja mj2 tkl · mx brown · black case · blank black pbt
varmilo va87mr tkl · gateron red · black case · dye sub pbt ❤
vortex pok3r rgb · mx silent · white case · blank xda pbt
