Author Topic: [IC] 2X3X4 cyan LED  (Read 50933 times)
Offline Fnzzy
Re: [IC] 2X3X4 cyan LED
« Reply #200 on: Fri, 24 October 2014, 12:01:49 »
The sky blue LEDs are lighter in shade than I thought. Finally mounted them onto a board, here are the best pictures my phone could take to capture the color.
OMFG I JUST SAW THIS THIS IS BEAUTIFUL
edit: Is that gmk classic beige or...?
Seeing that it has little nubs on the homing keys I assume it's BSP.
« Last Edit: Fri, 24 October 2014, 17:45:35 by Fnzzy »
Offline nuclearsandwich
« Reply #201 on: Fri, 24 October 2014, 13:12:49 »
I could use quite a bit of these for various projects whether they're cyan, sky blue, or mint greenish.
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #202 on: Fri, 24 October 2014, 21:50:21 »
-100 Take me off please. Thanks.
Offline ceflame
« Reply #203 on: Fri, 24 October 2014, 22:18:00 »
just wondering how many days did it take for it to arrive from the date they ship it off ?
Placed the order on Aliexpress 8/22/14.
Arrived at my doorstep (West Coast USA) 9/16/14, so about 3 weeks.
Got it from another member here, but I'd assume it's the same set as the one Originative stocks.
Offline ceflame
« Reply #204 on: Fri, 24 October 2014, 22:27:55 »
Placed the order on Aliexpress 8/26/14**.
« Last Edit: Tue, 28 October 2014, 00:02:26 by ceflame »
Offline evolveS
  • ಠ_ಠ
« Reply #205 on: Sat, 25 October 2014, 08:02:49 »
Please remove my order from the list
« Last Edit: Sat, 25 October 2014, 10:40:28 by evolveS »
"money comes and goes, but doubleshots are forever"
-a petty thief
Offline pichu23
  • ୧༼ಠ益ಠ༽୨ FITE ME
  • ʕ ͡·ᴥ ͡· ʔ
« Reply #206 on: Sat, 25 October 2014, 09:46:15 »
Alright thanks.  :)
« Reply #207 on: Mon, 27 October 2014, 23:51:01 »
I don't think I'll be able to run this GB. I'm not financially solvent enough to handle this amount of money, as one mistake (like paypal freezing my account) can financially ruin me.
Hopefully someone else with more than $50 in savings will step up.
« Reply #208 on: Tue, 28 October 2014, 01:10:34 »
I'd be able to run this if folks want. Is there any more interest checking we want to do or should I set up a thread and googly form for a group buy?
I'll probably add every 2x3x4 color from this page. Are there any others y'all want? Throw me links.
« Reply #209 on: Tue, 28 October 2014, 01:21:10 »
Methinks it's time for a GB.
And just checking, have you run a GB before?  While this seems simple, adding more colors will make this one a ton of work.  It might be worth running just 2-3 colors max at a time.  It will cut down on the stress of it.
« Reply #210 on: Tue, 28 October 2014, 01:25:47 »
That's a valid point. I haven't run a group buy before, although I do ship a lot of stuff from home so I have some experience with the fulfillment end. What do people think about running three colors as a start and then doing more in a later round?
Offline trizkut
« Reply #211 on: Tue, 28 October 2014, 01:30:30 »
My top 3 are probably cyan, sky blue, and pink... I would probably order 2-300 of each.  If one or more of those gets pushed back to a possible later round, that's fine by me if it simplifies things for you  :thumb:
« Reply #212 on: Tue, 28 October 2014, 01:47:53 »
Based on reading the thread history, those seem to be everyone's top three. The only other one I'd consider would be what they list as orange since it looks a very nice amber color. I might just order 100 of them with the first batch to evaluate the color.
Offline Flamingchook
  • There are no dumb questions, only forbidden ones.
« Reply #213 on: Tue, 28 October 2014, 02:46:17 »
Those three colours sound fine to me. I'd definitely be in for a couple hundred of each.
MX: Filco Majestouch Metalic Blue 104-key w/ MX Brown, JD40 w/ MX Green, ErgoDox w/ MX Blue, GHPad w/ MX Blue. Topre: Realforce 87U 45g. BS: IBM Model M 52G9700 29-OCT-93
Soon™: GH60 w/ 62g MX Clear, [CTRL]ALT 60 w/ MX Green
Offline Fnzzy
« Reply #214 on: Tue, 28 October 2014, 11:32:37 »
I would also be in for cyan, pink and sky blue. Maybe 100-200 of each.
« Reply #215 on: Tue, 28 October 2014, 13:08:30 »
Cyan, pink, and sky blue sound awesome I'd be in for 100-200 of each.
« Reply #216 on: Tue, 28 October 2014, 23:06:18 »
Working on the group buy thread for Pink, Sky blue, and Cyan right meow.
« Reply #217 on: Wed, 29 October 2014, 02:08:07 »
Group buy thread is pending moderator approval.
2x3x4 LED and SIP socket Group Buy
Even though they come from a separate source, I thought offering SIP sockets with this buy would make a lot of sense. You can get hella more LEDs if you know you get to swap them out without desoldering!
Offline kitsun8
  • In need of some cash
« Reply #218 on: Wed, 29 October 2014, 03:23:20 »
How would SIP sockets work with the LEDs? This sounds cool, I'm very interested  :cool:
Offline Ripudio
« Reply #219 on: Wed, 29 October 2014, 11:22:15 »
I basically works like an electrical outlet. The sip socket goes inside the switch and gets soldered to the PCB and you can plug and unplug LEDs into the socket.
« Reply #220 on: Wed, 29 October 2014, 11:51:36 »
Basically what Ripudio said. Check out this thread here: http://geekhack.org/index.php?topic=51792.0
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #221 on: Thu, 30 October 2014, 21:51:07 »
Ya, this link is a really good resource on the topic.  If you want to see some more examples you can checkout my build log.  I have built two boards with sip sockets.
http://geekhack.org/index.php?topic=58969.msg1349714#msg1349714
Edit: Just a note.  It is super important to put LEDs into the sip sockets before you solder them.  If you don't you will have a very frustrating couple hours getting your LEDs into the sip sockets.  I know some members have made this mistake in the past and it is not a fun mistake to make...
« Last Edit: Thu, 30 October 2014, 21:53:54 by swill »
Offline DzyDzyDino
« Reply #222 on: Sun, 02 November 2014, 16:12:56 »
If this IC is still active, I am definitely interested in getting at least 100. If we can do them in increments of less than 100, I'd like 150 of each color, whatever colors there may be.
« Reply #224 on: Sun, 02 November 2014, 17:12:27 »
Dorkvader. Does locking the IC make sense?
